XDA Mobile 6 Release 3
support
Base ROM
* Windows Mobile 6, OS 5.2.318 Build 15342.4.0.01
* ROM Version: 10.1.0.811 WWE
* ROM Date: 08/11/06
* Protocol: 4.1.13.09
XDA Mobile 6 Release 3 :
* Internet Sharing via BlueTooth DUN (like WM5) is back and available! WM6 Internet Sharing is still there, the BT DUN is in addition to that!
* Office 2007
* 9 Button "Touch" Style CommManager from the Kaiser
* VoIP (See next post for instructions to set this up)
* SQLCE
* Arcsoft Composer 4.2.8.1 with SMS and MMS split apart
* pBar 1.4 (replaces HTC X-Button)
* Notepad editor
* Pocket RAR
* SIP Config 2.0.1
* SK tsync (replaces SynchroTime in XM6r2a)
* Total Commander Beta 2.5 Beta 3
* PIM Backup to 2.5
* Esmertec Java Manager (replacing Intent Midlent Manager)
* Oxios Memory
* PHM Alt-Tab (mapped to Button 5 by default)
* Windows Live Search searches via Google
* WM5torage 1.75
* SIM Manager 6.13
* dotFred TaskManager (with registry editor link setup and associations built in for .reg files)
* Regional Settings default to English (United States) and use a slash for the date seperator (M/dd/yyyy)
* Menu sounds work by default
* Pressing the "End Call" button does not disconnect GPRS but minimized the active application. Pressing and holding the "End Call" button for about 5 seconds will do a GPRS Disconnect
* Internet access over ActiveSync (USB) connection works (You must apply a registry fix on your PC first. See the next post for the fix)
* Upgraded .NET compact to 2.0 SP2
* delayedexec.exe is in \Windows but is not configured. See this post for details on using this.
The Full Release also contains the following
* PocketCM 0.9 a finger friendly contact manager
* Schap's Advanced Configuration Tool and VoIP Setup Tool
* WinXplore 0.3.2
* Mortscript 4.0
* mUn designed onscreen Keyboard skin (grey/green one)
* Mobile Justice (a security app that will send an SMS if an unauthorized SIM is placed in your phone)
* TodayAgenda Beta 1.0
* ClearTemp replaces StartClean
* Pocket Screen Capture
* HTC Audio Manager
* CicleBT (Toggle BlueTooth on and off)
* 1-Calc Lite
* PeekPocket 1.2 replaces WiFiFoFum
* MoDaCo NoData (so you can turn off data sources)
* Smartskey 0.56 (DPAD is set to 0 in the .ini so the up and down scrolling works in the Phone dialer as expected in WM6)
* DotFred's SoftKeyAppletEx
* WM5NewMenu
Download
XM6r3 Full Version
http://rapidshare.com/files/50488568/XM6r3.zip
http://www.savageground.com/downloads/mfrazzz/XM6r3.zip
Size 54012 KB
XM6r3 Lite Version
http://rapidshare.com/files/50488572/XM6r3Lite.zip
http://www.savageground.com/downloads/mfrazzz/XM6r3Lite.zip
Size 54012 KB
nhocquaytony
có ai test thử rom này chưa nhở??????????đang đợi os Core của boy_de_ghet nên lười down rom này wa rapid mới ác hix bác nào test xong cho ý kiến nhá,thanks
love_rain_2303
Em đang down .. down ở savageground nhanh phết chứ đâu có chậm. Up thử cho biết với người ta.
namket
Ai up cho ý kiến nhé mọi người, ngại úp wá hông biết có gì khác biệt ko nhỉ :D
diepthao
vừa up xong chạy thử 2h chưa thấy lổi gì , tốc độ cũng khá ổn , bản lite khá sạch sẽ thích gì thì cài thêm , không rõ là pagepool là bao nhiêu mb?
hoangnha
Rom này chạy rất nhanh nhưng chỉ bị 1 lỗi không biết có ai như mình không là tự nhiên nghe nhạc 1 bài không tới 30giây thì báo bộ nhớ đầy không đọc file được
hohnk
mình up rom này khoản 1 tuần (G4 up bằng shelltool), chạy rất nhanh. pin sử dụng cũng khá lâu 3-4 ngày nếu nghe và gọi điện thoại. nhung bàn phí Qwerty bị lỗi gỏ ! thành ~, @ -> !, #->@. $->#, .... có anh em nào biết cách chỉnh lỗi này chì mình cách sửa với.
t2b
các bác cho hỏi em mới vào nghề không biết gì cả, thế cái bản này có up được cho các dòng máy hay không, tại em thấy có các forum chuyên up rom cho từng loại PCC riêng biệt, máy em là T-mobile compact II, cả cái WM6 thì có phải là Rom không ạ
t2b
mình đã up xong nhưng không có âm thanh, lỗi o hiện pin nhưng rất đẹp, sửa thế nào hả bạn ???????/
