Caohieu88
AntiTheft 1.20 FINAL - Update 31/8/0
Feature:![]()
When the cellphone is lost or thief somewhere, or the SIM card is replaced this app send informations thief or founder SIM card.
!!!Use only 5 KB RAM!!! tested my SE M600i
Usage:![]()
Before: Uninstall m Runtime Environment and previous AntiTheft version
1. Install SIS
2. When install finished - go to Control Panel and start Anti-Theft Configurator (Default PIN Code: 12345)
3. Now, the application some information read and stored your SIM card
4. Check the Options menu (and set protection etc...)
5. Enter your phone number to which to send the information to the program
Todo - before change SIM card :![]()
1. Go to Control Panel start Anti-Theft Configurator
2. Disable Protection
3. OK and exit
4. Change SIM crad
5. Now, turn back to Anti-Theft Configurator
6. Enable Protection
7. OK and you see this:
Functions:![]()
Enable-Disable protections![]()
Auto send SMS when the SIM card is replaced and Send IMSI information![]()
Autostart application![]()
Send Cell ID![]()
Obtain some entries from the address book![]()
Application install only C:\ drive (phone memory)![]()
New: Anti-Theft Configurator application![]()
Add Passord Protection![]()
The Anti-Theft appl. run hide and more speed (0,5 sec) when boot your phone (After immediately closing the Anti-Theft appl.)![]()
Support more SIM card![]()
Autostart default, non selectable![]()
IMSI:![]()
What is IMSI - International Mobile Subscriber Identity - Wikipedia, the free encyclopedia
Analyse - International Numbering Plans
IMSI number format - 123 12 1234567890
123 = Country
12 = Operator
1234567890 = SIM card unique ID
Cell ID:![]()
What is Cell ID - GSM localization - Wikipedia, the free encyclopedia
Version: 1.20 Final![]()
History:![]()
0.10 beta![]()
First version
0.30 beta - http://www.persian-forums.com/f76/an...457/#post68774![]()
Add autostart function
Fixed Status Info
Some bug fixed
0.60 beta - http://www.persian-forums.com/f76/an...457/#post68849![]()
Send by SMS: Cell ID and some SIM contacts (15)
0.80 beta - http://www.persian-forums.com/f76/an...457/#post69839![]()
More Stealth - More Security
Add this app to Control Panel
The Anti-Theft script run hide and more speed (0,5 sec) when boot your phone
0.90 beta - http://www.persian-forums.com/f76/an...html#post71071![]()
Fixed Installation pack
Fixed some application bug
1.00 FINAL![]()
Add About and History menu
1.20 FINAL![]()
Fixed: Support empty SIM card
Fixed: Change Password menu Cancel - when cancel this menu set default code: 12345
!! TURN OFF CAPS BEFORE MODDING !!
!! PLEASE TEST AND WRITE HERE RESULTS !!
!!! BIG THANKS FOR ALL TESTERS !!!
