Thảo Luận dùng Rom Cook LeeDrOiD Flyer HC V4.1.0
alibabahp
Anh em mình trên diễn đàn ai đang dùng rom LeeDrOiD Flyer HC V4.1.0 thì vào chia sẻ trao đổi kinh nghiệm tí nhỉ?Như call làm việc hoàn hảo chưa?Bluetooth,wifi sóng sánh và pin thế nào?:-?
Cái này mình lấy bên XDA
Presenting LeeDrOiD HC for the HTC Flyer
Android 3.2.1 - HoneyComb & Sense... No Gimmick's, No Bullshit..
Just an EPIC Experience from the most experienced ROM/Kernel developer for the HTC Flyer
Official Support Links:
» Chat live now or join #LeeDrOiD-Roms on Freenode (irc.handhelds.org)
What you get -
The Kernel
LeeDrOiD Kernel V2.2.0 -2.6.35.14
Based on official sources Flyer-2.6.35-HC-MR
Patched to linux upstream 2.6.35.14
CPU Governors - LagFree, Smartass, Ondemand, Performance, Conservative & Powersave
Custom LeeDrOiD CPU FREQ Table
SYSFS VDD Levels interface
OC up to 1.94GHz (1.54GHz Standard)
WiFi PM=FAST in standby
SLQB Memory allocator
Added BFQ & V(R) IO Schedulers (V(R) as default)
Built with XZ Compression
Automated per tty tasks
Thermal protection
CIFS & OpenVPN support
Heavily optimized code passing -03's
Compiled with the latest Linarion 4.6.1 toolchain
For teh full kernel change log >>>> Visit my GIT Repo
The ROM
Based on HTC Asia HC (WWE) 3.63.708.1 (RUU > OTA > OTA)
Rooted with the latest superuser & Bianry
Busybot 1.19 with Run parts support
CIQ & Logger free!
Huge system optimizations & Cleanups
Fully working Phone functionality
Full HW/Virtual Keys
Stock % Battery display
Transparency in app drawer & add to home
Lots of default configuration changes
Battery life enhancments
The usual LeeDrOiD Customizations
Huge Locales list (Language support)
Masses of system cleanups
Fancy animations
Fixed keyboard animation
Advanced power menu
5x7 app drawer (thanks to Scabes)
SUPER STABLE!!
LeeDrOiD Tweaks with the ability to toggle HW Keys (Thanks to Daniel & Jan)
SpareParts advanced config tool
Additional settings and tweaks exposed throughout
Optional Stock Honecomb launcher
All applications updated with each build
Custom LeeDrOiD Wallpapers & Bootanimation
AND LOTS MORE!!.... see the change-log's below
LeeDrOiD Flyer HC V4.1.0 - 31st January
Fixed incoming call answer/decline (Lockscreen)
Fixed random reboots @lockscreen
Added Honeycomb Dialer widget thanks to ElephantStone82
Fixed HTC Locations "insufficient space" error
Increased app drawer capacity - 3x8 & 5x7
Added transparency to app drawer & add to home
Home UI speed tweaks
More System cleanups & Junk removal
Fixed Android stock keyboard
Removed additionalbugreport logs
EXT4 file system tuneups
Cleaned up build.prop
Cleaned up init.d scripts
Fixed thermald.conf
lowered boot soundvolume
LeeDrOiD Flyer HC V4.1.0 (Torrent)
LeeDrOiD Flyer HC V4.1.0 (FTP)
MD5 Checksum file
MD5# 65176ca3e47b5b1c40f93f0b25629900
If you have acheived S-Off via HTCDev, you will need to extract the boot.img from the ROM.zip and flash it via fastboot
"fasboot flash boot boot.img"
Kernel Download links
To be flashed VIA CWM recovery
LeeDrOiD Flyer HC V2.2.0 - 2.6.35.14 KERNEL (FTP)
Updated 31st December
MD5 Checksum file
MD5# b3be9b85cdb0b9c4db779a032908e052
If you have acheived S-Off via HTCDev, you will need to extract the boot.img from the Kernel.zip and flash it via fastboot
alibabahp
Hiện tại mình đang bị lỗi ở bản rom này là ko set thời gian khoá màn hình đc.Để vài giây nó tự lock luôn.Vào screen chỉnh thời gian không được
