Sao cái ông tác giả Rafpigna gì đó toàn upload ROM lên hotfile nhỉ? Em down bản ROM (SD) RAFDROID HD 3.2.2 mà từ 09h sáng đến 17h chiều mà được có 65%, nản quá!
Có bác nào có bản 3.2.2 SD không up giùm em lên MF or 4Share với.
Của bạn đây! Chờ thêm 1h nữa nhé!
http://www.mediafire.com/?etc6i503dpss3
Sao em vào trắng trơn vậy?0 items found to display!
không biết bản 4.x so với 3.2 cái nào hơn nhỉ ai sài so sánh với
3.2 - 25.FEB.11
Some improvements and fixes to radio/audio driver,
this "should" fix phone freeze in some setups, also if I was not able to replicate the issues
Tweaked for more battery life on some sd cards usage
Updated hosts file with last one
4.0.2 - 10 MAR 11
Reverted the weather fix. If you weather doesnt work apply the fix in post 2
4.0.1 - 9 MAR 11
Reverted to radio drivers from 3.2 for better data stability
Fixed a typo in init causing some issues with data and booting
Fixed some drivers dependencies
Fixed PPP: working again
Included WeatherSync fix
Reverted to camera app with working preview
Some fixes on some parts of the system to improve stability and speed.
Some other small fixes
4.0 - 6.MAR.11
New base TELUS 1.84.661.1
new kernel rafpigna 1.8 OC
updated gmail
updated market
updated flash player so you will have no more erros
modified camera app: disabled review to not show the "share" menu (credit cmylxgo)
updated busybox to 1.18 stable
added custom wifi possibility
added ppp possibility again using a separate radio lib to not "touch" the rmnet radio lib so battery drain will not be affected.
modified init and init.log to have better debug informations
zip align of all apps on boot to improve speed, ram, and battery drain
updated some driver and libs for better stability
updated all languages including Serbian and handwriting languages
MMS sizes 300kb, 600kb, 1024kb (default 300kb, choose size in the sms settings)
reduced freeze a bit when installing apps from the market
some other small fixes and tweaks I forgot
Chào cả nhà, mình đang thử update từ 3.2 lên 4.0.1 nhưng không thành công. Sau khi isntall file Zip xong và bôt lại thì nó cứ đứng hoài ở logo Android và chữ RafDroid, chờ đến cả tiếng đồng hồ vẫn vậy. Bực quá làm lại với 4.0.2 cũng không cải thiện gì hơn. Mình dùng Leo 512 và cũng đã phân vùng SD đúng như hướng dẫn. Nhờ các bác chỉ giáo gỡ rối vụ này giùm.
Thanks!
