Trunghuy90
Changes in version:
- Added feature to automatically install an application seeking the installation package (at the request of user St.FrantiC, though this is not exactly what he wanted, but the idea is the same);
- The editor added 2 lists ways to add a new record - either through File Manager,or manually;
- Minor fixes;
- Added delete function applications (known bug - why it is not always displayed correctly mask for the icon image, so in these cases is simply a blankspace instead of icons, if you do not mask all the works, but will be on a black background, I think does not look at no);
- To view the application file, you can create a custom list for this application, and the list willautomatically be in your custom lists;
- Rewritten daemon cleanup;
- Added configuration section demon cleaning;
- Fixed errors found hope;
- Changed the styling of the info window;
- Changed boot splash;
- Added ability to specify a list entry form!: / / Folder/folder2 / *. txt (! - Makes it clear that it must be looked at both drives * - makes it clear that it must be looked in this folder to expand);
- Peredalana schedule and method of rendering (now drawn on the mask, which made it possible to reduce the size of the installation package and increase the speed of loading);
- Slightly increased the font (not everywhere);
- Added function SCTurbo (to speed up analysis time and the search several times, with a map of the search process or analysis available);
- To clean the added ability to edit the found (ie, beforecleaning can be removed from the list of files that should not be deleted);
- Wherever it is needed (such as) adds the ability toattach a file exclusion list;
- To remove the folders added possibility to specifyany number of names (by default, only two names did);
- Changes in the scanner added ability to specify thefolders for which you need to follow (the default drive is C and E);
- Booked a place in the function of removing and installing applications (stillhave not done these functions);
- Slightly altered configuration section for its unification in the horizontal display;
- Added to the assembly ochitski lists of users and imp37 JEdgar (thanks to them for this big).
Who does not have module cfileman have to throw in the game on the way! \ Sys \ bin!
In this program, there is no database to clean and can not be. All treatment, it makes for Spica, which lie in the appropriate folder. Lists - simple TEXT files, which spelled out the path to files or folders. Therefore, create, delete and edit these lists as you want. This program is universal.
http://www.mediafire.com/?9wi85m8ux804955
- Minor fixes;
DOWLOAD
