Python v1.9.1 S60v3 SymbianOS9.x hỗ trợ cả S60v5 9.4
Đây là bản python mới nhất dành cho dòng S60v3 và hỗ trợ cả dòng S60v5 như 5800:)
http://rapidshare.com/files/188714029/Python_1.9.1_3rdEdFP2.rar
http://rapidshare.com/files/188715288/Python_1.9.1_3rdEd.rar
Bác nào có thời gian thì giúp em đưa lên host khác cho anh em dễ down nhé. Đang bị gọi đi làm gà cúng giao thừa:D
MinhThang
Giao thừa gì mà sớm thế em? bản này không biết có gì đặc biết hơn các bản cũ không.:-/
troly
Theo em biết thì nó là bản nâng cấp. Anh tự dịch nhé.
This is the new 1.9.1 development series of PyS60. This release is intended
only for S60 3rd edition, S60 3rd edition FP1, S60 3rd edition FP2 and
S60 5th edition devices.
Note on versioning: The versioning scheme in PyS60 releases is such that the
releases with an even minor version (1.0.x, 1.2.x ...) are "stable" and releases
with an odd minor version (1.1.x, 1.3.x ...) are "development" releases. This is
thus a development release, meaning that it includes functionality that has not
been tested as extensively as the stable releases. This release is provided as a
preview to developers who wish to experiment with Python on S60 before the next
final stable release.
What is new when compared with PyS60 1.9.0?
- Better interpreter startup and sis installation time!
- All the Python files in the runtime sis are compiled into .pyc files and
included in a zip file. sys.path is updated with the path of this zip file.
This reduced the interpreter startup time considerably.
- A more generic error message is displayed when trying to load an application
without the PyS60 Dependencies installed.
- Support for building just a <subsystem> is provided. Refer build, build_emu,
build_device help of setup.py
- Unlike 1.4.x, a single SDK zip contains both gcce and armv5 link libraries.
Separate SDK zips are provided for 3rdEd, 3rdEdFP1 and 3rdEdFP2.
- The default mode of ensymble py2sis command is changed to 'pycore'. All
scripts which refer to pys60 modules socket and calendar should use the new
names - btsocket and e32calendar to use the S60 functionality in pycore mode.
Also renamed "Prioritize PyS60 module library" to "1.4.x compatibility mode"
on the UI of application packager.
tuilaai221
em cai` python 1.9.1 nay` vao` rôi` ma` nó báo la` python for s60 missing , lỡ xó mất cái python for s60 v1.4.5 rồi , hic
Kojiro
Vậy chắc bạn cài Scriptshell trước rồi! cần cài Python S60v3 vào trước rồi mới cài Script.
mrdragon88
Mình vừa format con 5320 của mình.Rồi cài bản Megapymodule 2.01 của bác tiny1990,rồi cài tiếp Python 1.9.1, rồi lại cài tiếp scriptshell 1.9.1 của bác GTCD.Xong xuôi mình cài Sleepmusic v08 vào thì máy báo "python for s60 missing".Cài đi cài lại mãi mà ko được:|
Nản quá đành gỡ hết ra cài bản Python 1.4.5 vào thì cài được Sleepmusic.Chạy ngon lành.Thôi dùng bản 1.4.5 cho lành:D
tiny1990
python 1.45 là bản ổn định nhất rồi.
Còn bản 1.9 hổ trợ thêm màn hình chạm như 5800
còn sleep music bây giờ bản mới nhất là v1.6 beta ghé đây tham khảo thêm s60python.blogspot.com để download
Caominh171
5800 cài Python v1.9.1 cũng bị python for s60 missing :(, cài thằng v1.45 thì ok :D
Cài bản 1.45 cho lành bạn ơi,hơi đâu mà chạy theo cập nhật,chắc tại nó mới ưá nên ít pm tương thích với nó :-??.Bản 1.45 là vừa rùi ;)
thanhdhl2003
Cái này thì mình biết mà, chỉ thông báo cho anh em xài 5800 biết thôi :D
huuquyet255
bac lam on cho e hoi. 6220c cai python xong rui cai them pm cat ghep nhac vao no ko chay la sao ?
