Taki7610
Unlock_GSM
To connect the phone you should remove accumulator and then connect the cable to the handset
If you need to enter into the LG service menu
type "3845#*6800#" in the number dialing window
To enter the provider hidden menu you need type service password
which is shown in the log
then type service password once more
Usually the service password is 147789
Connecting with LU6800
Firmware Version: LU680128
Bluetooth Address: 70:05:14:17:24:7F
Connected
Receiving phone info
Firmware Released: 19:00:00
Firmware Compiled: 00:33:02
Connect mode: Normal
Meid unlock code 02f7144e0357ffe0
SPC: 000000
MEID: A00000312E2161
Mobile ESN: 80ACF9C6
Phone Number(MDN): 01039976971
min1: 9976971
min2: 063
SSD_A: F473EBC6FBDA9F96
SSD_B: 00FE31BEE86D43EF
AKEY: 00000000000044967056
User Lock Code: 0000
MCC: 450
MNC: 6
Info received
Restoring to factory defaults
Cant switch the mobile phone to download mode
You can make it manually
OMAP User Data Clear Done
AP part has been successfully reseted
If you want to continue work with the handset
you should reconnect it with special buttons pressed
as you did it when you connected the first time
Don't forget to restart the phone
Factory defaults successfully restored
