Edit by S90
Icons: replacement
system and third
-party systems and third
-party (decently) amended version
(type in the menu backgrounds, programs for the curtain, bottom bar on stol, added / ordered folder icons, added some minor and major icons to third-
party software)
Made by Theme Makers
Alliance. TMA - Only genuine
themes! Theme has no
analogues on Symbian. This is
a high quality product
designed and tested by professionals.
iVertigo a vertiginous blend of
style, which is built on an
elegant combination of
elements. Just try it, you'll love
it! In the theme has all the
standard icons, of which there
-HD Island is my new theme
for Belle, Anna and Symbian'3 mobiles
-With my new Anna Boss Icons
Pack
-Added more then 800 TPI .All elements are Default only icons and wallpaper is changed
-Lite and easy to use on your mobile
Author of the source code: IND190
Modification: S90
Compatibility: Belle FP2 (FP1/Refresh)
Icon: the replacement of the standard and many third-party
The amended version. Added icons to third-party programs (140sht), system (secondary) icons,
small changes in the backgrounds and text colors / icons tidied folder icons, replaced the progress bar waiting (there was a small defect).
Test for N603belleFP2 - perfect. Who should be taken away.
