RamStat v1.0 Widget shows Ram State + Homescreen widget N97
Description: RamStat is a widget, which simply shows Ram States. It shows:
Full Amount of Ram
Used Amount of Ram
Free Amount of Ram
You could also use it as a Homescreen Widget For N97
This widget was created with the help of DeviceInfo v2.0 Widget.
