+ After blocking now returns to the same application / state that was before the lock
+ Now the screen backlight should behave normally (except backlight keys on p1/w960)
+ Displays number neprochitanyh SMS / MMS / Email (I checked only SMS / MMS, please check with the case EMail)
+ Displays missed calls, believes only missed when blocking (which was before the lock, ignores), with manual unlock - dumped.Cancelled during a blocking call is considered a missing
+ To ini parameter added HiddenTaskMode - hides application from the list of targets
+ If idleTimeOut = 0 and StartOnBackground = 1, the program works in the background and avtoblokirovka time inoperative
+ If TimeToDisplayOffAfterLock = 0, the screen is not extinguishes after the block. Now, this value must be a multiple of 10! Works not very precise, error of approximately 10 seconds smile.gif
+ To ini parameter added UsePowerSaving: 1 - using energy-saving mode, 0 - disabled energy saving
+ Added in the ini settings and ScreenActiveOnMobiReader ScreenActiveOnCorePlayer: 1 - not extinguish the screen with the active or MobiReader CorePlayer, 0 - disable this feature
+ Added in the ini settings and NotLockOnMobiReader NotLockOnCorePlayer: 1 - not to block the active MobiReader or CorePlayer, 0 - disable this feature
+ To ini parameter added LockOnlyOnStandByOrGDesk: 1 - automatically block only with the active standby or GDesk, 0 - otlyuchit this opportunity. NotLockOnCorePlayer. This option has a higher priority than NotLockOnMobiReader and NotLockOnCorePlayer.
+ To ini added Section LockedKeys - in what it described key block: 1 - block, 0 - not to block
+ To ini parameter added TurnOnDisplayOnTouch: 1 - include touching the screen with, 0 - do not include
+ To ini parameter added AutoStartOnBoot: 1 - iPhoneLock load at boot phone (works even if, in addition enabled StartOnBackground), 0 - not to download
+ To ini parameter added ShowBatteryLevel: 1 - shows the level of battery in% 0 - disabled
