tiny1990
Đọc bài trên Thesymbiancore rồi coi Video hay quá lên post bài chia sẻ với anh em
Bringing life to mobile games
eyePlay™ for mobile games is eyeSight’s™ first product to use our proprietary motion recognition technology.
eyeSight’s™ products are based on a core technology and each product is delivered as a stand-alone component with a very small footprint that can be easily integrated into mobile games through a simple API.
eyePlay™ enables the user to act as if he holds an object in his hand and perform real-life movements, while eyePlay™ translates that movement to corresponding actions in a game. Now your gamers can actually drive the steering wheel in a racing game. Or throw a shooting star at an enemy. Or shoot a basket in a basketball game. Let your imagination run wild. The possibilities abound.
eyePlay™ V1 for Symbian enabled devices
eyePlay™ V1 provides horizontal/vertical hand motion recognition that is translated to action and motion speed that is translated to power.
Ideal for integration in games such as: bowling, golfing, and games that involve shooting and kicking.
Seamless integration by API
Very small footprint
eyePlay™ V2 for Symbian enabled devices
eyePlay™ V2 provides four direction hand motion recognition (up, down, left, right) for mobile games.
Ideal for integration in games such as: sword fighting, tennis, baseball and punching games.
more info
http://www.eyesight-tech.com/default.aspx
catch the video
http://www.ynet.co.il/articles/0,7340,L-3521257,00.html
Source www.thesymbiancore.com
Hix cái video nó dấu link kỹ qua phải dùng đến Net Transport mới lấy dc, post lên youtube cho anh em coi cho thoải mái
http://youtube.com/watch?v=yWsr9RklHT4
Coi xong lục tung cái Google mà ko thấy link nào,hix đành phải chờ vậy
Nếu ai chưa xem clip thì hối hận cả đời. Ung dung này chỉ xài camera thoi. mình có ông chú làm trong hãng này. và ổng đã chia sẽ với mình. mình xài thấy rất hay. Ổng nói không được chia sẽ và phát tán phần mêm này. Nếu không thành quả sẽ bị hack và công sức nghiên cúu đổ hết xuông biển (tức là phan mềm này đang là beta - chua có bổ sung key). Nên các bác ở tỉnh Bình Dương thì gọi mình nhé, mình cho xài thử. à mượn thì phải khao 1 chầu cafe nhé. mình thật may măn vì là người VN đầu được xài phần mềm này ôi sướng vô cùng. Theo mình được bíêt thì giá của sản phẩm thông minh này sẽ là 10 - 30 USD (giá chưa thống nhất) và sẽ được phát hành cùng với N96. tức là ai mua N96 sẽ có phần mềm này cài sẵng. Cảm ơn các bạn đã đọc tin này
