quancaka1
RomPatcher+ is an improved and fixed version of the RomPatcher software developed by ZoRn.
Using RomPatcher+ it is possibile to reach a new level of customization for you Symbian phone.
This is the list of the main differences in comparison with RomPatcher by ZoRn:
- New: support for compiled patches
- New: can dump the whole rom content to file \romdumpplus.dmp
- New: can dump the SuperPage content to file \superpage.dmp
- New: full support for DomainSrv.exe autostart.
- New: introduced new commands ord_rel, ord_snr which allow to patch DLL using ordinal.
- New: can be integrated in cooked ROM firmware
- New: it is now possible to apply/remove patches with just 1 click.
- New: added vertical scrollbar.
- New: introduced support for the new command '+SuperPage' which allow to patch the RAM area where is stored the SuperPage.
- New: introduced support for a new commands, info: return: error: check the demo1-4.rmp patches included.
- New: introduced #ifdef, #ifndef, #else, #endif, #define statements. This will allow to retrieve system values at runtime to create more flexible and powerful patches. Check the ReadMe_Macros.txt for all the details.
- New: you can search / filter the patches in the list. Just start typing the patch name to apply the filter.
- New: wildcard ?? support for patches.
- Fixed: Kern-Exec0 error when closing RomPatcher after a patch was applied.
- Fixed: doesn't unexpectedly crash when using large and complex patches.
- Fixed: RP+ can correcly patch contiguous shadow ram pages without any crash.
- Improved: the shadow ram memory is now fully released when a patch is removed.
- Improved: better compatibility (supports also the OmniaHD, 5630, E52 and probably future devices).
- Improved: the 'Patch Info...' option shows all the information lines contained in the patch.
RomPatcher + là một phiên bản cải tiến và cố định của phần mềm được phát triển bởi RomPatcher Zorn.
Sử dụng RomPatcher + nó là possibile để đạt đến một cấp độ mới về tùy biến cho bạn điện thoại Symbian.
Đây là danh sách các khác biệt chính so với RomPatcher bởi Zorn:
- New: hỗ trợ biên dịch các bản vá lỗi
- New: có thể đổ toàn bộ nội dung rom file \ romdumpplus.dmp
- New: có thể biến các nội dung SuperPage vào tập tin \ superpage.dmp
- Mới: hỗ trợ đầy đủ cho DomainSrv.exe tự khởi động.
- New: giới thiệu các lệnh mới ord_rel, ord_snr DLL cho phép để vá bằng cách sử dụng thứ tự.
- New: có thể được tích hợp trong phần vững ROM nấu chín
- New: bây giờ có thể áp dụng / gỡ bỏ các bản vá lỗi chỉ với 1 cú nhấp chuột.
- Mới: thêm thanh cuộn dọc.
- New: giới thiệu hỗ trợ cho các lệnh mới '+ SuperPage "cho phép để vá vùng RAM là nơi lưu trữ các SuperPage.
- New: giới thiệu hỗ trợ cho một lệnh mới, thông tin: trả lại: lỗi: kiểm tra các bản vá lỗi demo1-4.rmp bao gồm.
- New: giới thiệu # ifdef, # ifndef, # else, # endif, # xác định báo cáo. Điều này sẽ cho phép lấy giá trị hệ thống trong thời gian chạy để tạo ra các bản vá lỗi linh hoạt hơn và mạnh mẽ. Kiểm tra ReadMe_Macros.txt cho tất cả các chi tiết.
- Mới: bạn có thể tìm kiếm / lọc các bản vá lỗi trong danh sách. Chỉ cần bắt đầu gõ tên bản vá để áp dụng các bộ lọc.
- Mới: ký tự đại diện? hỗ trợ cho các bản vá lỗi.
- Cố định: Kern-Exec0 lỗi khi đóng RomPatcher sau khi vá lỗi đã được áp dụng.
- Cố định: không bất ngờ sụp đổ khi sử dụng các bản vá lỗi lớn và phức tạp.
- Cố định: RP + có thể correcly vá tiếp giáp bóng trang ram mà không sụp đổ bất kỳ.
- Cải thiện: bộ nhớ ram bóng bây giờ là phát hành đầy đủ khi bản vá được gỡ bỏ.
- Cải thiện: tốt hơn khả năng tương thích (hỗ trợ cũng là OmniaHD E52, 5630, và có lẽ các thiết bị trong tương lai).
- Cải thiện: những "Patch tin ..." tùy chọn hiển thị tất cả các dòng thông tin có trong bản vá.
http://www.symbian-toys.com/download.aspx?file=rompatcherplus_2.6.zip
