q630666
Mới Tìm đc cái này a e nào có thời gian thì test nhé
Mình đã test rồi.Theo mình là chuẩn không cần chỉnh.Cảm ứng chuẩn.Tốc độ tốt.Nghe nhac xem ảnh bình thường.Ram lúc boot là 41M khi mình đã cài thêm bàn phím ảo(Cái này tốn ram)
--Đặc biệt là chưa có tiếng việt.Chờ các pro add hộ tiếng việt vào với
Many thanks to CONII, LPHS, PNHT, Rawand Kurdy, ishandigipunk, Upakul, liliantungary, pirates_killer, PrinceRM-786 and anyone else who has contributed feedback or suggestions and those who have offered ideas for mods and fixes on the forum.
Welcome to The C6-X6 Remix!
C6-X6 REMIX INFO:
C6-X6 REMIX INFO:
The C6-X6 Remix features a fully operational widget homescreen which can be customized to suit your needs. You can control the Music Player directly from the homescreen, check the latest weather report for your region (requires AccuWeather widget). You can start your favourite apps and check calendar entries. If you don't want to do any of that, then simply add new widgets and shortcuts. The choice is yours! The homescreen supports rotation which adds a whole new dimension to your X6.
Other features include innovative media applications such as the Gallery, Music Player and the Videos and TV app. Plus Active Notes, Drawing, E-mail, Message Reader and Zip Manager applications.
This C6-X6 port is a must for any X6 user!
MODS & HACKS:
\private\
100059C9 : Custom Folder Creation (scriptinit.txt)
100069CC : Bluetooth Name. Set to 'X6 Remix'
10202D56 : Heap Size Mod (sbeconfig.xml)
10282F06 : Disabled Widget security notifications
200113DD : Custom Menu. Organised folders into alphabetical order plus renamed and moved some apps. I have also included many apps in the xml configuration file which are not installed with the CFW. This way, when the apps are installed, they go where I want them to go and some are renamed. So, if you install an app and can't find it in the default folder, have a look in the other folders
Due to the way the phone handles widget installations, you may find that some widgets you install get named and/or moved incorrectly. With .sis/.sisx files, the app has a permanent uid which the phone recognizes but with widgets, the apps are assigned a name based on the order they are installed i.e; 2000DAD2, 2000DAD3, 2000DAD4, 2000DAD5 etc etc. The widgets I install may be different from the widgets you install so you may notice some problems. To overcome this, you will need to edit the matrixmenudata.xml file in the \private\200113DD\ folder. If you do not know what to do, let me know and I will try to help
\private\10202be9\
101F87A3 : Voice Recorder. Increased quality and recording time. Set the default save location to the Mass Memory
101F87EB : Messaging Settings. Added Conversation App to messaging menu and increased number of messages in sent items to 500
101F87EF : No request for SMS receipt. Enabled full character support
101F876F : Default theme (Dark)
101F877C : Idle settings
101F978F : UPnP settings
101F8557 : Browser Cache to E Drive
101F8763 : Startup Configuration
101F8798 : Edited profile settings
101F8831 : Enabled call summary
101F8847 : Menu Mod. Unhid some items to move to Tools folder
101F9775 : RAM Cache to C Drive
101FFCD2 : Music Player Harvest Folders. Set to 'E:\Music'
10008D39 : Browser environment
10200C8C : Set light timeout to 30 seconds
10204DAB : File Transfers Folder. Set to 'E:\File Transfers'
10208A43 : Camera RAM Release
10282DF0 : Sensors Mod
10282F0F : Rotation Speed
102072C4 : FOTA settings
102072C6 : FOTA Disk Reserve set to 0
102818E8 : Theme settings
102828AC : Gallery Harvest Folders
200009FE : Gallery Harvest Folders (C6 Specific). This should restrict the image and video gallery to harvest files which are stored in their default image and video locations. If you want to hide content, keep it in E:\Personal (other locations are restricted too...feel free to ask for the complete list).
102828B1 : Call Volume
102858F2 : Concerns apps
10275102 : Homescreen shortcuts
10281872 : Video Settings
10283344 : CPU Mod/UI Acceleration. Set fps to 30 and CPU to 75%
200159ED : Application orientation settings
20021192 : Kinetic Scrolling Optimized
Improved caching (1MB on C: & 4MB on E
Java app permissions for installed apps set to 'Always allowed'
Removed default browser bookmark folders and their contents (Download Applications, Download Games, Download Themes etc and their contents)
Disabled Nokia SMS on first start
Predictive text enabled by default
RomPatcher set to autostart
InstallServer patch
Changed Software Version details *#0000#
N8 style icons
Customized effects package. Effects are on by default
I have removed non-English language files. Integrating your own is possible with the PNHT language packs.
INTEGRATED APPLICATIONS
AutoInstaller v1.2.0
BatchUninstall v2.0
BT Switch v1.0
Egg Timer v1.0
File Browser v4.5.2
KillMe v1.36
Nokia Music Player Update v15.02.1034
Nokia Web Browser v7.2.6
Ovi Contacts v1.50.12
Ovi Maps v3.06
ROM Patcher+ v2.3
Vivaz Conversation
WinRAR v1.01
AUTOINSTALLER APPLICATIONS (E:\THINKCHANGE\C):
Accel Switch v1.00
Jbak TaskMan v1.41
Nokia Internet Radio v2.00
Ovi Store v1.8.206
PhoNetInfo v2.9.0
Photo Browser v0.9.5
ScreenSnap v3.00
Widgetizer v1.04
YouTube v1.00.2
INTEGRATED GAMES:
Bounce v1.0
Marble Maze v1.80
SkyForce Reloaded v1.07
Spore v4.30.61
THEMES
Dark (Default)
Blue
Light
Nokia Theme White
Red
The following themes are included in the core file. Please bear in mind that switching to them will cause the homescreen to render incorrectly:
Circles
Light Vision Grey
Orbits Grey
Pieces
Stripes Grey
Dowload
C6-X6 ROFS2:
http://www.mediafire.com/?r5h6429hcod8kbu
C6-X6 Core:
http://www.mediafire.com/?a3bc360d3lrqswa
CHụp màn hình
![02homescreenlandscape.jpg](http://img816.imageshack.us/img816/1628/02homescreenlandscape.jpg)
![01homescreen.jpg](http://img814.imageshack.us/img814/6019/01homescreen.jpg)
![03menu.jpg](http://img688.imageshack.us/img688/8938/03menu.jpg)
![04apps1.jpg](http://img827.imageshack.us/img827/8101/04apps1.jpg)
![09messaging.jpg](http://img560.imageshack.us/img560/9281/09messaging.jpg)
![17musicplayer.jpg](http://img411.imageshack.us/img411/736/17musicplayer.jpg)
![21softwareversion.jpg](http://img585.imageshack.us/img585/2756/21softwareversion.jpg)
Thêm 1 ít dịch từ Gu gồ
HƯỚNG DẪN
Bạn sẽ cần phải tải về C6-X6 của tôi ROFS2 và Core C6-X6. Sau khi tải về, lưu chúng vào một thư mục trên máy tính để bàn của bạn. Sau đó tải về quốc gia của bạn / biến thể mã sản phẩm với NaviFirm để:
C: \ Program Files \ Nokia \ Phoenix \ Products \ RM-559 \
Xóa hoặc di chuyển các tập tin ảnh rofs3 vì điều này sẽ không cần thiết.
Hãy ghi nhớ tên file chính xác của tập tin rofs2 của bạn sẽ biến thể. Bạn cần phải đổi tên của tôi rofs2 để nó phù hợp biến thể của bạn rofs2. Theo thủ tục này với các tập tin Uda (nếu cần thiết).
Sau đó di chuyển các lõi C6-X6, và các tập tin rofs2 Uda để:
Nếu bạn đổi tên các tập tin một cách chính xác, bạn sẽ được nhắc nhở để ghi đè lên ba tập tin. Đó là một ý tưởng tốt để sao lưu các tập tin firmware gốc chỉ trong trường hợp bạn có thể cần đến chúng lại.
Bạn đã sẵn sàng để flash!
Tôi đã sử dụng JAF khi cài đặt CFW này. Có nhiều phương pháp khác mà một số người sử dụng nhưng tôi khuyên bạn nên JAF. Nếu bạn không chắc chắn của quá trình nhấp nháy, hãy xem các chủ đề sau đây:
http://forum.dailymobile.se/index.php?topic=24990.0
Sau khi nhấp nháy, thực hiện reset cứng * # 7370 # sau đó chạy AutoInstaller để cài đặt các ứng dụng bổ sung.
