XDA ATOM EXEC - PDAVIET ROM WM6.1 (Core 20273)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.20273 Build 20273.1.3.3 PV
=== Only for XDA ATOM EXEC ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Medkid
Mod Hoangdat_vista
Trial Mod Lamson
Trial Mod PhamNhatThanh
Trial Mod TranMinhMan
Trial Mod nhocbanme
Trial Mod khacduy1978
Thông tin - ROM Information:
- CE OS 5.2.20226 Build 20226.1.3.0 PV
- Pagepool: 6M
- Rom date: August 16, 2008
- ROM Version: 20080816B4WWE
- High Speed ROM.
- Based on the 20226 ROM but some changes
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- CE OS 5.2.20273 Build 20273.1.3.3 PV
- .NET Compact Framework 2.0.7045.0
- Office Mobile 6.1
- Office Note
- ArcsoftMMS v5.0.31.11
- Windows Media Player 10.3 Build 20273
- Adobe Reader LE 2.5
- PHM TrayLaunch
- Advanced Configuration Tool v2.02.0.1.0 by Schap
- ClearTemp v1.0.2 by Vicott Wong
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.49
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080610.2.1
- Pocket Screen v1.3 by JJM. Roseboom
- Total Commander CE v2.5 by Christian Ghisler
- SMS Display Mode by Sonblack (change message display on PPC)
- WKTask v1.1.7.3 (open/close applications fastly)
- PocketRAR v3.71 by Alexander Roshal
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
Hướng dẫn - Guides:
Chỉ cần tải file .exe chứa ROM và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it, then follow the guide step by step that the program requires until it finishes. At the end, your Atom Exec will automatically perform a hard reset.
Link đã có sẵn.
The link is available now.
ATOM EXEC ROM 20273 - PDAVIET
PASSWORD for unpack: SONBLACK
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Up cả ExtendRom để có được giao diện màu đen của
Wireless Manager.
Flashing with option "Update Item" is "OS+EXtendedROM" for having black skin of Wireless Manager.
Cuối tuần vui vẻ!
Have good weekend!
Sonblack
multilovehn
Bác Sơn ra bản mới rồi à. hay quá, ko biết tai nghe bluetooth của mình có bị như bản 20226 ko nữa. để thử test xem thế nào. Thank bác trước nhé
giangharry
Hix, minh vua up ban rom cua bac Khoa Ha xong, 1 ban rat muot. Gio bac Son lai ra them ban rom moi. The la lai co them 1 dem voc vach rui ^^ thank bac Son nhiu nha.
hoanganhquynh
bản rom rất đẹp và chạy ổn định lại không tốn pin cho lắm.Cảm ơn bác Black!
mrducbao
Lại có cơ hội được thử một bản Rom hay sau bao ngày chờ đợi. Trân trọng cảm ơn những người như bác Son Black.
dungrock
Thank bác Sonblack, bản rom này giao diện và một số đặc điểm ok hơn so với bản trước. Tuy nhiên máy của mình cài rom của bác khởi động vào desktop thì nhanh, nhưng phải để khoảng 3-5 phút chọt mới chạy. Không biết tại sao??? Khi hoạt động được rồi thì chạy mượt nhất trong các rom mình sử dụng. Thanks bác Sonblack nhìu
Sonblack
Chính xác. Lý do là do HTC Home đấy bạn à. Không sao, sau đó mọi thứ lại đâu vào đấy thôi :D Tắt HTC Home đi thì mọi thứ OK hết nhưng Today nhìn hem có đẹp :)):)):))
risk4u
ExtendRom là gì hả bác.Em chưa up ROM bao giờ nên không biết
risk4u
Em up ROM xong thì không có bảng hiện thông số máy (RAM,PIN,...) và Wireless Manager không có black skin mặc dù khi up em đã chọn option OS+EROM rồi.Thế là bị làm sao ạ?
Mà bác cho em hỏi là bản này không hỗ trợ weather ạ?
kenny9699
hi, i can't download it. is there other way to download thanks =D>
kha0xx
Để upRom tốt nhất là mình nên để up
ALL hay
OS only hay
OS + Bootloader hay
OS + Extendrom
vậy anh SonBlack???
lyductuong
anh Sonblack ơi cho e hỏi, e đả up bản CE.5.2.20226 của anh rồi, e đã Backup, thì nay e Re nó lại thì có được không (khi e Up bản mới này)?
ancntt
sau khi mình up bản rom này của Sonblack thì môcx lần soft reset lại máy là bi treo luôn, không vào destop được. phải tháo pin ra rồi reset lại mới được. không biết có bạn nào bị giống mình hay không nữa, nhờ bác Sonblack giúp dùm. Thanks Sonblack vì bản Rom rất pro, lại đẹp mắt nữa.
Sonblack
anh Sonblack ơi cho e hỏi, e đả up bản CE.5.2.20226 của anh rồi, e đã Backup, thì nay e Re nó lại vẫn được phải không (khi e Up bản mới này)?
Restore kiểu này sẽ không hoàn hảo đâu nhé, ROM chạy sẽ ì ạch hơn. Đó là khuyến cáo! Build càng mới thì sẽ có một số thay đổi bên trong, restore như thế sẽ không chuẩn đâu!
minh_prime
Bạn thử hardreset lại và up lại bản rom xem sao. Mình up rồi và ko bị như vậy, chỉ hơi lâu khi vào desktop thôi do giao diện của HTC home hơi nặng mà thôi. Chúc bạn thành công. :-D
tuandat090
bản này xài ko biết có ai bị lỗi giống em ko ,nghe nhạc ở chế độ offcreen ko được ,chỉ được khoảng 3 phút là off luôn .
dungrock
Đúng, cứ khoảng 3-4 phút là off máy. Máy tự động chuyển qua chế độ standby. Các chương trình đang chạy dừng hết. Mình vào chỉnh back light, power setting đều không được8-Bác Sơn kiểm tra lại và tìm cách giúp anh em với|
