LINK TẢI ROM CHO TẤT CẢ CÁC DÒNG PPC
SirKojiro
Bản ROM mới cho BA đây là bản R2 của Baniaczek buit trên nền của Helmi
Helmi_BA_WM2k5_AKU3.5_v1.4.CF2 R2 by baniaczek
http://rapidshare.com/files/24716296/Helmi_BA_WM2k5_AKU3.5_v1.4.CF2.R2.rar
http://www.sendspace.com/file/h56wqp
http://www72.megaupload.com/files/a982cdda1d26731146b3f970640ba8ff/Helmi_BA_WM2k5_AKU3%5B1%5D.5_v1.4.CF2.R2.rar
Modifications:
* Fixed mail body/mail attachments errors.
* Default Crossbow theme: Remake.
* Net.CF: Fixed errors. Upgraded to Net.CF2.SP2. Managed V1 libraries (Microsoft.WindowsMobile.Configuration Microsoft.WindowsMobile Microsoft.WindowsMobile.Forms Microsoft.WindowsMobile.PocketOutlook Microsoft.WindowsMobile.Status Microsoft.WindowsMobile.Telephony) imported from WM6 SDK.
* Phone application imported from AKU 3.3 (smartdial still works). Used a bit different phone skin (gray molski.biz). I'll post smartdial gray skin compatible with phone skin.
* SqlCeSe.sys.dll: imported from WM6 ROM. A bit newer version than used in WM5.
* Deleted all predefined favorites. They are not mine favorites.
* Corrected Sim Toolkit.
* Added Windows Mobile Updates for Daylight Saving Time
* Reorganized "Programs" and "Settings". Removed ActiveSync (still available via Comm manager), InternetSharing and ModemLink - available in Settings/Connections. "Backlight" applet moved to "Personal" tab. I think, it is the most often used applet. Removed "Button Lock" - use: Settings/Personal/Buttons/Lock tab instead.
* Modified today items order, date plugin set to single line.
* PIE: some tweaks. Mostly performance tweaks. Cache limited to 10880kB - the rest of RamDisk can be used for storing mails.
* Startup items removed from \Windows\StartUp folder. They are launched from [HKLM\init]. This saves some vital resources.
* MSN (in the ExtRom folder) - slightly modified. Other ExtRom CABs are nearly the same. All CABs are disabled by default. Modify \ExtROM\cfg.txt to suit your needs.
* Modified some graphics (smallest ones imported from WM6) and sounds. Removed fatutil.dll.0409.mui
* COM6 set as GPS intermediate port (look at GPS applet). Don't use COM6 for other purposes unless you undefine that.
Maintenance:
* Remove (by hand) \Windows\StartUp\Camera_Detect.lnk.
Known problems:
* Button SpeakerOn button doesn't work. Press and hold green phone hardware button instead. Probably I'll not fix it in the nearest future.
* Changing themes: After changing theme and reverting back to the default, BaseHue is not restored. I think it is WM5 error (there is somewhere hardcoded default value). To restore: set [HKLM\Software\Microsoft\Color] value BaseHue to b0d57e (hex).
* Net.CF: Resco keygen and some other poorly written applications expects to use Net.CF.2 without any service pack. Ask software vendor.
* Ringtones are not clear. IMO they have to be loud. They are encoded to have files as small as possible.
Tips:
* Turn on WiFi: Do it only once after soft reset. This procedure will load WiFi driver into system drivers. Start Comm Manager. Select from menu: Settings/WLANsettings. Tap "Turn on WLAN". If there are any WiFi networks available - device will try to connect to. Provide proper parameters (network name, authentication, encryption, keys etc). Probably device would not connect. Go back to "Comm Manager". Turn WiFi off. Since that use only Comm Manager to turn WiFi on and off. There is easy way to recognize if it is required to load WiFi driver, or it is enough to turn on. Look at todays wireless plugin. If there is listed WiFi in any state - there is no need to load driver tapping "Turn on WLAN". Resolving this issue is not easy. If you are interested - read this: http://www.teksoftco.com/forum/viewtopic.php?t=194
* COM ports: There are free only COM7 and COM8. COM1 - serial (bottom connector), COM2 - serial_cmd (to send AT commands to the phone) (I'm not sure), COM3 - IrDA, COM4 - BlueTooth, COM5 - BlueTooth DUN, COM6 - GPS intermediate driver, COM7 - free, COM8 - free, COM9 - Virtual COM (virser_data).
* NetCF, WiFi and BT GPS together - WiFiFoFum. Setup: add new bluetooth device. Follow pairing procedure. Check "Serial port" service to use from this device. Select "CommPorts/NewOutgoingPort". Use COM7 or COM8. Goto GPS applet (Settings/Connections/GPS). Select "Hardware" tab. Enter previously selected port COM7 or COM8. Verify "Programs" tab - COM6 should be selected. Ok. Turn on WiFi (see previous tips), turn on BT, start WiFiFoFum. Goto Options/GPS. Select COM6 (the same, as selected in GPS applet in the "Programs" tab). Enjoy.
* Devices randomly wakes up if BlueTooth is on: this is well known issue and nobody is working on it. Look at this: http://forum.xda-developers.com/showthread.php?t=267389 If it is a problem for you, look for something that can lock device after WakeUp. For example: http://forum.xda-developers.com/showthread.php?t=261277
cachep2006
Rom HP iPAQ hx4700 dự phòng khi up rom bị lổi !
HP iPAQ hx4700 Pocket PC Series ROM Update 2003:
ftp://ftp.hp.com/pub/softpaq/sp29501-30000/sp29841.exe
HP iPAQ hx4700 Pocket PC Series ROM Update 2005:
ftp://ftp.hp.com/pub/softpaq/sp33001-33500/sp33318.exe
Thân chào !
cachep2006
ROM Update ACER n300 Version 1.00.15
ftp://ftp.support.acer-euro.com/handheld/n300/osimage/Acer_n300_SD_ROM_WWE_1_00_15.zip
Rom Upgrade for Dead Prophet SPL 2.xx.0001​
Link: http://files.pdamobiz.com/c/Dopod818ProRom_pdamobiz.com.rar
Thân chào !
binhlerhm
ROM mUn_aRTM_10.2.0.8_WWE FOR WIZARD
Rom mUn_aRTM_10.2.0.8_WWE (aRTM=almost Release To Manufacture) được đánh giá 1trong 4 rom hot trên forum.xda-developers
Một số thông tin về rom
1) OS version: 5.2.968 (build 17217.0.0.0)
I transfered wm6 kernel from tytn's rom
2) ROM version: 10.2.0.8_WWE
3) Storage:
Total: 47.46 Mb
Free: 42.99 Mb
RAM
Total: 51.99 Mb
Free: 30 Mb
PP is 4 mb
4) Еxtended rom was moved in windows folder and contains only register fixes. I turned off the installation from real Extrom.
5) It is a vanilla rom. It includes only native soft. There is full customization from HTC:
a) MMS - 3_5_1_17
b) Midlet Manager - 11.1.7.1029
c) WM player codecs - 6.28.061020.X0
d) CYBERON VC&VD - 1_1_B60920 (with voice tag backup function)
e) TaskManager - 1_0_27406_1 - works great for real closing applications, even Commmanager
f) StreamingMedia - 2.10.1025621
g) commManager 8 buttons
6) WPA2&WPA2-PSK
7) New nice skin for default keyboard
8) New icons for backlite, power etc
9) A2DP settings for best qualifity of sound
Links to download:
http://drp.centrmia.gov.ua/WM6/RUU_m..._2_0_8_WWE.exe
http://torrents.ru/forum/viewtopic.php?t=174651
http://rapidshare.com/files/20985850..._2_0_8_WWE.exe
binhlerhm
Rom XPLORE verion 1.1
OS version 5.2.968 (Build 17217.0.0.0)
CommManager 9 Buttons (VoIP Ready)
ArcSoft MMS 3.5.1.22
Intent MIDletManager 11.1.7.1029 (still testing)
Camera version 3.00(Build 25498)
Adobe ReaderLE
Pim Backup 1.3
Voice Speed Dial (reinstalled)
SmartSkey 0.56
Voice Command -removed completly
Added WM5 wmv9 Codecs
-No Extended ROM so this should work for G3 and G4
-Page Pool is 4MB
-Low power consumption (in idle it reaches 30mA)
-Low CPU Usage
line tải rom
http://www.megaupload.com/?d=C6YX74ZI
http://putstuff.putfile.com/64830/4224520
http://putstuff.putfile.com/64921/5988199
http://s23.quicksharing.com/v/3268267/Xplore_1.1.rar.html
