HƯỚNG DẪN CHI TIẾT CÁC BƯỚC UP ROM CHO i780 + LINK
gaugaugau
Flashing Guide To update your i780 (UPDATED 10 OCT ’08)
WHAT YOU NEED:
1) Windows XP SP2 . Mirage does not work with WINDOWS VISTA
2) Samsung ActiveSync 4.5
3) Samsung USB driver
4) MIRAGE UPDATER
5) Russian PUHE1(to flash the EBOOT+PDA+PHONE)
6) Complete ROM V5X
7) 7 zip (software to unzip most of the files you have downloaded)
BEFORE STARTING
1) Check the battery of your telephone! It must be FULL
HOW TO DO IT
(0) Download Mirage Updater, the Samsung USB Driver and ActiveSync 4.5 and install them.
(1) Download the Russian PUHE1
(2) Download the V5X ROM you prefer
(3) Extract the two files downloaded at the point 1 and 2 in the same directory
(4) Switch off your phone and remove the battery, then insert the battery
(5) Connect the telephone to your PC via USB cable
(6) Launch Mirage updater. Select MIRAGE LV image as the profile
(7) Click EBOOT+PDA+PHONE and select the extracted Russian PUHE1 and wait until Mirage recognize the ROM (you will see the log on the left side).
(8) Click on DETECT
(9) Switch on the phone while holding the ENTER and FUNCTION buttons (the green and red on the sides of the finger mouse. As soon as the telephone starts (you will see the red light on the top switching on) immediately release all the buttons.
(10) After the system DETECT your phone a message appears in your I780 screen.
(11) Wait until the image is written. The mirage light on the top will be BLUE and your telephone switch off.
(12) Disconnect the cable and switch-on your phone. Immediately after the first START make a SOFT reset
NOW the first part is done! Let’s start with the second to install ROM V5X
(13) Repeat steps 4-12 but, this time, for step 7 select PDA in Mirage . Choose the ROM V5X and wait until the process is finish. Then, at the first start make a soft reset (again).
IMPORTANT:
1) Always remove the battery before starting a process. Always make a soft reset when finished.
Link:
Samsung USB driver: http://www.internet-tools.co.uk/blog/wp-content/uploads/2008/01/blackjack_modem_driver.zip
Mirage updater: http://rs227tg2.rapidshare.com/files/110283700/dl/Mirage_LV_v1.8.rar
Rom Russia (Rom tạm): http://rs346gc2.rapidshare.com/files/120197435/dl/i780PUHE1.7z
Rom 6.1 version 5X (mới nhất tính đến ngày 10 tháng 10):
V5X 128DPI Standard:
http://www.mediafire.com/?2x5zjft3jj0
* Based on ITA PXIHH5 PDA Rom
* Opera, RSS Feed, Podcasts, MP3 Ringtones, PhotoSlides, Viedo Player & CNN Removed
* SYS Section uses Official WM6.1 Pro 20273 Build from HTC Diamond
* OEM Section uses PXIHH5 100%
* No additional apps or tools included (plain Vanilla)
* Windows Live from PXIHH5 used
* NetCF 3.5
* Selection of multiple messages enabled
* Uses Battery (four bars) and 3G indicators from official Samsung SCH-M40
* Added Samsung Menu Launch from PXIHH5
* Standard Samsung i780 apps retained
* Bluetooth OBEX Fix
* SDKCerts (2) already installed
* Performance & Security tweaks
V5X 128DPI Ultimate:
http://www.mediafire.com/?z5tylzmlemk
* Opera, RSS Feed, Podcasts, MP3 Ringtones, PhotoSlides, Java, Video Player & CNN Removed
* NetCF 3.5
* Opera Mini 4.1 & Esmertec Java (Required)
* Dogmood's Samsung Backlight
* Tweak Cabs for i780
* Adobe Reader LE, Microsoft eBook Reader, Latest Pocket RAR
* TCPMP Core Player with FLV Support, Youtube Play
* Vicott Keyswop ClearTemp 1.1 (updated), Total Commander 2.51 (updated), Modaco NoData, Dotfred PIM Backup, PsShutXP, WM Tool (added new), Synchro Time, PHM Regedit, Pocket Tweak CPL, Zinyee Notif Blinker, HTC Comm Manager, Schap Advanced Config 3.1
V5X 96DPI Ultimate:
http://rapidshare.com/files/152116659/i780_EV5X.96_Ultimate_PXIHH5_PDA.7z.html
Nên chọn bản này vì màn hình được chỉnh về độ phân giải 320x320 sẽ tương thích với hầu hết chương trình chứ ko kén chương trìnn như bản 128dpi (độ phân giải 240 x 240)
* 96DPI Components from Official HTC Kaiser SYS
* NetCF 3.5
Original Unmodded WM6.1 PXIHH5 Italian PDA ROM 128DPI
http://www.mediafire.com/?leyyzknt2z2
* 100% unmodded WM6.1 Build 20270
* Bugs on ringtones and picture viewing fixed
V4X.Uf (Ultimate) FINAL Release
http://www.mediafire.com/?2zzmzmnyznt
* Based on WWE DXHE1 PDA Rom 96DPI
* 96DPI components from HTC Kaiser 19212 Official ROM
* OEM Section uses DXHE1 100%
* NetCF 3.5
* NEW Battery (Percentage) and 3G indicators - Fixed 3G/Wifi icon swap issue
* HTC Home V2 & Black Clock
* Nadavi Modded 3G Dialer
* Vicott Keyswop & ClearTemp, Total Commander 2.51 (updated), Modaco NoData, Dotfred PIM Backup, PsShutXP, WM Tool (added new), Synchro Time, PHM Regedit, Pocket Tweak CPL, Zinyee Notif Blinker, HTC Comm Manager, Schap Advanced Config 3.1
AnhPheCT
Mỗi Rom Bạn cho hình minh họa đi cho A-E dể lựa chọn!!! Xem nó có mới với Rom mình đang dùng ko đã mới Up chứ!!! đưa link ko làm sao dám Up Bạn!!! Thank's!!!
vunguyenonly
hic..hic...em hổng có hiểu...trùi ui làm sao để xài đây,em muốn cất hết mấy cái biểu tượng đi bằng cách nào,em mò hoài hổng thấy phần cài nhạc của tin nhắn...giúp em với
pana734
Sao mình extract 2 file vô một thư mục ở bước số 4, một file thì có đươi là IMG còn file kia có đuôi là BIN. Mình là bước úp bản ROM tiếng NGA thì ok đến khi chạy tiếp lần 2 để úp bản ROM mới thì nó không tìm thấy image của ROM đâu cả. ai biết chỉ giúp với. Giờ đang chạy tiếng NGA (Rom tạm) làm sao quay về tiếng Anh mấy bác
