TP.HCM Nokia C5-06 RM-816 Flash Tiếng Việt ok !
Taki7610
Unlock_GSM
Number of Image Files: 4
Processing Image File :
 RM-816_23.6.015_prd.core.C00
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed    : 650000Hz
Algorithm Sending Speed    : 6500000Hz
Program Sending Speed      : 13000000Hz
Message Reading Speed      : 98000Hz
Number of Blocks :  468
Entry Point:  0x01E2
Page Format : -1
MAX PAGE : 0x00040000
 RM-816_23.6.015_C01_prd.rofs3.fpsx
CMT Type : BB5
Number of Blocks :  8
Entry Point:  0x00E1
Page Format : -1
 RM-816_23.6.015_prd.rofs2.V20
CMT Type : BB5
Number of Blocks :  79
Entry Point:  0x00E7
Page Format : -1
 RM815_816_004_U001.uda.fpsx
CMT Type : BB5
Number of Blocks :  34
Entry Point:  0x00E7
Page Format : -1
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96  (0x60) bytes returned
Number of Sub Blocks 7 (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000003
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00010007
     ID DWORD    3 : 600C1921
     ID DWORD    4 : 02031104
  2  EM_ASIC_ID 02
     Block Length  : 5  (05)
     ID DWORD    0 : 00001040
  3  EM_ASIC_ID 02
     ID DWORD    0 : 00001060
  4  PUBLIC_ID 12
     ID DWORD    0 : 18C0000C
     ID DWORD    1 : 11255940
     ID DWORD    2 : 31981D04
     ID DWORD    3 : F6AE27F7
     ID DWORD    4 : 4CCBEDE1
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  DA 55 0B 5B AA B5 17 40 90 88 A3 E4 F3 EB 53 AC
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : E693EF0D
     CRC         1 : AC22615B
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg
Secondary Loader Sent....
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> Type not in database
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Manufacturer Code : 0020 ->
   Device ID         : 0040 -> Type not in database
   Revision ID       : 0031
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0000 -> SPANSION
   Device ID         : 0001 -> Type not in database
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Revision ID       : 0031
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              : XSR 1.6
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Flash Descriptor
   Device ID         : 0040
   Revision ID       : 0000
   Size              : 10000000 (256 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
 START READING RPL DATA
IMEI: 358295045519158
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
NPC CERTIFICATE INFORMATION (CMT):
IMEI           : 358295045519158
PRODUCT CODE   : 059L758
WLAN ID        : F4:8E:09:8D:12:37
BLUETOOTH ID   : F4:8E:09:8D:02:97
PUBLIC_ID      : 18C0000C1125594031981D04F6AE27F74CCBEDE1
PAPUB_KEYS_HASH: FCA5CA3CB2B6BE0DD4FAD6075AFCBB8D7972103C
CCC CERTIFICATE INFORMATION (CMT):
HWC CERTIFICATE INFORMATION (CMT):
RPL Backup was Successful...
 Plain RPL saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\358295045519158\358295045519158_104657.rpl
PA PUBLIC KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
  PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index   : 00
CMT PAPUBKEYS HASH:
PHONE FIRMWARE VERSION:
22.6.007
ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-816\
ImageFilename: RM-816_23.6.015_prd.core.C00
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
    Partition Blocks :   1
     1   PARTITION_INFO_BB5
            BB ASIC Index     : 0x00 CMT
            Device Type       : 0x03 MuxOneNAND
            Device Index      : 0x00
            Partition Version : 00020000
            Spare             : FFFFFFFF
            Num Partitions    : 00000004
            Partition    1
              Attribute       : 00000002  RO
              Start Address   : 000A0000
            Partition    2
              ID              : 00000004  DEMANDONOS
              Start Address   : 02E80000
            Partition    3
              ID              : 00000008  FILESYSTEM
              Attribute       : 00000001  RW
              Start Address   : 0A340000
            Partition    4
              Start Address   : 0F640000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF000000040000000300000002000A000002DE0000000000040000000202E80000074C000000000008000000010A34000004F400000000000A000000010F640000003C000050
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength  :  0x4F  (79)
ERASE Blocks :  0x02  (2)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x1B (27)
            Device Index     : 0x00
               0             : 00020000-0003FFFF
               1             : 00060000-004DFFFF
               2             : 008E0000-0A33FFFF
     1   FORMAT_PARTITION_BB5 0x19
            Block Length     : 0x2F (47)
            Device Index     : 0x00
            Format Info ID   : 0x02000000
            Format Info      : 000000000000000A0000000000000002000000640000000B00000002000000010000000000000000
ERASE_REQUEST_BB5  : 5003120B000300000200000003FFFF120B00030000060000004DFFFF120B000300008E00000A33FFFF7F
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A0000000000000002000000640000000B0000000200000001000000000000000033
Successfully Erased...
Total blocks to write : 468
>>  CMT Rootkey Hash CERT : ADA
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : RAP3NAND
>>  CMT Rootkey Hash CERT : SOS+PMML
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS [FCA5CA3CB2B6BE0DD4FAD6075AFCBB8D7972103C]
>>  CMT Rootkey Hash CERT : GENIO_INIT
>>  CMT Rootkey Hash CERT : SOS*UPDAPP
>>  CMT Rootkey Hash CERT : SOS*DSP0
>>  CMT Rootkey Hash CERT : LDSP
>>  CMT Rootkey Hash CERT : SOS*ISASW
>>  CMT Rootkey Hash CERT : SOS+CORE
>>  CMT Rootkey Hash CERT : SOS+ROFS1
ImageFilename: RM-816_23.6.015_C01_prd.rofs3.fpsx
StartErase_DCT5...
BlockLength  :  0x0E  (14)
ERASE Blocks :  0x01  (1)
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 09940000-0A33FFFF
ERASE_REQUEST_BB5  : 5001120B000300099400000A33FFFF06
Total blocks to write : 8
>>  CMT Rootkey Hash CERT : SOS+ROFS3
ImageFilename: RM-816_23.6.015_prd.rofs2.V20
StartErase_DCT5...
            Device Index     : 0x00
               0             : 077D0000-0993FFFF
ERASE_REQUEST_BB5  : 5001120B000300077D00000993FFFFC0
Total blocks to write : 79
>>  CMT Rootkey Hash CERT : SOS+ROFS2
ImageFilename: RM815_816_004_U001.uda.fpsx
StartErase_DCT5...
            Device Index     : 0x00
               0             : 0A340000-0F27FFFF
ERASE_REQUEST_BB5  : 5001120B0003000A3400000F27FFFF6C
Total blocks to write : 34
ContinueFlash_DCT5 Complete
Continue Flash Complete :  : No Error - 0 (0x00)
STATUS_REQUEST_BB5...
1  Sub Block ID      : 15 STATUS_NAND_OK_BB5
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Num Bad Blocks    :  00000001
          Additional Bad    :  00000000
          Correctable ECC   :  00000000
FlashInfo.RestartMode : 1
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:16
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
SW: V ICPR82_11w25.10 08-06-12 RM-816 (c) Noki
CONFIG KEY    :  0000000000000000
PROVIDER KEY  :  2440700000000000
NETWORK NAME  :  Nokia Default;Finland
LOCK COUNTERS :  KEYPRESS 0/3,  FBUS 0/10
SIMLOCK TABLE :
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE :  Not Locked
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SUPER_DONGLE_TEST  : PASSED
               SL3 Phone detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
FACTORY SET TO : Full Factory Set
 OK
FACTORY SET TO : User Data
 OK
FACTORY SET TO : Leave Factory
 OK
FACTORY SET TO : Service Center
 OK
FACTORY SET TO : Software Upgrade
 OK
FACTORY SET TO : Production Tune
 OK
RESET LIFE TIMER TO : 0000:00
 OK
