Forum for english speaking people
K
kraziii
Guest
NET CF 3.5 OR NET CF 2.0 ,which one is faster?
Thanks a lot ! Is the newer version faster? I doubt that. Please tell me the truth.hehe
K
kraziii
Guest
Thanks ! is there any software that NET CF 2.0 can not support and only running with NET CF 3.5 ?
mohannad18
BA upgrade vi BLUETOOTH Ỏ SD CẢD
CAN UOY PLEASE HELP ME
MY BA ACTIVSYNC IS NOT RECOGNIZED BY THE PC I DONOT KNOW WHY IT IS STILL 2003SE
IS THERE A WAY TO UPGRADE VIA BLUETOOTH Ỏ SD CARD
THANKS
NBLam
I hope they can fix the BT problem... I will just go back to the old rom since this 6.1 version seems to have problem receiving file from BT.8-|
Have you read this? We have replied to your question in another topic:
Go to Settings / Beam and check on Receive all incoming beam. Then things will go well. It's a problem of WM6.1 that we cannot switch the Beam on/off using CommManager if we don't have Receive all incoming beam checked. And you need to switch Beam on before using bluetooth.
Go to the Bluetooth setting and choose "Make this device visible to other devices" in Mode tab. I have no problem with bluetooth.
Enjoy.
Dvha79_ddt
Run BEAM at Connections TAB then check "Receive all incoming beam" and click "On" BEAM on Comm Manager
Good luck
andromede
hi all !!!!
plz can I put her any thing in the forum that I can not anderstand.
and thãn a lot for this initiative
NBLam
hi all !!!!
Yes, anything, but it should be better we focus on PDAViet's ROMs for Blue Angle so that it is not too distracted. Is it ok for you? Anyway, we will try to help with anything :D
andromede
really thnx a lot my friend !!!!=D>:)
excuse me for thí stupid question :mad:) ; what is the languege of our forum pdaviet ??? Im so sorr:-/y for this question my friends !!!
NBLam
Vietnamese, my friend. You can use some online translation sites to read other topics.
Oh my god. All is BLT hức hức......why not fix, cooker?
What do you want, vnanhvn? Do you have problems with bluetooth? If yes, please read some posts above about turning Beam on first before using bluetooth. It's a common problem of WM6.1.
NBLam
So do you mean this is a problem with your GPS? or with BlueTooth? If GPS, I cannot help. Sorry.
Somtop
I think a problem from BlueTooth with Rom 6.1 Because when I flash with rom 6.0 ,I can connect my GPS bt .
