XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 20931)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.20931 Build 20931.1.5.0 PV
=== Only for XDA ATOM / ATOM PURE ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Lamson, TranMinhMan, Hoangdat_vista
Trial Mod PhamNhatThanh, khacduy1978
VIP Medkid, nhocbanme, nhattoai
herg62123, poorlyduck, A_C, adderz91, mpenguin14 and greatbal from xda-developers
Thông tin - ROM Information:
- CE OS 5.2.20931 Build 20931.1.5.0 PV
- Pagepool: 6M
- Rom date: November 14, 2008
- ROM Version: 20081114D3WWE
- Transcriber included.
- Manilla 2D with Black Skin also included.
- Remove all help files.
- XIP & SYS from xbeta.cn
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- AudioManager v2.0 Build 1819.3326 (Jade)
- Audio Booster v2.1 Build 1819.2131 (Jade)
- JBlend Java v3.3.5 Build 20081015.1.1 (Jade)
- Outlook Enhancement (Jade)
- Picture Enhancement (Jade)
- Comm Manager v2.7.1.8
- ArcsoftMMS v5.0.31.51R2 (Jade)
- Acrobat PDF LE 2.5 (Jade)
- Enlarge Start Menu (Raphael)
- Enlarge TitleBar (Jade)
- M2DC v0.22.215 by mpenguin14
- Manila2D v1.00.1819.2926
- S2U2 v1.35 by A_C
- S2P v0.55 by A_C
- HTC Sim Manager for Pocket PC v6.58
- .NET Compact Framework 3.5.7283.0
- Office Mobile 6.1
- Office Note
- Google Maps (automatically run)
- Opera Browser (automatically run)
- SIPChange (automatically run)
- Windows Media Player 10.3 Build 20931
- Advanced Configuration Tool v3.3 by Schap
- PHM Registry Editor v0.70 for Pocket PC by Philippe Majerus
- Pocket RAR v3.80 by Alexander Roshal
- ClearTemp v1.1 by Vicott Wong
- PIM Backup v2.8.0.0 by FdcSoft
- Pocket Screen v1.3 by JJM. Roseboom
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.1.7.3 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link không còn - The link is not available
UP ROM VỚI TÙY CHỌN "OS+ExtendedROM".
FLASH THE ROM WITH OPTION "
OS+ExtendedROM".
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Chúc vui!
Enjoy it!
Sonblack
KiD2034
Ui Ui Ui ROM Mới Hot Hot Hot xông đất anh Sơn 1 cái lấy hên :D.
Em sẽ mãi chờ và mãi đợi anh Sơn (Up ROM) =))
A
atman
Guest
Wow! As promised! .. Waiting for the download link to appear..
knmh2005
công nhận nhanh thiệt!mới đây mà đã có rom mới rùi!
Thanks A.SON nhiều nha!Chờ thui!
AnhPheCT
Xin chúc mừng Atom!!! Chúc Bác SonBlack có nhiều sức khõe!!! Cống hiến niềm đam mê! Chia sẽ niềm Hạnh Phúc!!! Cảm Ơn!!!
Sonblack
Sonblack không làm gì thừa và cũng chẳng muốn để thiếu (tất nhiên phải có 1 lợi ích nào đó). Điều quan trọng là bạn dùng thêm Soft nào và chỉnh setting của S2U2 ra sao mà thôi. Mình dùng chẳng thấy treo gì cả.
tiensylao
Banned
Cảm ơn bác đã hồi âm! Mình cũng từng nghĩ như thế nên mình đã không cài vào bất kì đâu và mình cũng tinh chỉnh setting rất ok nhưng vấn đề trên vẩn bị bác à. Với lại không biết bác builrom bác dấu thằng thằng chỉnh cái phần chỉ ấn vào nút power thôi máy mới lên.chứ em thấy là em ấn vào nút nào máy cũng lên nguồn cả!!!:O
when device is off:
o Lock all buttons except Power button
o Do not lock buttons
Xin Bác Chỉ Giáo!
Sonblack
when device is off:
Xin Bác Chỉ Giáo!
Mặc định từ ROM gốc của Atom là không có cái này, đương nhiên là chỉ nhấn Power mới lên. Nếu cài thêm từ soft của HTC e rằng không hữu hiệu gây ra nhiều thứ lỗi linh tinh. Atom không phải của HTC.
S2U2 đã setting tối ưu.
@All: Với ROM này, phần lớn các ứng dụng cho ROM mà mình thêm vào đều nằm ở ExtendedROM vì vậy lưu ý khi up rom phải với tùy chọn "OS+ExtendedROM" thì mới đầy đủ. Việc làm này để tạo nhiều chỗ trống cho ROM.
Lỗi mở Power từ biểu tượng Pin cũng đã được khắc phục.
Rom đang được upload lên host, vui lòng chờ thêm tý nữa.
tranthetai79
Thắc mắc bản rom ngay 11 tháng 11 vừa rồi
Ở phần contact khi vào xem danh bạ ko dùng đựoc cuộn danh bạ bằng Touch kéo lên mà phải dùng Scroll bar .Anh em nào để ý chỗ này ko. =D>
tiensylao
Banned
thanks bác nhiều! Mình đã chọn kỉ càng phần "OS+ExtendedROM". Vì mình đã thử ở bản 19971 thì không cần tinh chỉnh gì cả nhưng nút power không bị lỗi đó.Nên mình nghĩ là khi biulrom bác đã dấu hay bỏ nó đi nơi nào!
Sonblack
Đúng ra bài này bị xóa vì sai quy định, không đúng chỗ. Nhưng xin mạn phép trả lời luôn:
- Bản 20757 Final Edition có chức năng này.
- Bản 19974 không có, điều này ai cũng biết nên có ai nói đâu.
Build ra thế nào thì nó thế ấy mà thôi.
Bạn đã đề cập vậy tức là bạn dùng 19974 rồi.:D
tiensylao
Banned
Muốn cho nó cuộn thì bác cài bản 20575 FE là có tích hợp touch đó.Mình thấy ok mà. Bạn xem lại nha.!
tranthetai79
Cảm ơn anh sơn
Xin cáo lỗi .Cảm ơn anh sơn.đúng em đã dùng bản ko có Scroll nhưng phải hỏi anh như thế vì em đã đc khám phá sự khác nhau giữa các bản của anh, chưa khám phá hết đã có rom mơi, sáng mai phải up sớm thôi=D>
KiD2034
Bóc tem mừng wá lại 1 đêm mất ngủ chúc anh SƠn ngủ ngon
Chúc anh em PDA Việt mất ngủ vì up ROM :D
Loa Loa Loa có ROM rùi pà kon cô bác ơi Down về đi rùi khỏi ngủ , kô uổng công đợi chờ từ chiều tới giờ , vừa xông đất vừa bóc tem lun vui wá :p
Cảm ơn anh Sơn thật là nhiều nhiều .
tiensylao
Banned
__________________
Chào bác! Em đã dùng thử thì cái nút power vẩn bị như thường. Cái này gây ra nhiều bất tiện nhất là khi để máy trong túi bị cấn nút. Bác có thể chỉ em soft nào tinh chỉnh được không bác.! chân thành cám ơn!
takaru
đêm qua say quá , bác Sơn báo có rom mới mà không thể online được , sáng nay dậy sớm down về up để còn test. Cám ơn a Sơn rất nhiều .
mykolor
S2U2 không phù hợp với dòng Atom cho lắm, vì vậy khi bấm power để tắt máy, mặc nhiên máy chỉ tắt đèn màn hình (phím không bị khoá), sau đó (tuỳ thời gian bạn setting bao nhiêu phút kô dùng thì máy tự tắt) thì máy mới tắt ở trạng thái sleep (lúc này thì tất cả các phím đều bị khóa rồi đó).
Bạn nên setting thời gian tắt máy khi không dùng là 1 phút. Còn không thì chỉ có cách gỡ bỏ S2U2 đi thì mới hết bạn à.
AnhPheCT
Vấn đề này đã nói nhiều lần rồi!!! Bản tiếng Anh không biết sử dụng thì tải Bản Tiếng Việt S2U2-VH 1.32 của Nguyễn Phú Côn Đảo!! Rất phù hợp cho Atom ko bị gì hết!!! Giao diện tiếng việt dễ chỉnh!!!! Vào Tab Phần mềm việt hóa mà tải!!! Ko bàn cải S2U2 nữa!!!! Còn không thích thì tắt nó đi! chích vào iLock2 trong Program/system và vào StarUp xóa iLock2 đi!!! Là xong!!! Chúc Vui!!!
mykolor
Bạn có chắc là bản S2U2-VH 1.32 bấm power tắt máy thì khóa được các phím cứng luôn chứ? Chắc là bạn đang xài, tui muốn bạn xác nhận để tui cài. (khỏi mất công download cài vào lại gỡ ra). Thanks trước nha
