hanoiwap
PHIÊN BẢN MỚI
Resco.Keyboard.PRO.v5.10
Bản này có tích hợp bộ tiếng việt,cá bản giải nén và chép vào nơi cài đặt nhé
http://www.4shared.com/account/file/59343776/4e4e9735/RescoKeyboardPROv510.html
Nhớ thank nhé
Đây là các nhận xét về phiên bản 5.10
1) 08-14-2008, 8:13 PM
evilninjam0nky
So what's different? Is there a change log or version history?
2)08-14-2008, 10:57 PM
Dmitry_N(Moscow, Russia)
Since yesterday, ALL links still lead to 5.01! [8o|] I used a lot of traffic from my mobile to check it out!
Guys, what a mess you have on your site!
3-Anonymous
This is what I found on the pocketland.de website (translated from german):
- completely redone
- One-hand operation possible
- Less memory usage
- Sound
You can download the international release (MUI) on this page.
4) 08-15-2008, 12:40 AM
Anonymous
The site indicates that the file is the new version 5.10, but, in actuality, it is the same 5.01 cab and exe files that has around for some time. They must have forgotten to link to the file of the new version. I wrote to support about the problem, but have not heard back as yet.
5) 08-15-2008, 2:53 AM
Lukas Greso Slovakia
We are so sorry, but human misstake cause that old version was uploaded contrary of new.
Now is this problem fixed and you can download this version ( we hope ) with no problems.
We are sorry again
6)Anonymous
And what changes in this release?
7) 08-15-2008, 6:19 AM
- supports square-QVGA resolution
- more than 20 skins available through the update
- supports Tegic eT9 word completion
8)08-15-2008, 8:25 AM
Anonymous
I tried to install the new 5.10 cab file that was uploaded to my WM5 iPAQ. Froze my PDA and wouldn't install. Tried a second time with the same result. Went back to v.5.01 which installed and worked normally. Bugs in 5.10?
9) 08-15-2008, 9:26 PM
Lifedrive
same here with xda Neo WM5.
with power supply = freeze
without power supply = installation failed.
old version is deinstalled and softreset
10) 08-15-2008, 10:29 PM
Lifedrive
download via resco update doesn't work.
after select language mui or english and place, i became a popup download "resco keyboard pro.cab" failed.
11)Yesterday, 12:26 AM
Anonymous
I have the same problem on my Axim X51v. Installed with CAB and with EXE, but the installation failed.
wombo
12)Yesterday, 12:32 AM
Anonymous
Same here and same device Smile
13)Yesterday, 12:36 AM
Anonymous
Means it completely
freezes my Dell Axim X51v and does not install.
14)Yesterday, 9:22 AM
Anonymous
Same problem. Axim X51v. Any solution??
15)Yesterday, 1:56 PM
uzer
iPaq 210. Installed RKv5.10. It worked but my registration code from 5.01 would no longer work. And, half the skins I downloaded either had messed up keys or the abc board would not stick. Seems this version may have been rushed out the door????
On the plus side, after removing it, reinstalling 5.01 and playing around with it I discovered that if you use the up gesture on either Arrow Up or Arrow Down, and depending on where in a document you are you can highlight many more characters than just the single one that upping on the Left or Right Arrows will get you.
16)Yesterday, 6:43 PM
Lifedrive
Hey Resco Team,
any solution?
