chichung781988
Mới lang thang qua bên forum pnht thấy có cái này mới, copy về cho anh em coi...Bác nào giỏi Cook làm cho anh em bản tiếng Việt...Và mod thêm 1 số thứ cần...
Sorry mình kém tiếng Anh nên kô dịch đc, bác nào cần thì xài google đỡ vậy
Thêm link cho các bạn down load
The new update has arrived and with it all the bugs fixed. Version 6.1 has many improvements in performance and appearance changes, but as we know you want to know the changes, here they are:
NEW FEATURES
New effects in the Symbian original interface ^ 3
Ovi Maps 6.3 built-Final (Except 5530)
15.2 music player with built-lyrics (Solution for Latin languages)
Ovi updated v1.09.
Fullset ^ 3 Symbian icons that change according to the theme you set.
Compatible with Ovi Suite 3.
Text of the menu buttons centered as in Symbian ^ 3
New Extended menu, wider!
Greater speed in the movement and application performance
Removed rotation sliding unlock
Fixed error when installing some old songs
Compatible with PhotoBrowser
The battery back to normal ... life improved
Features
Interactive desktop with Widgets
Languages: English and Spanish Latino (5230 5530 5800) and Spanish Spain (X6 5800)
You can install anything you want without signing applications, or perform any process
Never again you will get a certificate expired error!
Integrated mail client with HTML support and compatible with your Hotmail, Gmail, Ovi, etc.
Release system by swiping your finger across the screen.
New font much more modern and fitted with the new menu, the original source is huge !!!!!!!!
4x4 menu reorganized and custom folders
Added 3 new widgets shortcuts so you can get full screen access.
79 MB free internal memory (290 MB free X6) and 58 MB free RAM
Clock Widget is now removable so you can remove it and have a Full Swipe
Removed the poster to show all applications running on the drop down menus
Java applications and bring all permits WRT enabled to avoid so many unnecessary requests
You can send any file protected by Bluetooth, no more restrictions
Added new audio codecs for stereo sound better
Sound a lot stronger than the original firmware
Embedded applications Ovi maps, Conversations, Notifications.
In the Ovi mobile is identified as a Nokia N97 so have many more programs compatible
Improved effects and without delay
Facebook added tactile equipment browser bookmarks
Gallery reconfigured to not read images in system folders
Dark S60 startup image and sound a bit low not to disturb
Removed some startup applications to have more free resources.
Browser Cache grown and moved to E
VERSION
FIRM BASE
WHO CAN USE THE
SYMBIAN ^ 3 v6
NOKIA 5230 RM-594
Only v21.8.005 RM-594 with the same firmware version
SYMBIAN ^ 3 v6
NOKIA 5530 RM-504
5530 v32.0.007 all regardless of version
SYMBIAN ^ 3 v6
NOKIA 5800
RM-356
All 5800 v52.0.007 RM-428 whether or RM-356 no matter which version
SYMBIAN ^ 3 v6
NOKIA RM-559 X6
All 31.0.004 RM-559 X6
The RM-551 with versions less than or equal to v30
FREQUENTLY ASKED QUESTIONS
How do I install?
Here we explain step by step tutorial with pictures and even video anti Dummies:
INSTALL A MODIFIED IN YOUR NOKIA FIRMWARE
WHAT HAPPENS IF I CHANGE RM?
The MR differ only in the languages of each mobile and firmware RM-428 is originally American English language, Spanish, Latin, Portuguese Brazil and others, while the RM-356 is British English, Spanish, Spain, Portugal and Portuguese; so if you change your RM only change the languages available and before you ask, YES ... your 3G will work as usual.
RM CHANGE HOW?
You need not do anything before, just flash when you select in the JAF MRI are going to call, say if you have a Nokia 5800 RM-428 to install this firmware you must select the RM-356 flash when the JAF and that's all.
CAN I GO BACK TO MY ORIGINAL RM?
Yes, you can simply re-flashing with the same version you have but it is for your MRI, what happens is that Nokia has abandoned the RM in the Americas and is only getting updates for Europe, and across all the major advances in CFW RM only leave for European
so think twice before returning to your RM American, we do not recommend!.
LOVE ME IF I CAN NOT RETURN TO ORIGINAL OR PUT ANOTHER FIRM CFW?
Yes, you can always put another CFW that is based on the same version of firmware that CFW. Likewise, you can return to the original version in the same versions.
"ALWAYS APPLICATIONS ARE COMPATIBLE WITH THIS CFW?
Of course, if all your applications are compatible, but we recommend that henceforth seek applications for the N97 or the C6 and some bring the plugin to put a widget on the desktop, down on the extras will leave you some. The themes are also compatible but do not bring the oldest mark button so we recommend you install themes designed for the N97 or search for the newest ... We put a new theme every weekend!
CLARIFICATIONS
Before writing that there is an error, please check before you formatted flash external memory and I did a Hard reset (* # 7370 #) to your mobile, 99% of problems are solved that way.
Nokia Messaging: Does not support, we will delete all Nokia components Messaging and still is not compatible ... continue working on it.
Activating effects: Settings> Themes> General> Options> Theme Effects / Activate
Support Contacts: If you make a backup with the Ovi suite will have problems, so the process to follow to keep all your phone numbers is:
From your phone go to your address book, press Options, where it says you give DIAL-> Mark all. Then press Options again and give in the BUSINESS CARD COPY -> In another report, choose your external memory and ready.
When you've got your Symbian phone with our CFW ^ 3 v6 installed so you just go to your address book again press Options, then BUSINESS CARD -> On the other memory and select your external memory. This method is not only much easier and faster but it also is much more complete because all pictures are saved contact and everything is done from the same phone.
Enable Rotation: Settings - Phone - Conf sensor - control activation - Auto Rotate Screen
Stamps: The stamps you put on your external memory in the folder E: / Sounds / Digital
Updates: Updates are already built, please understand that not need to reinstall them.
Sound camera: Camera> Options> Settings> Capture tone> Camera 4
ADVISED BY THE COMMUNITY BUGS
PROBLEM SOLUTION
No green light on the Nokia 5530 We are awaiting confirmation and if a bug is corrected the download package throughout the week. As reported also solved by just changing the subject ...
In the 5800 Latino, not an option to reset the phone That was an oversight on our part and although the text appears, if the integrated function but so correct over the week.
links
http://shareflare.net/download/14405.19959d40cbee4bc91f4814774445/CFW_Symbian_3_v6.1_Nokia_X6.rar.html
http://shareflare.net/download/82529.81bbc6f0a79047786564fccda0a8/CFW_Symbian_3_v6.1_Nokia_5800_RM-356.rar.html
http://shareflare.net/download/89887.86b70e33f22248843caf8b05665b/CFW_Symbian_3_v6.1_Nokia_5800_Latino.rar.html
http://shareflare.net/download/43701.40ac26c32a7b4b415c4fb59e376d/CFW_Symbian_3_v6.1_Nokia_5530.rar.html
http://shareflare.net/download/32959.34aec3369b3be6e2613c2e6817c1/CFW_Symbian_3_v6.1_Nokia_5230.rar.html
CFW SYMBIAN^3 v6 Nokia 5230 [URL="http://www.multiupload.com/TSY4WRSU09"]http://www.multiupload.com/TSY4WRSU09[/URL]
CFW SYMBIAN^3 v6 Nokia 5530 [URL="http://www.multiupload.com/38QSABPL7W"]http://www.multiupload.com/38QSABPL7W[/URL]
CFW SYMBIAN^3 v6 Nokia 5800 RM-428 (poner 356 en el JAF) [URL="http://www.multiupload.com/85HKMRKKBM"]http://www.multiupload.com/85HKMRKKBM[/URL]
CFW SYMBIAN^3 v6 Nokia 5800 RM-356 [URL="http://www.multiupload.com/NWSO563EFH"]http://www.multiupload.com/NWSO563EFH[/URL]
CFW SYMBIAN^3 v6 Nokia X6 (poner 559 en el JAF) [URL="http://www.multiupload.com/VF8BJYCZZW"]http://www.multiupload.com/VF8BJYCZZW[/URL]
