Taki7610
Unlock_GSM
Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\08-06-2014_10-21-25.log" created (6/8/2014 10:21:27 AM).
ERROR : 6/8/2014 10:21:28 AM > Access violation at address 008F42F8 in module 'OctoplusSamsung.exe'. Read of address 00000004
INFO : 6/8/2014 10:21:29 AM > Set up system language English (file: English.ini)
INFO : 6/8/2014 10:21:29 AM > Welcome to Octoplus/Octopus Box Samsung software version 1.5.7
INFO : 6/8/2014 10:21:58 AM > -----------------------------------------------------------------------------------
INFO : 6/8/2014 10:21:58 AM > To connect SGH-I717 phone you have to perform the following steps:
INFO : 6/8/2014 10:21:58 AM > 1. Disconnect USB cable from phone.
INFO : 6/8/2014 10:21:58 AM > 2. Go to Menu->Settings->Applications->Development.
INFO : 6/8/2014 10:21:58 AM > 3. Turn on "USB Debugging" option.
INFO : 6/8/2014 10:21:58 AM > 4. When message is appear press "Yes".
INFO : 6/8/2014 10:21:58 AM > 5. Go to dial window.
INFO : 6/8/2014 10:21:58 AM > 6. Enter "*#7284#" number.
INFO : 6/8/2014 10:21:58 AM > 7. Set "USB" radio button to "Modem" value.
INFO : 6/8/2014 10:21:58 AM > 8. Press Home button.
INFO : 6/8/2014 10:21:58 AM > 9. Go to dial window.
INFO : 6/8/2014 10:21:58 AM > 10. Enter "*#9090#" number.
INFO : 6/8/2014 10:21:58 AM > 11. Set "Diag config" to "USB" value.
INFO : 6/8/2014 10:21:58 AM > 12. Restart phone.
INFO : 6/8/2014 10:21:58 AM > 13. Press "Read Info" in software.
INFO : 6/8/2014 10:23:28 AM > -----------------------------------------------------------------------------------
INFO : 6/8/2014 10:23:28 AM > Platform: Samsung Android
INFO : 6/8/2014 10:23:28 AM > Selected port: COM19
INFO : 6/8/2014 10:23:28 AM > Selected model: SGH-I717
INFO : 6/8/2014 10:23:28 AM > Port is busy
INFO : 6/8/2014 10:23:31 AM > Phone was not found on the selected port!
INFO : 6/8/2014 10:23:31 AM > Searching for USB diagnostic port...
INFO : 6/8/2014 10:23:31 AM > Connecting to phone on COM309
WARN : 6/8/2014 10:23:31 AM > Phone connection failed
INFO : 6/8/2014 10:23:31 AM > Connecting to phone on COM308
INFO : 6/8/2014 10:23:31 AM > Connecting to phone on COM310
WARN : 6/8/2014 10:23:31 AM > No diagnostic ports found!
INFO : 6/8/2014 10:23:31 AM > Connecting to phone on COM5
WARN : 6/8/2014 10:23:32 AM > Phone connection failed
ERROR : 6/8/2014 10:23:32 AM > Selected action can’t be performed
INFO : 6/8/2014 10:23:35 AM > -----------------------------------------------------------------------------------
INFO : 6/8/2014 10:23:35 AM > Platform: Samsung Android
INFO : 6/8/2014 10:23:35 AM > Selected port: COM310
INFO : 6/8/2014 10:23:35 AM > Selected model: SGH-I717
INFO : 6/8/2014 10:23:36 AM > Phone was not found on the selected port!
INFO : 6/8/2014 10:23:36 AM > Searching for USB diagnostic port...
INFO : 6/8/2014 10:23:36 AM > Connecting to phone on COM309
INFO : 6/8/2014 10:23:36 AM > Mode: Normal
INFO : 6/8/2014 10:23:37 AM > Phone model: AAABQOCZ
WARN : 6/8/2014 10:23:37 AM > Phone model is not supported
WARN : 6/8/2014 10:23:37 AM > Phone connection failed
INFO : 6/8/2014 10:23:37 AM > Connecting to phone on COM308
INFO : 6/8/2014 10:23:37 AM > Mode: Normal
INFO : 6/8/2014 10:23:37 AM > Phone model: SGH-I717
INFO : 6/8/2014 10:23:37 AM > Firmware compiled date: May 07 2012
INFO : 6/8/2014 10:23:37 AM > Firmware compiled time: 20:00:00
INFO : 6/8/2014 10:23:37 AM > Firmware released date: Jun 23 2012
INFO : 6/8/2014 10:23:37 AM > Firmware released time: 15:56:02
INFO : 6/8/2014 10:23:37 AM > Phone IMEI: 352013-05-193450-0
INFO : 6/8/2014 10:23:37 AM > SW version: M9200B-SCAQCSZD-3.4.701084
INFO : 6/8/2014 10:23:37 AM > Unlocking phone...
INFO : 6/8/2014 10:23:37 AM > Phone is successfully unlocked
WARN : 6/8/2014 10:23:37 AM > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!)
Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\08-06-2014_10-21-25.log" closed (6/8/2014 10:24:21 AM).
