jaguaralani
ROM SOURCE : http://www.miui-dev.com/
ROM BASE 1.6.10
KERNEL ACA r610
How to Install
Download the ROM
Unzip using 7zip
Copy ANDROID folder to the root of your SD card
Click CLRCAD then HaReT
First boot takes 5-10min ( Building 1 GB data.img )
Restart ( Please do It )
Download Link for JaguarMIUI-V8 ( 11-June-2011 )
DOWNLOAD MIRRORS ARE NOT ALLOWED
(MAGLDR files Inside)
http://hotfile.com/dl/120581743/3a76038/JaguarMIUI-V8.7z.html
If your THEME MANAGER does not work, download THIS FIX, unzip the root folder inside your ANDROID ROM FOLDER and restart
http://hotfile.com/dl/120587251/3ecb6ee/root.7z.html
Change LOG ( JaguarMIUI-V8 ) - (11/June/2011)
Updated ROM BASE to 1.6.10 (Latest)
Updated kernel to ACAr610
Updated English Language Pack to English Pack 1b (Lateset)-
[Change to English through Setting/3rd tab/scroll down to the keyboard icon/second row and choose English ]
Improved Battery Drain. ( huge improvement - Thanks to ACA Kernel)
Smoother UI
Improved Theme Graphics.
Some Tweaks/Fixes.
New Official MIUI Dark Theme
Fixed Dialer Graphics
Completely DeOdexed
New rootfs
New MUSIC EQUALIZER..thanks MIUI-dev..
Improved GPS positioning and allow Wireless network assisted positioning
New Customizable Toggles
New Customizable Sound Settings
Other UI performance enhancements
Lots of Contacts Issues fixed
New status bar icons
New USB Toggle in Status bar pull down menu
Phone:
T9 Dialer has been optimised to improve search optimisation and also database size.
Added support for T9 to search long names
Messaging:
Fixed SMS session cache
Fixed issue in messaging where playing multimedia resulted in invalid volume
Other optimisations with messaging and call log interactions
Contacts:
Added improved copy selection of numbers from menu list
Adding an empty contact will result in the menu forwarding to the stored contacts list
Optimisation of multiple contacts, list will show most recently contacted number for the list of numbers
DND:
Added support for keyword filtering of messages (SPAM filter)
Blacklisted numbers can be given notes
Lockscreen & Status Bar:
Fixed issue with password lockscreen in landscape mode causes abnormal layout issues
New USB toggle switch in Status Bar pull down
Fixed 3rd party status bar icons, no longer using the previous single notification counter. Icon notifications are shown in Status bar homescreen and lockscreen
Themes:
Added download indicator to Theme Manager UI to improve visual optimisation of download progress
Fixed issue where themes failed to load or caused Force Close (FC)
Fixed issue where default icons would not reset
Gallery:
Improved optimisation of Gallery thumbnail loading speed
Music:
Fixed issue with sleepmode not waking up correctly
Fixed some issues with downloading online music (removed in our mod as its in Chinese)
Backup:
Added automatic online backup option for scheduled backups (Wi-Fi only mode)
Monitor:
Fixed problem resetting traffic data did not reset after first reset
Fixed input method issue where decimals caused issue
And More...........
If you like my work, you may want to buy me a cup of coffee, donations are not mandatory, but they really do motivate me to work harder....
(- DONATIONS -)
https://www.paypal.com/cgi-bin/webs...=PP-DonationsBF:btn_donateCC_LG.gif:NonHosted
ROM BASE 1.6.10
KERNEL ACA r610
How to Install
Download the ROM
Unzip using 7zip
Smoother UI
Some Tweaks/Fixes.
Completely DeOdexed
New rootfs
Phone:
Messaging:
Contacts:
DND:
Themes:
Gallery:
Music:
Backup:
Monitor:
And More...........
(- DONATIONS -)
