kkkkk skyscape 2.0
kkkkk skyscape 2.0 for ppc & palm
Mới tìm thấy trên mạng chưa kịp dịch, các bạn tham khảo bằng tiếng anh nhé
How to use sky scape key gen (4 both palm & Pocket PC)
PALM
Q: why 2 keys?
A: coz the old books still need the old key and the new books needs the new key,
Q: How do I know which key to use?
A: books from skyscape new release section needs the new key, other than that use the old key.
Q: I down loaded the key then what?
A: Go to skyscape
choose the book u wanna ad to ur Palm
sign in
download the book
when u finish double click on it
a wizard will start
when it asks u what do want; choose the trial
next, tell u reach the place where u c ur email and pass next then cancel
Q: OK, did that, whats next?
A: go to ur drive C:/ on ur PC
u'll find a folder with the name skyscape
open it
u'll find the book u downloaded file in it
open it
then u'll find a single file named with numbers
open it
u'll find a file with the name palm install files
open it
ex. for the book merk manual
C:\Skyscape\Merck_Manual\10.2.3\Palm Install Files
open ur palm Quick install
choose from the file THOSE ONLY WITH THE BOOKS NAME
NEVER CHOOSE A SMART LIBRARY
drag what u choose to ur SD
hotsynch
Q: so now i have the skyscape book @ my device?
A: nop! u won't be able to open it tell u download the
smart library files
open it, drag all the file to ur PALM RAM, i.e. MAIN MEMORY not SD CARD
hotsynch again
now u can open ur skyscape book
Q: is it cracked?
A: not yet!
go to the keygen
it a new book then key 2, if old key 1.5
for 1.5 key check the box next to the old algorithm then write ur ID
this is the ID u'll find when u open the book on ur device u'll see it when it tells u its a trial version
then go to select a file
go to this location again
select the palm application file
i.e it will be the only different one (has different icon than the others) which has the books name
hit generate
u'll pass will appear in front of u!
BE CAREFUL WITH THE Os AND ZEROS THEY LOOK ALIKE
Q: is this the same way 4 the new key 2?
A: no, it's slightly different,
in key 2 DON'T CHECK THE OLD ALGORITHM BOX
and when u select a file choose a palm application file i.e the ones with the similar icon
just select one of them
some times all of them generate the same pass some times each one generate a different one so keep trying tell u get ur key.
Q: my palm resets when i hotsynch the smart library files is this normal?
A: yep, its totally normal, not all of palms resets but if it did, its completely normal.
Q: when i crack the skyscape book, when i try to open it again it asks again for the pass word, what shall i do?
A: hotsynch the smart library files again before entering the key again.
Q:can i update the book after a while?
A: unfortunately u can't! what i usually do is that i remove the book or just download it again from skyscape!
Q: i have a nagging msg that keeps appearing every time i open the book, it says that i installed an update and it has finishes since ... , how i make it disappear?
A: simply the smart library files hot synch again!
thats it for palm
POCKET PC TUTORIAL
hello all it me again, sorry 4 the delay but u know how it could be when ur Dr. stuff u with work
lets start with our Pocket PC tutorial
Q: is the skyscape key gen the same for Palm and Pocket PC?
A: nop, it ain't the same at all!
Q: how to use it then?
A: first of all download it from here
skyscape keygen
active synch it to ur device
then go to skyscape website
register with an email adress and a password for free
choose the book that u need to download.
of coarse ur gonna choose the trial or test drive version
Q: done that, whats next?
A: its pretty simple after word, when u finish downloading
double click the book icon where ever u saved it
click next and follow instructions,
when it comes to trial or complete choose the trial one
complete the process
ur device will display a msg that if u trust the application to be downloaded press ok
Q: so r we done here?
A: just a simple step left
open the book u downloaded
u will find an ID number, write it down
go to the key u hotsynched on ur device
open it
write the ID u just wrote down
and click start
and tataaaaa ur books will always be open any time u download a book from skyscape
just download it and it will open by it self
