XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 21109)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.21109 Build 21109.1.5.0 PV
=== Only for XDA ATOM / ATOM PURE ===
Lời cám ơn - Thanks:
Super Mod PhamQuang
Super Mod BatKid
Admin Kawaguchi
Adv. Mod Dvha79_ddt
Mod Lamson, TranMinhMan, Hoangdat_vista
Trial Mod PhamNhatThanh, khacduy1978, nhattoai
VIP Medkid, nhocbanme
herg62123, poorlyduck from xda-developers
Thông tin - ROM Information:
- CE OS 5.2.21109 Build 21109.1.5.0 PV
- Pagepool: 6M
- Rom date: January 3, 2009
- ROM Version: 20090103D8WWE
- Well supported A2DP
- Transcriber included.
- Manilla 2D with
Blue Skin also included.
- Remove all help files.
- XIP & SYS from xbeta.cn
Hình minh hoạ - Illustrative Images:
Chức năng chính - Main functions:
- AudioManager v2.0 Build 1820.1321 (Elfin)
- JBlend Java v3.3.5 Build 20081015.1.1 (Jade)
- Outlook Enhancement (Elfin)
- Picture Enhancement (Elfin)
- Comm Manager v2.7.2.8
- ArcsoftMMS v5.0.31.63 (Elfin)
- Enlarge Start Menu (Moderate from Elfin)
- Enlarge TitleBar (Elfin)
- YouTube v1.5.1820.2325 (Elfin)
- Manila2D from Elfin (Moderate)
- HTC Sim Manager for Pocket PC v6.58
- .NET Compact Framework 3.5.7283.0
- Windows Media Player 10.3 Build 21109
- Office Mobile 6.1
- Office Note
- HTC Album (Moderate from Elfin)
- SIPChange (automatically run)
- Advanced Configuration Tool v3.3 by Schap
- Pocket RAR v3.80 by Alexander Roshal
- ClearTemp v1.1 by Vicott Wong
- PIM Backup v2.8.0.0 by FdcSoft
- Pocket Screen v1.3 by JJM. Roseboom
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.2.0.0 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn - The link is available now
DOWNLOAD
(Pass: SONBLACK)
UP ROM VỚI TÙY CHỌN "OS+ExtendedROM".
FLASH THE ROM WITH OPTION "
OS+ExtendedROM".
Chúc vui vẻ!
Enjoy it!
Sonblack
pal2000
Nhanh thật, lại có Rom mới rồi, hi vọng bác up link sớm để anh em tận dụng ngày nghỉ vọc ROM. Thanks bác nhiều
Sonblack
原始数据 未有删减任何数据
Build date属于12月中旬
21109的build date属于10月
哪个新哪个旧大家能够清楚
21109也就是Wm6.5的数据是沿用早期Aku1.4的数据
某些人放出来的21109=把关于里面的1.4改成了5.0而已
所以和aku1.4的内容基本都是一样
21009Aku1.6的提升很大,更稳定,内存控制更加的完善。
相对于21109和之前发布的20954而言。
我们发布的每个Rom的核心都是经过反复的测试的。
当然没有最稳定的,也没有最完美的。
少一点墨迹。
I hope member jonhson9931 helping me to translate above quote to English. Thank you in advance.
Refer: http://ivgappc.cn/viewthread.php?tid=9890&extra=page=1
johnson9931
(21009) Original data, without any adds or delete
Build date: middle third of December
21109 build date: October
It’s clear which one is the latest!
The data of 21109----so called WM6.5, adopted data from AKu1.4
AKu 5.0(1.5) in 21109 just is some simple change from 1.4,so most of datas are the same as 1.4!
Compared with 21109 and 20954, 21009AKu1.6 has a big upgrade, more stable, better in memory control .
Before released, all ROMs were tested time after time.
Of course, there is not any perfect ROM, we just try our best to keep all original!
Sonblack
Thank you so much member johnson9931.
Every your opinions, I will remember and I also know you come from China. :D
I downloaded everything with build 21009 AKU 1.6 already.
I will release it after this build.
AnhPheCT
Bác Sơn khỏe ghê!! Ra Rom liên tục!! Test mõi tay luôn!! Cảm ơn! rất nhiều! Download về test thôi!!!
pal2000
Link down chậm quá bác Sơn ơi :((, 2.55 kb/s - 7h57 min mới down xong. bác có thể chuyển sang link khác được không.
Cảm ơn bác nhiều;;)
Stone_ll
It is too difficult for me to download your Rom from Mediafire.com
Just because I can't find a good proxy to visit mediafire.com
why not use the ftp method as before or use other share space website
johnson9931
老兄,mediafire上的东西在我们中国确实比较难下载,但是我能下了!
用无界(这是个代理,在国内被禁止的外国网站用都能上的)+ 世界之窗浏览器下载就可以了,记得要保证你的网速,我2M的电信就很好了,太慢的网速会导致下载不完整。有时你点击下载后会回到下载界面而不是下载对话框,多试几次或者关了浏览器在开就行了。祝你好运!
johnson9931
Thank you very much for your attention on my concern!I do like your ROM very very much!and now i try to make ROM myself,i'd like to ask you some questions about building ROM if it's possible.and of course,please let me know if you have difficulties in reading Chinese language!
my MSN:luozongsheng@hotmail.com
Sonblack
Now, I finished the ROM build 21009 AKU 1.6.
I'm testing and will release soon. :D
AnhPheCT
Bản Rom này còn hơn Bản Rom Clear nữa!!!! Up xong Storage còn 40MB Program 20MB. Quá đã để cài ứng dụng!! trong khi bản Rom Clear trước Up xong còn khoản 35MB Storage, 20MB Program!! Cảm ơn!! Mình test hôm qua tới giờ chưa thấy có trục trặc gì cả!!! Cảm ơn Anh Sơn nhiều!!!
noobZ
Links dow chậm quá .... lúc lại 0bytes/s hic cả ngày chưa dow dc ... bác chuyển links khác được không? cảm ơn nhiều...!
