biteSMS v6.1 [bài 244] - Ứng dụng nhắn tin số 1 trên iPhone
langtuvn7
sao e cài mà lúc tin nhắn đến nó kô hiện ra ngoài màn hình các bác nhỉ ???
m0nk3y86
ko hỉu sao bản 4.94 ở đây cài bằng PCsuite nhg ko hiện lên, pó tay.
AquaSta
Đã có biteSMS 4.95 rồi các Bác ơi :)
Có thì có cũng trial thôi, bao giờ có cr@ck thì anh em báo đi. Chương trình này đâu phải ai cũng cr@ck được, modul protection của nó tốt lắm đấy
m0nk3y86
BiteSMS 4.95 - Ngày càng hoàn thiện hơn
Bite 4.95 nhạy hơn, fix vài điểm không quá quan trọng như thêm Backspace to "To:" trong mục Quick Compose,... (chưa nghiên cứu thêm :D)
DESCRIPTION:
You love your iPhone as much as we do? You text all the time? Want more features? Then biteSMS is for you, with lots of extra features like Smileys, Quick Reply, Quick Compose / Quick Call, Privacy, a Character / SMS Counter and much more! You can use biteSMS as a replacement to the built-in Messaging application, and send messages via your mobile carrier as you normally do. Or, if your mobile carrier charges a lot for sending SMS messages (say texting to overseas), you can buy credits and send them via the biteSMS network instead, which can be much cheaper.
CHANGELOG:
v 4.95 - July 8, 2010
* Fixed all known issues with Drafts and Backgrounder consistencies in conversation list and conversations.
* A nice NEW feature for all those users who have been so patient with the iOS 4 bugs. You can now backspace in Quick Compose to quickly get back to the "To:" field. Makes it much easier to change the recipient name. Settings->Quick Compose->Backspace to "To:" default OFF.
* Fixed Quick Reply issue when there was more than 3 lines of text in landscape mode.
* Cursor no longer disappears in Quick Compose.
* There is no longer any "cannot use Keyboard" delay when Quick Compose is invoked. So now it’s quicker to use.
* Fixed issue, whereby you could touch the "Contact Name" area on Quick Reply and it would incorrectly dismiss the alert.
* Fixed a number of issues with signatures containing special characters, like smileys or brackets.
* Fixed issue where biteSMS Passcode (if set) did not always appear if you opened the native Messaging app.
* Fixed issue where [Open] in Quick Compose and Quick Reply and Contacts (etc) did not prompt for biteSMS Passcode (if set).
* For incoming MMS messages the badge is now correctly shown on the biteSMS icon not the native Messaging one.
The above fixes are all for iOS 4 issues. The only change for iOS 3 is a fix whereby the Quick List icon did not always function correctly for a limited number of users.
Download (trả lời bài viết để xem link, ấn F5 hoặc refresh sau khi trả lời)
Dành cho iOS 4 và OS 3.x
MultiUpload:
[HIDE]http://www.multiupload.com/LFWRGRVKOT[/HIDE]
MediaFire: [HIDE]http://www.mediafire.com/?yznrnyoyzmm[/HIDE]
(theo xSellize)
ntpminh_82
Mình thử dùng bản 4.94 và 4.95 đều bị thoát khỏi chương trình khi tới đoạn Sending (dù tin nhắn vẫn gửi được) là sao ta?
Có ai bị vậy ko ạ?
m0nk3y86
Có ai bị vậy ko ạ?
Chuẩn luôn, mún ko bị nt thì chỉ dùng bản 4.93 trở xuống, còn 2 bản kia đều bị như vậy. Ko hỉu đó là dụng ý của tác giả hay do lỗi khi *****
chính xác. mình cũng bị tương tự.chưa thử bản 4.93.để thử xem sao
kren
Từ ngày lên 4.0 đến nay mình cài BiteSMS chưa bao giờ chạy cả, bản này kg biết thế nào đây?.........
Bản này củng kg chạy luôn, nhờ các cao thủ chỉ dùm tôi với, từ khi lên 4.0 đến nay 3 soft kg bao giờ chạy được trên con 3gs của tôi là: xGPS, BiteSMS(cả iReaSMS), Vietnam 2.0, trong khi các bác chạy được kg hiểu vì sao (?)
AquaSta
Có ai bị vậy ko ạ?
Ai dùng iOS 4 thì không nên dùng bản 4.94, 4.95 vì sẽ hay bị đẩy ra khi gửi tin nhắn, bạn sang link bài bản 4.94 mình post có cả link 4.93 đó
