XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 20755)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.20755 Build 20755.1.4.0 PV
=== Only for XDA ATOM/XDA ATOM PURE ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Hoangdat_vista
Trial Mod Lamson
Trial Mod PhamNhatThanh
Trial Mod TranMinhMan
Trial Mod Medkid
Trial Mod nhocbanme
Trial Mod khacduy1978
Also thank to Author of Prophet Green Edition Clean ROM (Green Skin)
Thông tin - ROM Information:
- CE OS 5.2.20755 Build 20755.1.4.0 PV
- Pagepool: 4M
- Rom date: September 24, 2008
- ROM Version: 20080924C7WWE
- "TOUCH" function included
- Transcriber, Internet Calling also included
- High Speed ROM.
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- .NET Compact Framework 3.5.7283.0
- Office Mobile 6.1
- Office Note
- ArcsoftMMS v5.0.31.11
- Windows Media Player 10.3 Build 20755
- Adobe Reader LE 2.5
- PHM TrayLaunch
- Advanced Configuration Tool v3.2.0.0 by Julien Schapman
- ClearTemp v1.0.3 by Vicott Wong
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.55
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080704.5.1
- Pocket Screen v1.3 by JJM. Roseboom
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.1.7.3 (open/close applications fastly)
- PocketRAR v3.71 by Alexander Roshal
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- SDAutoRun v2.0 (automatic install cab files from Storage Card)
- Internet Calling
- Some changes from my previous rom (build 20753)
Hướng dẫn - Guides:
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link không còn
The link is not available now.
PASSWORD for unpack ROM: SONBLACK
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Chúc vui!
Enjoy it!
Sonblack
VOKE
Tức nhỉ :(, chắc người thứ hai cũng ko đến nỗi nào , pác Sơn up toàn giờ độc ko !... :-??
Chắc bản này ngon đây, cám ơn bác Sơn thiệt nhiều nhé ... :D
Atomo2
Wow! nhanh dữ ta. Thanx SONBLACK. Lai có cái để trao đổi và đánh giá. Rocket ROM. Được up lên theo tên lửa của Trung Quoc tối qua đây!!!.:))
rockcaonguyen
Để thử cái này xem sao .. thanks SON
UI trời .. hjc hjc .. Link bị sao rùi ... có mí trăm kí à ... Bác sơn coi lại thử
luong
SONBLACK có thể làm khi chọc vô biểu tượng % PIN tren taskbar thì xuất hiện CT power prepe.. được không bản này vẫn không có. cái đó đẹp vậy mà?
thienly12333
ặc mới hôm qua nói là từ từ mới ra mà sáng nay lên đã thấy rom mới rồi,bái phục:D.ai xài rồi nói cho biết rom này có thay đổi gì không vậy!!!!!
luong
ặc mới hôm qua nói là từ từ mới ra mà sáng nay lên đã thấy rom mới rồi,bái phục.ai xài rồi nói cho biết rom này có thay đổi gì không vậy!!!!!
mới up xong cũng chưa thấy gì mới, chỉ thấy call internet.
Sonblack
Nói vậy mà coi được sao?
ROM mới đương nhiên là Core và Build mới. Cái này quan trọng hay soft linh tinh quan trọng.
Xin nói thẳng quan trọng là ở Windows Mobile mà thôi, còn soft thêm vào thì có gì khó đâu, bạn cài cũng có kia mà.
luong
xin lỗi SONBLACK mình là dân amatơ nên không thấy được Core và Build mới nó khác nhau như thế nào? bạn làm cái khi chọc vô % pin trên taskbar thì khởi động CT power prope.. được không?
thienly12333
anh sơn bớt giận,bạn luong nói là mới up rom thì chỉ thấy internet calling là mới chứ bạn có nói là test rồi mà chỉ thấy có phần đó mới ko đâu!!!!ai cũng biết mỗi lần buil sẽ có thay đổi gì đó trong CT mà.cảm ơn anh còn không kịp nữa chứ ai mà chê!!!!
rockcaonguyen
Hu hu .. sao mình down về và giải nén .... nó chỉ có file Txt ko vậy ... kì quá .. làm thử rất nhiều lần rồi ... heo heo với .. hu hu
letuankhung
X-( trong file .TXT co' link down do' X-( không chịu đọc gì hết vô đó coppy linh ra down rom về rui úp X-(
đề nghị bác sơn xả xitret' =)) thanks bác sơn nhiều =))
dangkhoivt
Ai nói gì thì nói, mình vẫn dùng SPB backup 2 restore lại toàn bộ data sau khi uprom vẫn ko hề bị trục trặc gì hết, ai ở không đi cài lại từng soft. Up từ WM6 lên 6.1 cũng không thấy có vấn đề gì, những tính năng mới của ROM vẫn hoạt động bình thường, còn những software cũ chạy ào ào cũng ko có vấn đề gì. À cái Start Menu sao ở bản ROM này sao lại trở về kiểu cũ vậy, xấu quá với lại kiểu kia nhìn quen mắt rồi, ai giúp mình sửa lại với. Cái Internet calling thì xài sao vậy nhỉ???
thienly12333
nếu bạn muốn có Start Menu đẹp thì bạn cài thêm wisbar advance để thay đổi.đây là diễn đàn dành cho tất cả mọi người nên cái gì bạn thích thì hãy chịu khó cài thêm!!!chúc vui
dangkhoivt
Ko phải ý mình nói là start menu giống như bản mấy bản ROM trước, stick mấy cái icon recently used lên trên đầu đó
Sonblack
Đã bảo dùng SPB Backup 2 Restore là được thì sao không restore luôn cái Menu Start theo kiểu cũ luôn đi :D
Cái gì cũng vậy, phải mày mò tìm hiểu. Đây là khu vực ROM cho Atom / Atom Pure, không phải là nơi hướng dẫn dùng soft. Nếu có nhu cầu qua khu vực Soft cho PPC mà tự tìm hiểu nhé.
Sonblack
Điều bạn yêu cầu sẽ có ở build sắp tới. Mọi thứ sẽ như ý bạn. Cái % pin ấy. :))
dangkhoivt
Hơ, no' đâu có restore cái đó được vì ROM là ROM mới mà, thành ra những thứ gì của rom mới đều có đầy đủ, nó chỉ restore software với mấy cái themes trên nền ROM mới thôi, không tin thì cứ thử đi chứ mình restore ko hề gặp 1 bug nào hết. Chán ghê, mình làm rồi, xài ổn định nên mình mới nói chứ nếu ko được thì còn nói làm gì nữa.
