XDA ATOM EXEC - PDAVIET ROM WM6.1 (Core 20758)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.20758 Build 20758.1.4.1 PV
=== Only for XDA ATOM EXEC ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Lamson, TranMinhMan, Hoangdat_vista
Trial Mod PhamNhatThanh, khacduy1978
VIP Medkid, nhocbanme
Many thanks to herg62123, poorlyduck, A_C and greatbal from xda-developers
Thông tin - ROM Information:
- CE OS 5.2.20758 Build 20758.1.4.1 PV
- Pagepool: 6M
- Rom date: October 15, 2008
- ROM Version: 20081015B6WWE
- Transcriber included.
- Manilla 2D with Blue Skin also included.
- Remove all help files.
- XIP & SYS from xbeta.cn and t2home.cn
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- AudioManager v2.0.1819.2129 (HTC Opal)
- Audio Booster (HTC Opal)
- JBlend Java (HTC Opal)
- Outlook Enhancement (HTC Opal)
- Picture Enhancement (HTC Opal)
- Comm Manager v2.7.1.8 (HTC Opal)
- Manila2D v1.00.1819.2926 (HTC Opal)
ArcsoftMMS v5.0.31.50 (HTC Opal)
- S2U2 v1.22 by A_C
- ClearTemp v1.1 by Vicott Wong
- HTC Sim Manager for Pocket PC v6.57
- .NET Compact Framework 3.5.7283.0
- Office Mobile 6.1
- Office Note
- SunHigh Windows Media Player 10.3 Build 20758 (Mod)
- Advanced Configuration Tool v3.3.0.0 by Julien Schapman
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.1.7.3 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- SDAutoRun v2.0 (automatic install cab files from Storage Card)
Extended ROM bao gồm các file sau (Extended ROM included the files as follows):
1. Album_2.0_1818.3032.cab
2. Album_Video_fix.cab
3. GoogleMaps_compressed.CAB (Mod)
4. Opera_v9.5_Build_2392_QVGA_WWE.cab (Mod)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn.
Link nằm trong file đính kèm ở cuối bài.
The link is available now.
Link put under attached file at the end of this post.
CHỈ CẦN UP ROM VỚI TÙY CHỌN "OS ONLY". THẾ LÀ ĐỦ!
ONLY FLASH ROM WITH OPTION "OS ONLY". THAT'S ENOUGH!
Để một số ứng dụng trong ROM có thể hoạt động tốt, bạn phải đặt thư mục Cabs và file SDConfig.txt (nằm trong file nén chứa ExtendedROM) trong thư mục gốc của thẻ nhớ trước khi up rom hoặc trước khi PPC reset sau khi up rom thành công.
In order to run well some utilities in my ROM, you have to put folder "Cabs" and file "SDConfig.txt" (ExtendedROM compressed file inside) in original folder of storage card before you flash the ROM or before PPC reset after flashing ROM successfully.
Note - Lưu ý:Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Chúc vui!
Enjoy it!
Sonblack
AnhPheCT
Xin chúc Mừng Atom Exec!!! Sắp có Bản Rom v 20758 mới nữa rồi!!! Bác SonBlack làm việc ko mệt mõi!!!! Build Rom double! cho mỗi loại máy!!! Mình đang thèm con Atom Exec để test ( mình đang bận thi hết môn HP9), Mình định T3 này về SG 1 chuyến tậu con PDA mới đây!!! Bạn nào có đc tin cậy giới thiệu cho mình tham khảo nhé!!! Cảm ơn các TV PDAviet!!!! Cảm ơn Bác SonBlack!!! Mong rằng Atom thường có Bản Rom Build rút gọn!!!!
Sonblack
BẢN NÀY CÓ GÌ CẢI TIẾN KHÔNG BÁC,CHỨ BẢN CŨ KHÔNG VÀO ĐUƠC WEB ĐÂU BÁC NHÉ
Bản nào cho Atom Exec mà mình làm đều vào Web được tất, chẳng có lỗi nào liên quan đến WEB. Bảo đảm 100%.
xem qua các ứng dụng cũng ko thấy có j khác nhau ....
Vậy theo bạn rom mới là ứng dụng phải khác? Theo mình thì không? Core mới, build mới quan trọng hơn.
spiderman_anhvu
Nhìn cái theme ở today thích quá, từ hồi bán con Atom Exec đi không theo dõi về rom nữa. Hôm nay thấy bản rom của Sonblack mê quá, nếu mà còn atom exec thì giờ này lại đang sốt ruột chờ rom rồi :D Chúc mừng Sonblack nhé, mong bác ngày càng build được nhiều bản rom ngon(giao diện đẹp), bổ(dùng mượt mà, ổn định), rẻ(free-thích nhất cái này) cho anh em :)
phongthanminh1
EM VÀO RỒI MÀ NÓ CỨ BÁO LỖI BÁC À,MÀ LÚC NÀO CÓ LINK VẬY Ạ,CẢM ƠN BÁC ĐÃ CHỈ BẢO NHÉ
NhatToai
Mới có build mới 20758 là Mod.Sonblack thức trắng đêm là cho xong luôn kìa,rất khâm phục.Congratulations!
Sonblack
Đã hoàn tất, anh em vào down nhé! Đề nghị không post bài không liên quan đến bản ROM!
Bản rom này tuy không khác nhiều so với 19971 (vừa giới thiệu hôm qua) nhưng có chức năng Touch (có thể vuốt danh bạ, tin nhắn, file trượt lên trượt xuống tùy ứng dụng...) và đã tối ưu dung lượng để có thể có đủ bộ ứng dụng văn phòng cho Mobile (gồm cả Office Note) không phải cài ngoài nhưng ROM vẫn hoạt động tốt, tốc độ nhanh.
Sau bản rom này, mình sẽ tạm biệt anh em một thời gian, chiếc máy sẽ được trả lại cho chủ nhân của nó. Xin cám ơn người bạn của tôi, cũng là đối tác của tôi đã cho mượn máy để hoàn thành 2 bản rom (19971 & 20758) nhanh hơn mong đợi.
Chào tạm biệt và chúc vui!
thaytumap
Rất khâm phục sức làm việc + tinh thần vì cộng đồng của SonBlack. Cám ơn bạn. Lại có thêm một buổi tối ngồi vọc máy rồi...
maerit
a SONBLACK CHO E HOI..Em vừa up bản ROM của anh
Em đã làm theo đúng chỉ dẫn ...nhưng sau khi Reset máy...rồi máy bi treo...phải tháo pin ra...mới khởi động lại được...mà mỗi lần vậy phải set lại time date!!!
E cũng từng qua ben XDA up ban touchflo 20748 cũng bị hiện tượng như trên...và sau đó đã có bản updated 20755...đã khắc phục được lỗi này...!có anh em nào bị hiện tượng trên giống em không?
CẢM ƠN ANH SONBLACK ĐÃ CHO RA NHIỀU BẢN ROM ĐỂ ANH EM VỌC!
gamehuyphuong
cảm ơn anh SONBLACK chúc anh gặp nhiều may mắn trong công việc. Hi vọng anh sẽ quay lại với nhiều bản ROM mới để anh em có nhiều cơ hội thử nghiệm. Thân
pavorotty
Anh SONBLACK ơi cho em hỏi tý. con EXEC của em up bản ROM của anh tới phần BURN RADIO STACK là nó dứng im lun ko chạy nữa. Anh có thể chỉ em cách nào ko. Hì :p em mới xài nên ko rành lắm . Em đã đọc kỹ bản hướng dẫn up ROM của anh rùi nhưng mà ko tài nào up xong được mong anh chỉ dẫn thank.
Hôm trước em cũng úp thành công con ATOM nhưng mà tớii con EXEC thì pó tay :-?
Em cũng xin cảm ơn anh SONBLACK vì nhờ anh mà tụi em có được những chú PPC rất ưng ý và dẹp mắt.1 lần nữa thank anh SONBLACK=D>
Sonblack
Đã ghi hướng dẫn là nên Up ROM với tùy chọn là OS Only rồi mà, đừng chọn All (trong hộp thoại ngay trước khi up á). Tới hộp thoại có chữ Option, ngay dưới chữ này là khung trắng có chữ All, click chuột vào mũi tên chỉ xuống, chọn OS Only. Radio vẫn là Radio WM5 của Atom Exec thôi, không cần up.
pavorotty
:D:D:D:D:D:D:D hì hì thank anh nha:)
anh SONBLACK ơi em up xong rùi nhưng vo phần wireless manager thì ko thấy gì hết. chỉ có cái khung còn màn hình màu trắng. chọt vào màn hình thì nó vẫn chạy nhưng bị treo máy luon .báo là: phone off . ko mỏ sóng lên đc.:-?
vớii lại em handreset vo lại thì cảm ứng ko còn sủ dụng đc nữa. vậ là bị sao vậy anh thiệt là khó hiểu quá. mong anh giúp đỡ . thanh k anh nha :(
phongthanminh1
Đang text,nói chung bản này của bác ổn lắm,cảm ơn bác cực nhiều,mông bác sớm quay về cho ra những bản rom đầy phong cách
hung207
bản rom khá ổn định. dùng rất tốt. thank bác Sonblack. Chúc bác mọi điều may mắn.
