Atom Exec WM 6.1 OS 5.2.19199 Build 19199.1.0.2
TranMinhMan
WM 6.1 OS 5.2.19199 Build 19199.1.0.2 for Atom Exec
Tác giả: Abusalza
Please Attention!!! This Rom For Atom Exec Only
First i want to say BIG THANKS to bepe for a tools, Garmin, Nhocbanme, Medkid and all my BIGS Family on this forum
About this rom:
-Abusalza Green Keyboard (NEW)
-Adobe Reader LE 2.0
-ArcSoft MMS 4.2.8.1
-Artamata Pocket Light 1.0 (NEW)
-Auto Config WM 6.1 by abusalza (NEW)
-AutoInstall by abusalza
-BenQ P51 Alert Ringtones
-Cyberon VSD 1.2 Build 070917 (NEW)
-dotFred Pim Backup 2.8.0.0
-dotFred Task Manager 2.7
-Tuma Games Addons
-HTC Hermes Tools by bepe (BIG THANKS)
-HTC Home Plugins 1.5.620.722 tweaked by Garmin (NEW)
-HTC SIM Manager 6.33
-Jeyo SMS Backup 1.1
-MortScript 4.1.1.5 (NEW)
-NetCF 3.5
-New STK Module Integrated
-O2 Media Album WM6
-O2 Photo Editor WM6
-O2 Wireless Manager WM6
-PocketRAR 3.71
-PSShutXP 0.0.29.0
-QuickMenu 2.7 by Nanling
-Smart Notepad
-SoftKeys Script
-SRS WowHD 1.2.10.0
-Startup Tone
-Windows Live 10.6.0033.0700
-Wm5torage 1.80
ExtendedROM:
-Atom Life Network Settings
-Capture Screen Utility 1.0
-HTC Touch Dialer 2G (NEW)
-O2 Media Album Skin
-O2 Photo Editor Skin
-Power Management patch
-Resco Explorer 6.17
-Resco Registry Add-in
-TCPMP 0.72 RC2
-Wireless Manager Skin
-XCPUScalar 3.0.3
Minor Bugs Fixed:
-Calendar and appointment problem
-Sending and actually receiving problem via bluetooth
-Activesync problem
-Internet connection problem
-Network connection setting for current location was not listed
-Sending message notification
-...etc (hope all not listed problem fixed too)
View attachment 74770 View attachment 74771 View attachment 74772
Bản Rom này được tác giả chỉnh sửa từ bản Atom Exec WM 6.1 OS 5.2.19199 Build 19199.1.0.0, sửa một số lỗi, thêm một số ứng dụng, giao diện mượt hơn.
Tham khảo thêm tại đây.
Download ROM tại đây.
AE test bản ROM này và cho ý kiến nha!;;)
Khoa_ha
Rom chạy rất nhanh ! Nhưng tốn pin kinh khủng 1 ngày là hết
Bản này lỗi lắm treo may liên tục!
thứ hai vào phân auto configurartor chọn mạng ở việt nam
là máy không nhận ra mạng nữa. nói chung bản rom này rất chán
bangviet
Nhìn hình ảnh thấy mê quá đang muốn up thử nhưng thấy mấy bác phản hồi nhiều lỗi quá, bác vanlydochanh check lại rom đi anh em đang chờ đợi một bản rom tốt nhé!
hoangnam55
Bản ROM này khá ổn định với điều kiện không cài các phần mềm kèm theo,mình đã test và thấy rất OK
phungthanh
Làm sao OK được , pin chạy chưa được 1 ngày là hết :p:=))
nói chung các bản rom mới 6.0 và 6.1 đều tốn pin hết bạn a không như bản rom gốc đâu tôi đã cài vài bản rom mới để test đều thấy thế
akiramatsu
thế bản gốc của bác xài được bao nhiêu ngày vậy, em xài cái trên seeo2 cũng hơn 1 ngày 1 tí à, còn cái bản 6 chấm N toch em xài cũng cỡ đó, ko biết bác được bao lâu cho em tham khảo, đang định up lên bản 6.1 mà mấy anh em chê hao pin, sao trên xda albusalza lại bảo là ít tốn pin hơn wm5 nhỉ?
huynhnguyens
Cũng tùy thuộc vào nhiều yếu tố lắm bạn ạ ! Nào là pin còn tốt hay không , chương trình mà bạn sử dụng nữa ... Trung bình nếu máy bạn xài trên 2 ngày là tuyệt lắm rồi . :)
akiramatsu
ý em nói là thời gian chờ đấy ạ, ngày nhận vài cuộc gọi, nhắn tin vài phát, ko xài bất cứ thứ gì trên màn hình, ấy vậy mà chỉ được khoảng 30h thôi là tắt ngúm, còn nếu xài liên tục thì giỏi lắm chừng được 2h là hết cỡ, thế mà quảng cáo là chờ 150h, xài 5h, ko biết cục pin của em có vấn đề ko mấy bác!
phungthanh
bản rom gốc WM5 của tôi để chế độ chờ qua 1 đêm chỉ hao khoảng 2-3% pin thôi nghe gọi,nhắn tin được khoảng hơn 2 ngày. còn mấy bản rom mới 6.0 - 6.1 này hao > 10% còn nghe gọi , nt thì 1 ngày phải nạp 1 lần.
sau khi dùng bản rom này mấy ngày theo tôi đánh giá và tham khảo 1 số chỗ khác thì bản rom này còn phải sửa nhiều , tôi lại quay về dùng bản rom 6.0 RC3 hoặc bản 0.7b thôi
TranMinhMan
Sau vài ngày test Rom:
- Về pin: mình xài hơn 1 ngày vậy là đạt yêu cầu(nghe gọi khá nhiều)
- Về độ ổn định: mình chưa gặp lỗi lớn gì, lượng Ram dư ~26Mb, bản này đã đc Abusalza chỉnh sửa khá tốt. Sau khi up Rom, HR vào ctr có trên Rom mình chỉ cài: Quickmenu, Powerment, Screen Capture. Những ctr còn lại thì cancel vì: HTC Home và XCPUScalar thường làm treo máy, ctr Resco thường thì chưa XXX...
- Về giao diện: rất smooth, so với bản Build 19199.1.0.0 thì đã thay đổi khá nhiều: Icon, bàn phím...
Túm lại, theo mình đây là bản Rom free mà được như vầy đã là quá tốt.=D>
Vì lý do phải bắt kịp thời đại nên mình sẽ chọn bản Rom này để sử dụng!:D:D:D
Hpanda
Bravo! Thì ra XcpuSclar thường làm treo máy, thanks vanly đã phát hiện ra điều này, gở nó đi thì dùng chắc ngon lắm đây.
phungthanh
chưa chắc đâu tôi không cài 1 PM nào trong rom mà mỗi lần reset lại máy đều bị treo cứng một lúc phải bấm linh tinh các phím cứng mới có thể sử dụng được
Hpanda
Làm gì ghê vậy! tui thấy đúng là có treo nhưng thi thoảng thôi, dễ treo nhất là sau khi đã ngồi vọc 1 hồi (lúc đó chạy rất nhiều chương trình nhưng RAM thì không free-up được). Nhưng nói chung là bản này ngon đấy, ngon nhất trong các kiểu "ROM exec chế". :).
TranMinhMan
Vấn đề của bạn mình đã có nói trước đây rồi, đó là do bạn kích ctr HTC Home lên (Những bản Rom trước đây có nhúng HTC Home đều bị tình trạng này). Nến mỗi lần SR bạn nên chờ 30s-1p thì hãy chọt vào màn hình, nếu càng chọt thì càng treo. Nếu ko thích tình trạng này thì bạn gỡ HTC Home đi!
Good luck!:D
Mấy hôm nay sao khó vào diễn đàn wá:(:)(:)((
phungthanh
nghe nói tác giả chuẩn bị đưa ra bản final cho rom này 1 ngày gần đây. hy vọng fix đựơc những lỗi trên...
và tôi thấy trên 4share có bản rom PDAVIET_ATOMEXEC_ROM61_19716 định test thử nhưng down mãi ko được , bạn nào biết bản rom này chia sẻ thông tin đi ...
TranMinhMan
Đúng là Abusalza sẽ đưa ra bản cuối cùng WM6.1 cho dòng Atom Exec trong thời gian tới, và mình cũng hy vọng bản Rom sẽ hoàn thiện hơn. Nhưng chữ "cuối cùng" - "final" ở đây không có nghĩa là bản cuối cùng WM6.1 fix hết các lỗi, mà là bản cuối cùng mà tác giả Abusalza sẽ viết cho dòng Atom Exec (vì Abusalza đã bán máy của mình rồi). Đây thật sự là 1 tin buồn cho những ai xài Atom Exec!:((
Trích nguyên văn của Abusalza trên forum.xda-developers.com ngày 27/02/2008:
"Hi, all. I'm sorry for all problem with my rom. now i'm not have atom exec anymore. it was sold yesterday. so i'll upload final rom and kitchen too for atom exec.
regards"
spiderman_anhvu
Pin của bác chắc chắn 100% là có vấn đề rồi :)). Con atom exec của em dùng wm6 bản AKU 0.7a.0 và bản N-Touch, F-Touch đều được hơn 2 ngày(nghe gọi, sms, chạy chương trình bình thường, hạn chế nghe nhạc). Bác thay pin đi thôi :D:D:D
