Base ROM Information
The base rom was an "Official" Wizard WM6 ROM that was part of the development cycle of WM6 inside of Microsoft (Dogfood as they call it). The base rom was not a port of another device rom with drivers and stuff pieced and parted onto this one, but this was an actual Wizard WM6.
* Windows Mobile 6, OS 5.2.318 Build 15342.4.0.01
* ROM Version: 10.1.0.811 WWE
* ROM Date: 08/11/06
* Protocol: 4.1.13.09
There is no Radio, IPL, SPL or Extended ROM included in this (so its G4 "safe").
What's In XDA Mobile 6 Release 4?
Bolded items are new / upgraded from XM6r3)
* WkTask 1.0.1.1 (replaces pBar and AltTab)
* Aserg's Touch Scroll Only
* HButton (Enable multiple apps on hardware buttons)
* HTC Action
* HTC TOUCH Dialer with enhanced keypad numbers by peu
* HTC Voice Recorder
* WMP Touch style skin
* PPC Contacts Manager
* QuickMenu
* MortPlayer replaces HTC Audio Manager
* Internet Sharing via BlueTooth DUN (like WM5); WM6 Internet Sharing is still there, the BT DUN is in addition to that!
* Schap's Advanced Configuration Tool v1.1 and VoIP Setup Tool
* Office 2007
* 9 Button "Touch" Style CommManager from the Kaiser
* VoIP (See next post for instructions to set this up)
* SQLCE
* Arcsoft Composer 4.2.8.1 (SMS and MMS are split apart and not merged)
* Notepad editor
* Pocket RAR
* SIP Config
* SK tsync (Time Synchronization)
* Total Commander Beta 2.5 Beta 3
* PIM Backup to 2.5
* Esmertec Java Manager (replaces the standard Midlet Manager)
* Oxios Memory
* Windows Live Search searches via Google
* WM5torage 1.78Beta4
* SIM Manager
* dotFred TaskManager (with registry editor link setup and associations built in for .reg files)
* .NET 2.0 SP2
* delayedexec.exe is in \Windows but is not configured. See this post for details on using this.
* FingerFriendlyFriends 1.0 Beta 2 (Replaces PocketCM)
* WinXplore 0.4
* Mortscript 4.1
* Grey / Black Onscreen Keyboard
* Mobile Justice (a security app that will send an SMS if an unauthorized SIM is placed in your phone)
* TodayAgenda 1.0 (Not Beta!)
* StartClean replaces ClearTemp
* PocketScreen replaces Pocket Screen Capture
* 1-Calc Lite
* PeekPocket 1.5
* MoDaCo NoData (so you can turn off data sources)
* Smartskey 0.56 (DPAD is set to 0 in the .ini so the up and down scrolling works in the Phone dialer as expected in WM6)
* DotFred's SoftKeyAppletEx
* WM5NewMenu
* Adobe Reader LE
* Battery Gauge (Displays a colored bar at the top of screen to show battery level)
* BT Crawler[/b]
* Call2Contact
* Camera 3
* Freecell (a Solitaire card game)
* SuperDoku v1.1 - Puzzle game
* Tetris - game
* Some new and fun ring tones - Nokia death, R2D2, Oldphone and Wolf Howl)
Mods made from XM6r3
In addition to the apps listed above, the following fixes and mods were made to improve the user experience on XM6r4
* Changing ringtone now stays changed when you leave the Phone app
* Using press and hold on CommManager button toggles vibrate on and off, and phone does NOT stay stuck in vibrate / no ring mode
* Regional Settings default to English (United States) and use a slash for the date seperator (M/dd/yyyy)
* Menu sounds work by default
* Pressing the "End Call" button does not disconnect GPRS but minimized the active application. Pressing and holding the "End Call" button for about 5 seconds will do a GPRS Disconnect
* Internet access over ActiveSync (USB) connection works (You must apply a registry fix on your PC first. See the next post for the fix)
* D pad now works differently with PIE. Up and down presses on the D Pad stay the same, but pressing right jumps forward a page and pressing left jumps backwards a page. Makes going through websites easier (IMO).
* Fixed the A2DP registry for sampling
* Registry Entries for PIE Connections to speed page loading
* Registry Entries to increase In Call Volume
* Press Button 1 for messaging (like normal) or hold it a little longer and HTC Action will come up (via HButton)
* WkTask setup to not show Phone and Activesync as running apps in task bar
* QuickMenu enabled for nice drop down and cascading start menu
* Touch Scroll only is active so use your finger to scroll in most places
Requirements
You MUST have an IPL and SPL at 2.xx or higher (BOTH not just one or the other).
You MUST be running ActiveSync 4.5 on Windows XP (Vista comes with the correct sync utility, although there have been issues reported about Vista and sync'ing with PPC's so be aware of that).
Before you attempt to upgrade to this ROM, Please follow this thread to learn how to flash roms, CID unlock your phone, and how to fix issues you may run into! It is also recommended that you flash your phone with a Windows XP computer and not Vista. It will work with Vista, but if you run into problems Vista can't talk to a phone in Bootloader mode!
Recomendations
* I HIGHLY Recommend that you flash back to an official rom before upgrading to this (or any) custom rom so you have a clean base (and correct any Extended ROM corruption you might have). G4 users would flash back to their provider's latest official release or the Wizard Love ROM. G3 users can use T-Mobile 2.26 for a good base.
* If you use BatteryStatus (its NOT included in the rom!) to overclock, I don't recommend overclocking above 260Mhz, and the CPUscaler settings in BatteryStatus should not be set to a min lower than 143MHz (or your device may not wake back up after going to sleep).
* Newer Radio ROMs on WM6 have had issues in the past (especially for Cingular / AT&T users). T-Mobile 2.19 (UK or NL versions) seems to be the most stable, but you can now run newer radios with the attached cab. This cab also works for some other providers but not for all, so its up to you to test what works for your phone.
Download
http://www.sendspace.com/file/pphz2k
http://www.savageground.com/downloads/mfrazzz/XM6r4.zip
tham khảo tại: http://forum.xda-developers.com/showthread.php?t=346478
* HTC Action
* QuickMenu
* Office 2007
* SQLCE
* Notepad editor
* Pocket RAR
* SIP Config
* PIM Backup to 2.5
* Oxios Memory
* SIM Manager
* .NET 2.0 SP2
* WinXplore 0.4
* Mortscript 4.1
* 1-Calc Lite
* PeekPocket 1.5
* WM5NewMenu
* Adobe Reader LE
* BT Crawler[/b]
* Call2Contact
* Camera 3
* Tetris - game
Requirements
Recomendations
Download
