congtutrensan_9x
CFw N97mini,C6 Repack : Customs, WP7 litte, WP7, WP8, Belle little, Belle Extended For 5800 XpressMusic by Huy Nghiã. Bản update 08 (22-10-2012)
Thông tin
Theo cảm nhận riêng bản này quá..... rùa rùa. =)) =))
Ước mơ sẽ bằng OFW ram in background 68Mb.
Chú ý :
+ Bản Custom không tích hợp minicmd anh em trước khi flash phải xóa các tàn dư trên thẻ nhớ
+ Bản Belle litte có minicmd bạn có thể setup wp7,wp8 hay belle full như hướng dẫn ở dưới
Link for 5800 RM-356 Belle litte.
Link download pass: huynghia Update fix 25-10-2012 Vs Update MOD
Link for X6 RM-559 Belle litte.
Link for 5800 RM-356 Custom™.
Link download pass: huynghia Update fix 23-10-2012
CFw N97mini,C6 Repack : Customs, WP7 litte, WP7, WP8, Belle little, Belle Extended For 5800 XpressMusic by Huy Nghiã. Bản update 07
You can choosen six styles : Customs™ , WP7 little, Wp7, WP8, Belle little, Belle Extended.
Update WP7 litte Tốc độ rùa rùa. Ai đua không? =))
Thông tin
+ FPS Maximum 40FPS Update 19-10-2012
+ New Effects 19-10-2012
+ Mod ép xung 600mhz
+ MiniCMD V2
+ Disable Text copied to clipboard + Actives Open Apps
+ Equilizer add Dolby Performance Audio Porting Dolby Sound
+ Mod Codec Audio Nokia 808
+ Open and Close Apps Speed N8
+ Remove Totality Voice Go To Music
+ Cache Increase Mod
+ Cache Drive Change Mod
+ Heap Size Mod
Xem ảnh WP7 litte
Custom version™
Thông tin
+ Tăng Cpu vs FPS Maximum
+ Mod ép xung 800mhz
+ Mod KillMe new
+ MiniCMD V2
+ Mod tap to lock new
+ 6 Six Shortucts Transparent For Mod Clock s^3
+ Disable Text copied to clipboard + Hidden Open Apps
+ Mod Codec Audio Nokia 808 For Nokia S-1 Porting V2
+ Music Player Symbian Belle For c6 Porting
+ New Charging Light Mod update
+ New S^3 Clock Move on HS - Change Wallpaper Hs Option + Widget S^3
+ No Voice Update
+ Remove Totality Voice Go To Music Store
+ Report Menu HeadPhones
+ Time Zone Update For Cfw
+ Heap Size Mod
+ N8 landscape Fix
Thêm tất cả ứng dụng cần thiết
+ Python
+ Virtua keyboard
+ Smart light
+ Phone touch lighting
+ Music key
+ Easy keylock
+ Youtube
+ Netswitch
+ Btswitch
+ Google Maps
+ OVi Maps 3.06
+ Nokia browser 7.3.1.33
+ Game Racing thunder
+ Minicmd v2
Xem ảnh Custom™
Link Background Custom
Link download pass: huynghia Update 09-10
Link for 5800 RM-356 Belle little.
Link download pass: huynghia Update 10-10-2012
Link for 5800 RM-356 WP7 litte
Link download pass: huynghia Update 19-10-2012
Hướng dẫn cài đặt:
Để setup các Version ở dưới bạn cần flash bản Belle litte hoặc WP7 litte
Xem ảnh Belle Full :
Hướng dẫn cài Belle Full:
Tải về Setup Belle Full
+ Cần tải setup ở trên giải nén vào thẻ nhớ ( ta sẽ có là E:\setup\* )
+ Sau khi flash đợi máy ổn định, Chạy xong minicmd và đã khởi động lại.
+ Tiếp theo ta copy file minicmd.txt trong thư mục setup cho vào C:\data\*.
+ Vào ứng dụng bật minicmd để chương trình tiến hành cài Belle Full.
Xem ảnh WP7 :
Hướng dẫn cài WP7:
Tải về Setup WP7
+ Vào ứng dụng bật minicmd để chương trình tiến hành cài WP7.
Xem ảnh WP8 :
Hướng dẫn cài WP8™:
Tải về Setup WP8
+ Vào ứng dụng bật minicmd để chương trình tiến hành cài WP8™.
BONUS
Link for 5800 RM-356 OFW
Thông tin
Port WP7 little to FW different ( 523x, 5250, 5530, X6...)
Hướng dẫn cách Port FW :
Ví dụ ở đây mình lấy FW 5800 V60.0.003 port cho FW 523x V50.1.001
Bước 1:
- Dùng NFE (bản nào cũng được) bung ROFS2 của bản FW 5800 V60.0.003 ra.
- Copy toàn bộ các folder data,private,resource,sys,system trong đó ra 1 folder bất kỳ (mình thường để ngoài Desktop PC).
Bước 2:
- Bung NFE ra một thư mục khác
- Dùng NFE này bung ROFS2 của bản FW 523x V50.1.001 ra.
- Trên trình NFE -> Xoá toàn bộ các folder toàn bộ các folder data,private,resource,sys,system trong đó đi.
Bước 3:
- Copy toàn bộ dữ liệu khi nãy lấy được (từ ROFS2 của FW 5800 V60.0.003) vào ROFS2 của FW 523x V50.1.001 đang bung ra này.
- Giữ nguyên những gì còn lại.
- Repack được file ROFS2 của FW 523x V50.1.001 và Flash thôi!
• Core FOR 5800 RM-356 edit by me. ^^!~ Update 09-10-2012
Chú Ý :
+ Sau khi flash vào mục ứng dụng bật minicmd2 lên nhấp ok cho đến hết sau đó khởi động lại máy.
+ Mặc định khởi động là tiếng Anh. Một số mod S^3 chỉ hoạt động trên nền tiếng Anh.
• Creating and edit by Huy Nghiã (Congtutrensan_9x PDAviet )
• +Liên hệ YH : yeuem_saothatkho_why ( Có hỏi gì cứ PM tớ sẽ reply )
• +Phone : 01656767175 ( Ai muốn hỏi thì nhắn tin trước xong hãng gọi nhé .tks )
Thông tin
+ Edit Lower Consumption Battery And Optimal System Configurations
+ Edit startter
+ Lock Unlock Mod
+ Heap Size Mod
+ BlazingFastScreenRotation
+ Default Video Capturing FPS increase Mod
+ Mod N8 Swipe to unlock (Unlock-Red + Answer-Green)
+ More Ram For Apps
+ Turn OFF Key Light
+ Stop all apps in background
+ Mod auto update time ON
+ Disable Text copied to clipboard + Hide Open Apps
+ Delete MiniQwerty
+ Effects new
+ Edit startter
+ Lock Unlock Mod
+ Heap Size Mod
+ More Ram For Apps
+ Delete MiniQwerty
+ Effects new
Chú ý :
Thông tin
+ MiniCMD V2
+ Heap Size Mod
Custom version™
Thông tin
+ Mod KillMe new
+ MiniCMD V2
+ No Voice Update
+ Heap Size Mod
+ N8 landscape Fix
+ Python
+ Virtua keyboard
+ Smart light
+ Music key
+ Easy keylock
+ Youtube
+ Netswitch
+ Btswitch
+ Google Maps
+ OVi Maps 3.06
+ Minicmd v2
Hướng dẫn cài đặt:
Xem ảnh WP7 :
Tải về Setup WP7
Xem ảnh WP8 :
Hướng dẫn cài WP8™:
Tải về Setup WP8
BONUS
Thông tin
- Ram siêu trâu : + Khởi động 75mb. Ram ổn định 68 ~ 70mb
- Ép xung 800mhz
- FPS maximum 39
- Pin gốc 5800
- Hiệu ứng Effects new 19-10-2012
- 5 hom screen
- Themes WP7
- Ring tone Lumia remix
- Đọc nhạc tại E:/sounds
- Không quét ảnh tại E:/hidden
- Mod belle đang hoàn thiện nên có một số kí tự lạ
- Coming soon fix..
- Ép xung 800mhz
- FPS maximum 39
- Pin gốc 5800
- 5 hom screen
- Themes WP7
- Coming soon fix..
Bước 1:
Bước 2:
Bước 3:
Chú Ý :
