Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.19971 Build 19971.1.2.6 PV
=== Only for XDA ATOM/XDA ATOM PURE ===
(Final Edition)
(Final Edition)
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Hoangdat_vista
Mod TranMinhMan
Trial Mod Lamson
Trial Mod PhamNhatThanh
Trial Mod Medkid
Trial Mod nhocbanme
Trial Mod khacduy1978
Many thanks to herg62123, poorlyduck, A_C and greatbal from xda-developers
Thông tin - ROM Information:
- CE OS 5.2.19971 Build 19971.1.2.6 PV
- Pagepool: 6M
- Rom date: October 09, 2008
- ROM Version: 20081009C8WWE
- Ported from latest original ROM of HTC Opal
- Transcriber included.
- Manilla 2D with Blue Skin also included.
- Remove all help files.
Hình minh hoạ - Illustrative Images: (Updated)Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Hoangdat_vista
Mod TranMinhMan
Trial Mod Lamson
Trial Mod Medkid
Trial Mod nhocbanme
- Pagepool: 6M
- AudioManager v2.0.1819.2129 (HTC Opal)
- Audio Booster (HTC Opal)
- JBlend Java (HTC Opal)
- Outlook Enhancement (HTC Opal)
- Picture Enhancement (HTC Opal)
- Comm Manager v2.7.1.8 (HTC Opal)
- Manila2D v1.00.1819.2926 (HTC Opal)
- ArcsoftMMS v5.0.31.50 (HTC Opal)
- S2U2 v1.22 by A_C
- ClearTemp v1.1 by Vicott Wong
- HTC Sim Manager for Pocket PC v6.57
- .NET Compact Framework 3.5.7283.0
- Office Mobile 6.1
- Office Note
- SunHigh Windows Media Player 10.3 Build 19971 (Mod)
- Advanced Configuration Tool v3.2.0.0 by Julien Schapman
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.1.7.3 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- SDAutoRun v2.0 (automatic install cab files from Storage Card)
Extended ROM bao gồm các file sau (Extended ROM included the files as follows):
1. Album_2.0_1818.3032.cab
2. Album_Video_fix.cab
3. GoogleMaps_compressed.CAB (Mod)
4. Opera_v9.5_Build_2392_QVGA_WWE.cab (Mod)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn.
Link nằm trong file đính kèm bên dưới.
The link is available now.
Link is put under attached file.
ONLY FLASH ROM WITH OPTION "OS ONLY". THAT'S ENOUGH!
Để một số ứng dụng trong ROM có thể hoạt động tốt, bạn phải đặt thư mục Cabs và file SDConfig.txt (nằm trong file nén chứa ExtendedROM) trong thư mục gốc của thẻ nhớ trước khi up rom hoặc trước khi PPC reset sau khi up rom thành công.
In order to run well some utilities in my ROM, you have to put folder "Cabs" and file "SDConfig.txt" (ExtendedROM compressed file inside) in original folder of storage card before you flash the ROM or before PPC reset after flashing ROM successfully.
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Chúc vui!To download the ROM, use both Username and Password PDAVIET
Enjoy it!
Sonblack
