Redsn0w 0.9.6 RC19 [bài 118] - Jailbreak untethered iOS 4.3.3 trên iPhone/iPad/iPod
danny_guan
Phiên bản nâng cấp của Redsn0w hỗ trợ Jailbreak trên iOS 4.3.1 dành cho iPhone iPhone 4, 3GS, iPad (1st-gen) and iPod touch 3G/4G
*Cách jailbreak cũng giống như các Phiên bản trướt nhé.
Link DOWNLOAD ^^
For Win
http://www.mediafire.com/?w7i5g9hpxi4fefd
For Mac
http://www.mediafire.com/?0qj1kyffj77fg4n
Link dowload
Redsn0w 0.9.6 RC-11 Mac
https://sites.google.com/a/iphone-dev.com/files/home/redsn0w_mac_0.9.6rc11.zip?attredirects=0&d=1
Redsn0w 0.9.6 RC-11 win
https://sites.google.com/a/iphone-dev.com/files/home/redsn0w_win_0.9.6rc11.zip?attredirects=0&d=1
Cập nhật Redsn0w 0.9.6rc12 cho Win và MAC:
Fix lỗi cột sóng cho iP4:
Win: https://sites.google.com/a/iphone-dev.com/files/home/redsn0w_mac_0.9.6rc9.zip?attredirects=0&d=1https://sites.google.com/a/iphone-dev.com/files/home/redsn0w_win_0.9.6rc12.zip?attredirects=0&d=1
Mac: https://sites.google.com/a/iphone-de...edirects=0&d=1
Redsn0w 0.9.6rc 13 Jailbreak & Untethered IOS 4.3.2
WIN
http://www.mediafire.com/?6kdyfdp521zk2po
Redsn0w 0.9.6rc 14
MAC
https://sites.google.com/a/iphone-dev.com/files/home/redsn0w_mac_0.9.6rc14.zip?attredirects=0&d=1
WIN
https://sites.google.com/a/iphone-dev.com/files/home/redsn0w_win_0.9.6rc14.zip?attredirects=0&d=1
redsn0w 0.9.6rc16 untethered jailbreak fw 4.3.3 ip3GS/4/ipod3/4/ ipad1 (No ipad2)
WIN
https://sites.google.com/a/iphone-dev.com/files/home/redsn0w_win_0.9.6rc16.zip?attredirects=0&d=1
MAC
https://sites.google.com/a/iphone-dev.com/files/home/redsn0w_mac_0.9.6rc16.zip?attredirects=0&d=1
redsn0w 0.9.6rc17
WIN
https://sites.google.com/a/iphone-dev.com/files/home/redsn0w_win_0.9.6rc17.zip?attredirects=0&d=1
MAC
https://sites.google.com/a/iphone-dev.com/files/home/redsn0w_mac_0.9.6rc17.zip?attredirects=0&d=1
ducthang
Đã tes chưa kịp pots thì bác đã ấy rồi
Chờ tool UL nữa là ok
vipboy_9x
Đã Test chạy rất Tốt trên iphone 4/ipad.
đưa lên chú ý cho mọi người dễ theo dõi.
AnhPheCT
Hướng dẫn Jailbreak Untethered vơi Redsn0w 0.9.6rc9 cho IOS 4.3.1 trên MAC!!!
Hướng dẫn Jailbreak Untether IOS 4.3.1 trên MAC với Redsn0w 0.9.6rc9.
Bước 1: Download Redsnow 0.9.6rc9 ở đây:
Redsnow 0.9.6rc9 for Mac (gốc) hoặc Link Mediafire
Và All Firmware iOS 4.3.1 ở đây:
http://www.coveringweb.com/2011/03/ios-431-available-for-download-direct.html
Giải nén file Redsnow.zip bằng cách double lick vào nó.
Bước 2:
Kết nối Iphone với Itunes.
Tiếp đến chọn Iphone của bạn ở danh sách thiết bị bên phía tay trái. Bây giờ giữ Phím Option và Click Nút Restore
Tiếp đến chọn đường dẫn tới firmware 4.3.1 đã download ở Bước 1. Click nút Choose để tiếp tục.
Bước 3:
Sau khi Itunes đã restore xong iphone của bạn lên 4.3.1 thì bạn mở chương trình Redsnow lên (cái này ở bước 1 đã giải nén ra).
Bước 4:
Khi chương trình Redsnow đã mở lên -> Các bạn chọn Browse
Bước 5:
Chọn Firmware 4.3.1 Gốc mà bạn đã download ở Bước 1 -> Sau đó Click Open
Bước 6:
Sau khi Firmware đã nhận thì click nút Next để tiếp tục
Bước7:
Redsnow sẽ chuẩn bị jailbreak
Bước 8:
Ở cửa sổ này, bạn chọn Install Cydia sau đó nhấn Next
Bước 9:
Cắm iphone bạn vào và chắc chẳn rằng Iphone của bạn đang ở trạng thái OFF. Sau đó Click Next
Bước 10:
Redsnow sẽ hướng dẫn bạn cách đưa Iphone về chế độ DFU.
Giữ nút nguồn 2 Giây.
Vẫn giữ nút Nguồn + Bấm thêm Nút Home và giữ 2 nút trong 10 giây.
Sau đó thả nút Nguồn ra nhưng vẫn giữ nút Home cho tới khi Redsnow nhận ra thiết bị.
Bước 11:
Iphone của bạn sẽ khởi động lại
Bước 12:
Redsnow sẽ bắt đầu upload RamDisk and Kernel mới.
Bước 13:
Sau khi redsnow chạy xong ở bước 12 thì bạn click nút Finish (iphone sẽ khởi động lại, ,mất khoảng 5 phút). Sau khi khởi động lên iphone sẽ vào màn hình chính Springboard có Cydia luôn.
AnhPheCT
Xác nhận nhiều Mem comments khi build FW4.3.1 với Sn0wbreeze 2.5 sẽ JB Untethered nhưng Ultrasnow 1.2 ko thể Unlock sóng được. Mặc dù thử JB lại bằng Redsn0w 0.9.6rc9. Mà ngược lại build bằng Sn0wbreeze 2.4b1 Tethered sau đó JB bằng Redsn0w 0.9.6rc9 Untethered xong Cài Ultrasn0w 1.2 có sóng. Các Bác test nhé. Nhớ build bằng Sn0wbreeze 2.4b1 đùng chọn Hackactive, Youtube, .....mới hoạt động.
Khoa_ha
Cách thoát lỗi 1013 với redsn0w 0.9.6rc9
Nếu bạn restore FW gốc 4.3.1 và không muốn lên BB sẽ dính lỗi 1013 và máy về màn hình cáp đĩa. Tớ vô tình đã tìm ra cách để thoát nó với redsn0w 0.9.6rc9.
1. Máy ở màn hình cáp đĩa bạn cứ để thế và đưa máy về DFU
2. chạy redsn0w 0.9.6rc9 để jailbreak
3. Lần này redsn0w sẽ bị dừng ở bước installing activate bundles..
4. Nhấn phím home + Power 1 lúc để tắt máy
5. nhấn power để bật máy lúc này máy sẽ trở về màn hình cáp đĩa
6. chạy tinyumbrella và nhấn exit recovery là bạn đã thoát được recovery mode
7. máy sẽ vào màn hình ermerycall nếu bạn có sim nhà mạng thì dùng sim nhà mạng activate rồi dùng thôi. còn nếu không có sim nhà mạng thì bạn chạy redsn0w để jailbreak và activate luôn máy nhé.
8. Thưởng thức 4.3.1 thôi nhưng lưu ý là chưa dùng được ultrasn0w nhé.
Mình đã làm đi làm lại nhiều lần và chắc chắn cách này thoát recovery 100% sau khi jailbreak chạy không hề có lỗi gì cả phải công nhận cydia tích hợp với redsn0w chạy rất nhanh và ok.
Lưu ý mình cũng test sn0wbrezzer 2.5 rồi nhé cydia của FW do em này làm vẫn là cydia cũ load chậm. Thêm và đó vẫn chưa dùng được ultrasn0w.
Tóm lại bạn nào dùng unlock thì chưa lên 4.3.1 được vì chưa có tool unlock còn nếu có SIM gevey thì dùng rất tốt đó.=D>
AnhPheCT
chở bàn custom Untethered vậy ...
Chờ làm gì? Đã có rồi đấy! Nếu build FW 4.3.1 Custom với Sn0wbreeze 2.5 (Win) và PwnageTools 4.3 (MAC) đã Untethered rồi đó Pro. Nhưng Ultrasn0w 1.2 ko làm việc, nên còn cách trở về build với Sn0wbreeze 2.4b1 và PwnageTools 4.2 Tethered, sau đó JB = redsn0w 0.9.6rc9 sẽ có Cydia và Untethered và Ultrasn0w 1.2 hoạt động nên đi đường xa vậy.
nin1009
vậy bây giờ em lấy bản Cập nhật FW 4.3.1 Custom cho 3Gs Boot củ
build JB bằng Sn0wbreeze 2.4b1 này của anh up xong rồi dùng Redsn0w 0.9.6rc9 để Jailbreak là dùng được phải không anh,không cần sim nhà mạng nữa hả anh
AnhPheCT
Đúng rồi chỉ cần JB = Redsn0w 0.9.6rc9 là xong, nếu ko có sóng thì Update lại Ultrasn0w 1.2 nhé. Tạm thời để Test thử với Sn0wbreeze 2.5 làm việc với Ultrasn0w đã mới build. Cơ bản 2.4b1 và 2.5 như nhau chỉ khác cái có sẳn Untethered cái ko. Nhưng có Redsn0w 0.9.6rc9 rồi nên k cần bản 2.5. Cứ từ từ. Thế nào cũng có cách mà.
StephenChow
cám ơn bạn mình đã làm thành công trên IP4 W . hoàn hảo.hehe sau bao ngày chờ đợi
nin1009
xác nhận đã up thành công bản Cập nhật FW 4.3.1 Custom cho 3Gs Boot củ
build JB bằng Sn0wbreeze 2.4b1 của AnhPhe và dùng Redsn0w 0.9.6rc9 để JB không cần đến sim nhà mạng nữa,mới up xong đang tét có vẻ như mọi thứ đều ổn định chưa có lỗi gì cả cám ơn AnhPhe nhều lắm=D>=D>:D
AnhPheCT
3Gs boot củ ko cần JB Untethered bằng Redsn0w 0.9.6rc9 đâu, nếu có SIM nhà mạng (Ko có SIM dùng cách này cũng được), vì bản thân 3Gs boot củ build với Sn0wbreeze 2.4b1 đã Untethered rồi. Nếu build với Sn0wbreeze 2.5 theo cách này thì Ultran0w ko hoạt động. Vậy các Bác cứ yên tâm dùng với Build = Sn0wbreeze 2.4b1.
- Nếu ko có SIM active chỉ cần dùng Redsn0w 0.9.6rc9 JB Active là dùng được rồi.
phoenix173
Iphone 4 sau khi update 4.3.1 bằng Snowbreeze 2.4b1 tethered và jailbreak bằng redsnow 0.9.6rc không thể unlock bằng Ultrasn0w 1.2 được. Đã làm theo hướng dẫn nhưng không được. Có cách nào khắc phục không mấy bác. Iphone minh là hàng lock.
tien113
em mún chơi custom cho nó có sẵn lun cydia, chứ đã custom còn chạy tool jb nữa thì lằng nhằng lắm... cái unlock kia e k wan tâm lắm ^^
AnhPheCT
Custom 4.3.1 có sẳn Cydia rồi. Chỉ có Tethered và Untethered mà thôi, Nếu Tethered thì JB cho Untethered, nếu có rồi thì thôi.
Lấy ví dụ, Máy World muốn lên 4.3.1 kích hoạt MG ko nâng BB thì dùng 4.3.1 Custom build bằng cái gì cũng được, nếu build = Sn0wbreeze 2.4b1 thì chạy Redsn0w 0.9.6rc9 để Untethered, nếu build với Sn0wbreeze 2.5 thì ko cần. Nếu chơi FW gốc 4.3.1 thì chưa kích hoạt MG, nâng BB (W ko quan tâm BB). thì cũng JB = Redsn0w để cài Cydia.
Máy Lock giử BB để Unlock, nhưng Ultrasn0w 1.2 ko làm việc với Sn0wbreeze 2.5 build 4.3.1 Custon Untethered nên đi bằng đường vòng. Build = Sn0wbreeze 2.4.1 Tethered, nên JB = Redsn0w 0.9.6rc9 cho Untethered, mà Ultrasn0w 1.2 hoạt động. Cái nào Bạn cũng đụng đến JB, Unlock... đó là công việc của người chơi iPhone.
