XDA ATOM EXEC - PDAVIET ROM WM6.1 (Core 19212)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.19212 Build 19212.1.0.3 PV
=== Only for XDA ATOM EXEC ===
Lời cám ơn - Thanks: Special thanks to
Man PhamQuang (everything)
Admin Kawaguchi (tools)
Trial Mod PhamNhatThanh (others)
VIP TranMinhMan (welcome screen, calculator skin, others)
VIP nhocbanme (IrDA and Bluetooth)
Thông tin - ROM Information:
Pagepool: 6M
IrDA and Bluetooth: no bugs, please don't complain
This ROM is built based on XIP & SYS 19212 from Kaiser Original ROM WM6.1
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- CE OS 5.2.19212 Build 19212.1.0.3 PV
- .NET Compact Framework 2.0.7045.0
- Office Mobile 6.1
- Office Note
- Windows Media Player 10.3 Build 19212
- Windows Live for Windows Mobile v10.6.0034.0800
- Adobe Reader LE 2.0
- Advanced Configuration Tool v2.02.0.1.0 by Schap
- ClearTemp v1.0 by Vicott Wong
- Task Manager v3.0 by FdcSoft
- Contacts Manager extension v1.6 by FdcSoft (support copying many contacts from Phone to SIM)
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.47
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080222.3.1
- Total Commander CE v2.5 by Christian Ghisler
- Mode SMS (change message display on PPC)
- PCM Keyboard v0.14 (support Vietnamese keyboard)
- X-Button for PocketPC v1.51 (Build 30744)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- Now, support SuperSIM
- and more ...
- Change icon inside program folder and other application icons.
Hướng dẫn - Guides:
Chỉ cần tải file .exe chứa ROM và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
You only download the exe file included ROM and perform steps which program require until it finishes. Your PPC will be automatically hardreset later.
Link download đã có sẵn.
The link will be available now.
LINK WILL BE HERE
PASSWORD for unpack: PDAVIET
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download ROM, the members use both Username and Password are PDAVIET
Cuối tuần vui vẻ.
Have a good weekend.
Sonblack
S
saudoi
Guest
Thanks đại ca Sonblack nhá em là người đầu tiên download. Hồi hộp quá , Rom này nhìn pro thật
amk
đang đào rồi nhưng muôn hỏi bác xem ROM này có chỉnh đc blacklight từ màn hình nền hay fims cứng không ahj =D>
Không! Vì HTC Home không hỗ trợ. Phím cứng càng không! (Sonblack)
aqua73
I trỷd the rom but after uploading it the device í blocked. The same thing happens with all the ROMs with HTC skin. What might be the problem? ATOM EXEC
spiderman_anhvu
host này không hỗ trợ trình tăng tốc download hả bạn? mình dùng flash get ma không downd được... dùng trình download mặc định thì lâu ghê, hơn 25phut lận
à, sorry, được rồi. Phải khai báo cả user và pass vào thì mới down được. thanks bạn nhé :D
hbtrung
Máy CQ mình không cho download file *.exe :) Bác nào đổi đuôi khác rồi cho mình xin link mới với...
Thanks
spiderman_anhvu
Thanks
cơ quan bác "thâm" quá =)) để tối về nếu bác vẫn chưa down được thì pm mình phát, mình re-up cho. Máy cơ quan mình upload thì lâu lắm, lại dễ disconect nữa :D
hbtrung
Thôi, vậy phiền Bác quá, để tối em về nhà down :)
Thanks
spiderman_anhvu
Lúc mình vừa mới up rom xong, ở cái today có 1 hàng biểu tượng ở phía dưới (chỗ system tray). Trong đó cái cuối cùng là để tắt màn hình giống như shutXP. Nhưng sau khi soft-reset thì mất béng cái đó luôn. Bác chỉ cho mình cách để hiện lại với :)
Sonblack
Bạn cho hiện lên lại cái BatteryStatus Plugin là cái đó nó có theo thui à!
Chắc bạn tắt cái báo pin, báo Operator, báo tốc độ CPU của PPC đi rồi!
hanhhn
anh sơn ơi em ko tìm thấy cái phần calculator nằm ở đâu cả anh, anh giúp em với nha, thanks
Sonblack
em cám ơn anh...ah sao anh ko tích hợp commanager va torch hả anh?
Về Comm Manager, mình thích bản gốc, rất chuẩn.
Còn Touch à, sợ rồi, coi chừng sau này lệch cảm ứng thì đừng trách cứ Sonblack =))=))=))
Í ẹ, lộn rồi Torch đó hả. Quên mất tiêu rồi, làm đèn pin chứ gì? Hao pin bà cố lại chê ngốn pin thì rõ khổ :(:)(:)((
spiderman_anhvu
Bạn ơi, cái này hao pin ghê gớm quá :(. Những bản rom trước mình để qua đêm chỉ mất khoảng 4-5% vậy mà bản này sau 1 đêm mât tận... 16%.
Hy vọng bạn sẽ có cách khắc phục. Vì dùng pda vốn đã hao pin rồi nên tiết kiệm được càng nhiều càng tốt, ít nhất cũng phải available được 2 ngày chứ kiểu này thì tối nào cũng phải sạc mất
BlackMountain
[FONT="Aỉal"]Theo mình thì việc ngốn pin của WM6.1 là chuyện bình thường.
Điều quan trọng là bạn có chạy nền nhiều chương trình quá hay không mà thôi.
Mình nhận thấy, các bản ROM từ 6.0 trở lên đều như thế cả.
[/FONT]
