TP.HCM Nokia C2-05 RM-724 Flash Tiếng Việt Ok !
Taki7610
Unlock_GSM
Number of Image Files: 1
Processing Image File :
 rm724__08.79.ppm_v
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Boot Successful...
Unique Data: 0280040784092828
Original Product Code: 059F9X0
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
 Plain RPL saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\355512055410265\355512055410265_32436.rpl
Certificate Block Saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\355512055410265\355512055410265_CERTIFICATE_4FF50F7F.bin
PM Block Saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\355512055410265\355512055410265_PMM_PROT_226D4F33.bin
Security Code: 12345
Data Sections : 01
Current File    : rm724__08.79.ppm_v
Compile Name: package_v.ppm_ebl_psi.fls
Image Type   : PPM Image
Data Size       : 6235544 Bytes
Sending Certificate Block
PPM Certificate Block Sent Successfully...
 Processing Section 01
PPM Erase Block: 0x41B40000~0x4223FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 6232200 bytes
Data Checksum: 170D
Uploading Data Blocks to phone...
Block Write Successful...
PPM Data Blocks uploaded to phone...
Data Verification Successful...
Total Flashing Time (Erase + Flashing) : 00:00:25
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
             Basic Phone Information
MCU Version: V 08.87 17-10-12 RM-724 (c) Nokia
IMEI Plain : 355512055410265
IMEI Spare : A355512055410260
IMEI SV    : 33555120554102617F
Phone Model: K        C2-05
Category   : Entry Phone
Phone Type : RM-724
            Extended Phone Information
Product Serial Number: B41A941BI
Product Code         : 059F9X0
Module Code          : 0204807
Basic Production Code: 059D2P1
Long Production SN   : 0
PPM SW Version       : V 08.79 17-08-12 RM-724 (c) Nokia             V
BT MCM Version       : 19b5-22012
MCU SW Version       : V 08.87 17-10-12 RM-724 (c) Nokia
HW Version           : 2001
RFIC Version         : Dummy RFIC version
LCD Version          : TPO
Content Pack Version : Content: a_dgray_059F9X0 V 08.87 17-10-12 RM-724 (c) Nokia
Bluetooth ID         : F4:F5:A5:96:32:92
CS Type              : GSM900, GSM1800
  ********** SIMLOCK INFO  **********
CONFIG_DATA  : 0010100000000000
PROFILE_BITS : 800000000003000B
ASIC         : 11
PROVIDER     : Default Test Operator
LOCK COUNTERS: KEYPRESS 0/3,  FBUS 0/10
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE             : PA_SL3 (15-digit NCK)
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SECURITY_CODE          : 12345
PHONE_MODE              : TEST
          Dynamic Camera Configuration
DCC ID  : 01022C00
DCC Ver: 003005
Status   : OK
Selected VPL File:
RM724_059F9X0_08.87_038.vpl
Variant Details     : RM-724 EURO A DGRAY LATIN DK
Software Version : 08.87
Product Type       : RM-724
Variant Version    : 038
FACTORY SET TO : Full Factory Set
 OK
FACTORY SET TO : User Data
 OK
FACTORY SET TO : Leave Factory
 OK
FACTORY SET TO : Service Center
 OK
FACTORY SET TO : Software Upgrade
 OK
FACTORY SET TO : Production Tune
 OK
RESET LIFE TIMER TO : 0000:00
 OK
