ROM mới: Ranju's - v7.4] WM6.1 Pro - 5.2.19199 (Build 19199.1.0.2)
DucLong
Changes and Features of v7.4:
-- New WM6.1 Core + OS (Build 19199)
-- New SDHC driver
-- New SD/SDHC driver switch-over tool (thanx OllieD for coding support)
-- New SIM manager
-- Added NetCF 3.5
-- Added SQLCE 3.5
-- Added BT FTP explorer
-- Added TCPMP 0.72
-- Improved Video renderer (game play should be OK now)
-- Improved Phone response
-- PIE hi-res support with improved preformance
-- Updated some OEM drivers
-- WkTask 1.1.7.3c (by waku) Task manager
-- Camera Application (Build 25626)
-- TodayAgenda 1.10 today plugin
-- WM5torage 1.78 (USB HDD Emulation)
-- Total Commander 2.5
-- Adobe Reader LE 2.0 (optimized)
-- OxiosHibernate 1.3 (no dialog) and Performance/overclocking applet
-- DF's PIM Backup 2.8 (for contact, sms/mms etc. backup)
-- DF's Task Manager / Registry Editor 2.9
-- SynchroTime (by Grachov) for Internet time sync
-- PocketRAR 3.71 (with .zip/.rar association)
-- File-Dialog changer (for file browser enhancement)
-- Voice notification & ringtones
-- New 9-button ComManager (Green)
-- ArcSoft MMS Composer
-- STK srvice and all the common utilities
-- SMS delivery fix (by Saman)
-- Set default search to Google (desktop) search
-- PIE cache (temp, cockies & history) relocated to the root (\IE Cache) for easy cleaning
-- PIE cache limit set to unlimited and tweaked to get best performance
-- WiFi WPA workaround
-- Set default dev-id and BT name to "Universal"
-- Disabled incoming beams (to save battery)
-- Disabled today plugins - Date, Appointments & Tasks (replaced by TodayAgenda)
-- Almost all the Today item set to hidden (Unhide from Today settings, if needed)
-- Exe's & Dll's transformed to module (wherever possile)
-- Some performance tweaks
-- Unlock/Unhiding tool for extROM
-- *Removed Windows Live / Live Search
-- *Removed Transcriber
-- Should work on G3/G4 both devices
-- 15 MB Flashdisk (for G3/G4 both devices)
-- Increased PagePool - 5.4 MB
-- 128 MB RAM Support (may need to set PP => 0)
-- An empty extROM (with special formating)
*Cab on Flashdisk (need to be installed manually, if required):
-- Windows Live
-- JBlend Java 3D
-- Transcriber
[Delete the "Software" folder under flashdisk if you don't need the provided CAB's]
Please note that, provided extROM need to be flashed separately if you're suffering from file disappearing issue @ extrom.
Current Build v7.4:
http://vidmes.com/xda/Uni/ROMs/Tomal/Ranju_v74_WM61_19199_19199_1_0_2.exe
tải file này về làm trống cho extendrom:
http://vidmes.com/xda/Uni/ROMs/Tomal/Ranju_ExtROM.rar
koolpoint
mình đã up bản này được 2 ngày rồi, định giới thiệu nhưng mấy bữa nay nâng cấp diễn đàn nên không vào được: sơ bộ rất tốt, chạy ổn định, ít hao pin, chưa phát hiện một lỗi nào cả.
Đây là bản rom tốt, mọi người nên dùng thử.
Thanks Ranju.
lams-blu
Bản Rom 7.4 nầy bộ nhớ cực lón 39mbStorage+14.59 FlashDisk+9.96 Storage. chạy rất ổn định. có thể xài lâu dài. chưa thấy lổi nào. Đặc biệt không tương thích PM Spb MobileShell2am cài vào gây treo máy luôn
ltrhai
Tôi cũng đã up dùng thử thấy có lỗi là khi cài phần mềm Photo contacts Pro v5.08, auto SMS reply v2.0 xong thì cứ mỗi khi set up xong, thoat ra thi các phần mềm này bị hệ thống bắt thoát ra luôn, phải SR thì mới ở trong tình trạng sẵn sàng làm việc theo chế độ mạc định bình thường, tôi thấy đây là lỗi của bản rom này, các bản rom khác không bị vậy. Không biết các bạn có bị vậy không?
TuyetKy
Bác Lâm xem lại, em chưa thấy bản ROM này xung đột với phần mềm nào cả và em cũng đang dùng Spb Shell đây
TLV
Đây là bản Rom tốt nhất cho đến nay của Ranju. Tôi đã dùng gần 1 tuần không bị lỗi gì. Tốc độ nhanh và mượt (mà không hao pin), ram ổn định. Kết nối wifi, GPRS tốt. Các chức năng cơ bản như camera, contact, gọi đi, gọi đến... hoạt động bình thường
DucLong
bác có nhầm không? bản này ranju mới upload ngày hôm qua, chỉ những ai được ranju gửi bản test mới được dùng trước thôi còn bản chính thức là được đưa lên lúc 6h30 sáng hôm qua.
TLV
Bạn ơi, tôi dùng bản này từ 06-03. Còn ở bên forum.xda-developers đưa lên từ 10-02
DucLong
Không phải vậy đâu bạn, ngày 10/2 là ngày Ranju đưa bản 7.1 sau đó ngày hôm qua Ranju đưa bản mới lên chèn vào bản cũ để đưa lên trang đầu cho mọi người dễ theo dõi đó.
HungUTD
Mình đã test song bản rom này thấy tất cả đều ổn định, không có một nỗi nào khác khi cài các phần mềm, thử tai nghe bluetoot thấy họat động tốt...tóm lại đây là bản rom tuyệt vời.
youandmebl
bản này bị mình phát hiện một số lỗi như sau (test trên exec , chip G4 ) , activeSys4.5 không connect bằng bluetooth , kết nối wifi tại mấy điễm đòi pass , kết nối chút là out ra, và bắt phập pass lại , sau đó tốc độ kết nồi rất chậm , nhiều khi không kết nối được ... chưa phát hiện thêm lỗi nào nữa .
O2XDAEXEC
Bạn thử HR lại xem có còn bị như vậy không.Máy mình chip G3 không phát hiện lỗi như bạn nói!
Thân!
connguab
mình cũng k bị lỗi như bạn nhưng cứ lâu lâu máy lại tự Reset , mình dùng mấy bản Rom trước cũng vậy ????
tưởng pin có vấn đề mình mua cục pin mới lắp vào nhưng nó cũng vận bị như thế, k lẽ máy của mình bị hư ????
có ai biết cách khắc phục k chỉ cho mình với ????
Lesangmd
Một bản ROM quá tuyệt vời !
Mình nghĩ nếu chúng ta sử dụng bản này để build thì sẽ càng tuyệt vời hơn !
Chưa thấy có một lỗi gì , chỉ tiếc là mỗi khi Hard Reset máy thì phải cài phông tahoma mới hiển thị được tiếng Việt và phải dùng tool Unlock and unhide extROM !
Nhưng nói chung thế cũng là rất tuyệt rồi !
Theo mình thì ROM này với bản build từ KITCHEN ROM của bác PHAMQUANG là như nhau !
rockone1909
mình thấy có 1 lỗi nhỏ, là khi HR thì EXTD rom mất hét dữ liệu, nhưng bù lại thì flash disk lại k mất, cái này hơi lạ, tuy nhiên k ảnh hưởng lắm, mình thấy đây là một bản rom tốt, tuy tích hợp nhiều pm có vẻ hơi thừa nhưng tác giả đã tối đa hóa bộ nhớ để cho chúng ta rồi nên k thành vấn đề lắm, mình kết bản rom này :D
djtrungkien
bản này thật tuyệt vì có thanh cuộn nhỏ rất đã nhường chỗ cho màn hình.Nhưng ko sử dụng được phần mềm Clear Temp
rockone1909
cái thanh cuộn ấy minhk dùng được, nhỏ quá, phải chỉnh cho nó về mặc định, hinhg như soft hibernate cũng k dùng được
Lesangmd
Soft Hibernate dùng được chứ bạn !
Bạn cứ đọc trong lời giới thiệu ROM của chính tác giả ấy !
Tức là tác giả đã bỏ thông báo kết quả thôi !
squall14
máy mình chip g3, up bản rom này xong chưa kịp cài softs gì, vào seting hay program file đều treo máy, SR ko ăn thua, cuối cùng đành phải up rom khác. ko hiểu sao nữa
