[ROM][WWE/NLD][4/06]Gen.Y D2 R1.0[WM6.1 B21051][TF3D2]
ntt2006
This ROM is based on bringing the Diamond2 experience to the Diamond.
It consists of almost 90% Topaz/Tachi/Rhodium OEM.
This ROM is almost bug-free, the only issues are related to TF3D2, the ROM will be updated once the final VGA Rhodium Manila files are released.
Pagepool: 12MB
What's Included:
XBMOD Rhodium Manila TF3Dv2 1D + fixes + NEW Manila executables + Tachi New Contact Card
MikeKnoop's Tachi PhoneCanvas VGA v2d
Topaz Calculator
Topaz CommManager
Topaz SensorSDK v4
Topaz Rings & Alerts
Rhodium MenuEnhancement
Rhodium EzInput 2
Tachi Notification Enhancement
Tachi Album v3
Tachi MP3Trimmer
Tachi Task Manager
Tachi Voice Recorder
Tachi Streaming Media
NeoS2007 Topaz OpenVG Drivers
Opera 9.50 Build 16643 VGA
& alot more Topaz/Tachi/Rhodium OEM
+ FInixNOverBatteryIconsOnly
+ some Extra's: PIM Backup v2.8, Advanced Configuration Tool v3.3
+ Replaced ugly green WM6.1 splash screen with WM6.5 orange splash
What's NOT included:
Java
OneNote
RSS Hub
Couple more useless stuff
Download:
Gen.Y D2 R1.0 WWE
Mirror WWE
TestZONE Mirror WWE
Free Storage: ~100 MB
RAM on startup (TF3D2): ~55-60%
Changelog:
R1.0
- Updated EzInput
- Updated DShow
> Fixed video preview showing black image in album
- Fixed Office (excel not starting up etc.)
- Added Windows Live Messenger
- Added Windows Games
- Added missing Camera icon to NLD rom
- Added missing ConnectionSetup icon in settings menu
- Changed dialer to Tachi PhoneCanvas VGA (native VGA)
- Added Tachi TaskBarIconMgr to fix bluetooth icon not appearing
- Fixed screen always dim when using Windows standard keylock
& a couple small things here and there =)
Preview:
- Initial Release
IMPORTANT:
* After flash, it's best to HARD Reset your phone (on boot, press Volume Down + Center button), to be sure that the rom is fully initilalized (less bugs!)
* When u have an active ActiveSync connection, WiFi is disabled in CommManager (this is a feature to save battery), WiFi can be selected again once u disable the ActiveSync connection
* If for some reason you can't access WiFi option in CommManager, either hard reset OR enable WiFi once through settings->connection and then soft reset
* Push Internet is disabled by default to save RAM, you can enable it by installing the attached cab, but be aware that this will keep Opera runnings in the background
Known issues:
- Minor scroll issues (can't scroll to bottom) in Contact Card (Call Log and Delete/Forward Messages) & World Clock view
- NLD ROM only: Pressing the menu button in World Clock view doesn't bring up to menu
> Suprisingly the menu does come up when u change your Regional Settings to US
- Clicking "Send Contact By Message" in contact card crashes/restarts TF3D2
- Some minor graphical distortion may appear when selecting a different band in the CommManager Band Switching app
tonychanh
bản rom này nhìn dẹp, em thix lắm, nhưng khi dow về , ko phải phần cái rom ,mà là
dow về thì thấy phần mềm này, phần mềm này là cai gì :-/:-/
trông giống công cu thiêt kế rom ><
LuonGThanGtk
mình đang xài bản GenY hình như mới nhất nhưng test lắm bug và lỗi quá :) kết mỗi album ảnh load nhanh vãi, down cái này thử xem
