ATOM LIFE - PDAVIET ROM WM6.1 (Core 20753) by TranMinhMan
TranMinhMan
PDAVIET ROM WM 6.1 CE OS 5.2.20753 Build 20753.1.4.0
By TranMinhMan
*** Only for Atom Life ***
Đặc biệt cảm ơn - Special thanks to:
Man PhamQuang
ROM Dev Sonblack
ROM Dev Dvha79_ddt
Trial Mod Medkid
Trial Mod PhamNhatThanh
Hình ảnh ROM - ROM Images:
Thông tin bản ROM - ROM Informations:
- CE OS 5.2.20753 Build 20753.1.4.0 PV T2M.
- Pagepool: 6M
- Free Ram ~ 27M.
- .NET Compact Framework 3.5.7283.0
- Adobe Reader LE 2.5
- Advanced Configuration Tool v3.2.0.0 by Julien Schapman
- Base Hue Express
- ClearTemp v1.0.3 by Vicott Wong
- Contacts Manager extension v1.6 by FdcSoft
- Esmertec Java Build ID: 20080704.5.1
- Free Mem
- FTouchFlo
- HTC Sim Manager v6.55
- Moto Q Flashlight by Cory Charlton
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7)
- Synchro Time v0.95 by Dennis Grachov
- Total Commander CE v2.51 by Christian Ghisler
- Pocket RAR 3.80 by Alexander Roshal
- PHM Registry Editor v0.7 by Philipe Majerus
- PIM Backup v2.8.0.0 by FdcSoft
- PocketNotepad v4.0.10
- PocketScreen v1.3 by JJM. Roseboom
- Task Manager v3.1
- WkTASK v1.1.7.3c
- Windows Live v10.6.0034.0800
- Default Dialpad Atom Life support 3G (mod)
- Windows Media Player 10.3 Build 20753 Black (mod)
- Comm Mannager Black (mod)
- Black Calculator (mod)
- Bootscreen (mod)
Hướng dẫn up ROM - Up ROM Guides: (up từ thẻ nhớ - up from MMC)
- Pin trên 70%, thẻ nhớ nhỏ hơn 2G, format FAT16 (trên PC là FAT).
- Battery over 70%, MiniSD is smaller than 2G, format FAT16 (on PC is FAT).
- Download và giải nén với password bên dưới, chép file AL1.DIO vào thẻ.
- Download and extract with the password below, copy file AL1.DIO to MMC.
- Nhấn Record + chọc Reset, buông Reset trước => ***MiniSD Detected*** => chờ 100% máy tự reset là đã có ROM mới!
- Press Record + Reset, leave Reset first => ***MiniSD Detected*** => waiting 100%, Atom Life auto reset and you have new ROM!
Link download đã có.
Download link was available.
http://www.4shared.com/file/1103320...IET_ROM_WM61__Core_20753__by_TranMinhMan.html
Password để giải nén: TranMinhMan
Password to extract: TranMinhMan
panteraz
Hey! New Rom! I am going to upgrade when it will be available! What about Flashlight 3.1 and Opera;
vutuantu1990
Trân trọng cảm ơn bác TranMinhMan vì những đóng góp của bác cho anh em
Háo hức chờ ROM mới ......
quanktv
Mình vừa kiếm được một em thẻ nhớ dành riêng cho up ROM, thế là lại có ROM mới xài luôn, thật là tuyệt. Cảm ơn T2M nhiều...nhiều...
axing
Bái phục Mr. Mẫn, Hình như công việc chính của Bạn là chế ROM sao vậy ? Cám ơn nhiều.
Chút xíu mới up xem có mới gì nào ? Mình rất kết cái kiểu nhắn tin theo kiểu CHAT , rễ kiểm soát và hộp tin nhắn đến rất gọn. không biết bản rom này có tích hợp không . down load xong sẽ rõ.
Thanks Mr.Man.
vutuantu1990
bác MinhMan ơi , sao em connect được vào GPRS rồi nhưng khi Connect vào Yahoo của IM Plus thi mặt cười nó ko sáng =>ko thể kết nối vào được . Tương tự là IE hay Opera cũng ko thể vào được Web nào mặc dù đã kết nối được GPRS , mà hình như là cả kết nối Sync cũng ko được nữa :((
conmeo8ya
Rom này chạy lẹ, đã quá :p chưa thấy lỗi gì.
Tiện thể a M cho em xin mấy cái theme của mấy version trước lun. Cái lào thấy cũng đẹp :|
panteraz
My mobile cannot enter bootloader mode :S I am pressing record+reset and it just resets the device :S :S
Plz help...
O2xdaaus
Thank you once again for your eforts. Do you plan to release the 2G version for the Dialpad that some many seem to like?
O2xdaaus
Plz help...
Try Pressing record + reset , keep record pressed and release reset and it should work now. Works for me.
vutuantu1990
Rồi , hoá ra ko vào được Net là do mạng Vina "làm nũng".
Opera 9.5 vào được tốt.Chân thành cảm ơn bác MinhMan.
Tiện cho em hỏi bác là làm thế nào để xoá hay cho cái WkTask Setting nó ko chạy mỗi khi SoftReset được ko , cái này em ko thích lắm .
Thân.
