ETEN (Glofiish) X500 WM6.1 V12 & V14 - Core 20721 & 20748 (DIAMOND)
Sublogic
v14 bug!
There is a bug in the v14 ROM.
When a SMS is received and you open it to reply, the keyboard (standard keyboard) opens and then just closes/minimises straight away.
The only way to get it to open is to actually click the keyboard icon at the bottom of the screen.
Also ì you use SPB Full Screen Keyboard, the text you enter does not appear after closing the keyboard.
This does not happen in version 12. I have tried reinstalling the v14 ROM again and it still happens.
Just letting you know. In the meantime, back to version 12 for me.
Thanks for your hard work.
KeinEngel
This is the first ROM for X500 that doesn't require me to shout in order to be heard by the ones I'm talking to, but, as someone said earlier, a light ROM would be AWESOME!
Is it possible to make a clean ROM and add the HTC Home and smart scroll as CABs? Or should I just go ahead and download the old v01, which seems clean?
phamhuu2007
Sao mình uproom cho X500 của mình nó chạy tới bước la download WM 5 gi gi rồi trên PPC mình báo "error" đầy màn hình luôn! Lỗi gì vậy các bro!
thanhgia123
Bạn thử uprom bằng thẻ nhớ xem sao. Có mấy cách uprom của bác Quang chỉ đó test cách khác xem khá hơn không.
