THẢO LUẬN VỀ ROM UNIVERSAL (XDA Exec, SPV M5000, i-mate jasjar/MDA Pro)
Levan
đây là rom windows mobile 6 professional 3G mà mình đã download được từ diễn đàn XDA-developers.com.
sau cài đặt storage 43.72 MB, Program 49.95 MB. dưới đây là chi tiết về rom các bạn có thể tham khảo. theo mình chạy khá ổn định, ít tụt ram, WIFI tốt, không bị lỗi camera (có thể chỉnh registry cho frame từ 10 lên 18, để quay cho hình mượt hơn).
New WM6PRO Business AKU 0.5 (G3 & G4 update 3 ready)
We removed all previous builds because people are getting confused which is the latest build
WIFI BUG FINALLY FIXED !!!!!
About the Rom:
OS Version : 5.2.1708
Build Version: 18508.0.7.0
AKU: 2.07.00 WWE
Radio : 1.18
Special thanks to Mamaich his beautiful work on SDHC!
Thanks also to Helmi, Dutty, DotFred, SZilamer, Mr. Groch , TehPenquin , DarkForce , Anichillus , Lt.Cmdr.Ivan , Mamiware, Ranju, Vagus_ppcw and all the others we forgot to mention, for their contributions.
Some screenshots:
1 plus 2 plus 3 ……
What is fixed:
- Wifi.
- E-mail account creation
- HTC Camera v.3.00 (Build 22844)
- Pictures and video
- New 9 button HTC Comm Manager v.1.3.7.0
- New WLAN Manager v.3.17.00
- Hardware Buttons
- Added Windows Mobile Green and Guave Bubbles to today theme option’s
- B2ADP according to Jwrightmcps settings (Currently testing)
- Hidden Extended ROM
- IE browsing speed
- Systray icons. (Screen Rotate, Power and Comm Manager)
- Windows Live Messenger
What is tweaked:
- IE Font, speed, cleartype
- Infrared Beam disabled by default for longer battery life
- Button lock enabled by default
- Cleartype enabled by default
- System Clock
- Power settings
What is included in this Rom:
- Windows Live and Messenger v.10.6.0031.2600
- VOIP with Custel
- SDHC support’s 8gb MMC cards (Mamaich)
- Arcsoft MMS v. 4.0.31.16
- HTC TaskManager v.1.5 (Build 29196)
- New HTC Sim Manager v.6.13
- NetWizard v.1.0.29982.1
- 3GVT Dialer (Videotell experimental)
- GroupSMS v.1.1
- New sounds and notifications.
- PimBackup v.2.5.0
- SMS Backup v.1.1
- PocketNotePad v.4.0.10
- StartClean
- USB HDD v.1.0.2.1
- WinRAR v.3.60
- New boot splash screen
- Remote Desktop
- Internet Sharing
The ROM ……
Make a Donation …
Thanks and Regards,
Beast and Laurentius
connguab
Bạn có thể chỉ cho mình chỉnh registry cho frame từ 10 lên 18, để quay cho hình mượt hơn k ???
Cảm ơn bạn nhiều nha
xda_exec
Pc không nhận ra XDA exec!!!
Các bác cứu với!!! Em exec G3 của em dạo này cắm vào các máy tính đều ko nhận nữa rùi, em đã thử thay cáp và thử ở nhiều máy tính khác nhau, đều cho kết quả là "USB device not recognieze" hic hic
Bác nào biết nó lỗi ở đâu, sửa ra sao và đến chỗ nào sửa tốt làm ơn chỉ giùm. Em ở Hà Nội ợ!!! cám ơn các bác nhiều!!! hức hức :((
Ps: Em đã thử up lại ROM nhưng ko đc vì máy tính ko nhận ra PPC. hức hức :((
XuanTruong
Có thể chỗ cắm cáp trên máy bị bẩn hoặc rơ lỏng nên không tiếp xúc tốt. Bạn thử coi và vệ sinh lại xem sao nhé!:D:-?
tobo
Máy của tôi cũng EXEC G3 và cũng bị tình trạng gần giống với bạn xda_exec: cắm cáp USB để uprom thì bị báo là "USB device not recognize" nhưng nếu cắm để sync thì vẫn sync được. Nên bây giờ hổng sao test được ROM mới.
Mong các bạn giúp đỡ.
XuanTruong
Bạn xóa thật sạch Active Sync đi rồi cài lại xem sao nhé, nên cài bản mới nhất trên Win XP SP2!:-?
Levan
chỉnh registry cho frame /camera
bạn vào HKEY_LOCAL_MACHINE\SOFTWARE\HTC\CAMERA\Recparam\MP4Large\FrameRate\DWORD Data từ 10 thành 18. sau đó soft reset là ok.
nhattuong
Các bạn xin cho mình hỏi. Tình hình là mình đang ở nhật, khi sang đây mình mang theo con exec thân yêu sang đây, mình bỏ sim 3G của softbannk vào và sử dụng. không biết bản rom nào hổ trợ mạng 3G của Softbank tốt nhất ? bạn nào đã và đang sử dụng cho mình ý kiến và xin chỉ giúp...cám ơn rất nhiều
tobo
Cám ơn bạn đã giúp nhưng sau khi xóa Active Sync và cài lại thì tình hình vẫn như cũ: vẫn sync bình thưởng nhưng nếu chuyển qua chế độ bootloader để up ROM thì lại bị báo lỗi USB device not regconised và chữ "S*e*r*i*a*l" vẫn giữ nguyên mà không chuyển thành chữ "USB".
thieuta
Bạn đã tháo thẻ nhớ ra khi cắm cáp vào máy chưa?!
XuanTruong
Tháo Sim và thẻ nhớ ra khỏi máy sẽ OK ngay!:D
Làm sạch đầu cáp nhé, khởi động lại PC
Dĩ nhiên là khi hiện ra dòng đó trên PC thì PPC làm gì chuyển qua USB được.
Không được nữa là mua cáp mới á :))
tobo
Khổ quá, tôi đã nói là bình thường vẫn sync được bằng đúng sợi cáp đó. Chỉ có khi chuyển về boot loader để up ROM thì mới gặp lỗi thôi.
Cám ơn bạn thieuta và XuanTruong, đúng là sau khi gỡ sim ra thì lại bình thường. Thật lạ, trước giờ tôi up ROM không biết bao nhiêu lần nhưng chưa lần nào tháo sim hay tháo thẻ nhớ cả.
Lần nữa, cám ơn các bạn rất nhiều.
doibung0
Thì tại nó có trục trặc với cái đầu mini usb của thằng pocket pc ấy, lúc trước cũng bị như bác, bác cứ giữ chặt cái cáp usb đè mạnh vào và giữ nguyên như vậy!
anhtuhd
I-mate cần giúp đỡ ?
Em có con i-mate jasjar chỉ chạy được khoảng 5 phút thì bị tắt máy, bật lại nguồn thì không lên nhưng nếu cắm sạc thì dùng bình thường pin vẫn báo là trên 80%, các bác cho em hỏi nó bi bệnh gì với, nó ở phần cứng hay phần mềm ?
XuanTruong
Thay cục Pin mới là OK ngay, vì Pin CHẾT rồi!:D:D:D
tobo
Thêm một thông tin cho các bạn tham khảo:
Sau nhiều lần thử nghiệm thì ra trong trường hợp của tôi vấn đề không nằm ở chỗ sợi cáp USB, hay lỗ cắm USB trên EXEC bị dơ, hay quên chưa tháo SIM mà là ở cái thẻ nhớ.
Trước đây tôi không hề phải tháo thẻ nhớ là do tôi xài thẻ SD; còn sau này là dùng thẻ SDHC. Đã thử nghiệm:
- Nếu để thẻ SD bên trong EXEC thì mọi việc bình thường;
- Nếu để thẻ SDHC bên trong EXEC thì bootloader không chuyển qua "USB" khi cắm cáp USB vào; nếu lấy thẻ SDHC ra thì lại ổn. =D>
XuanTruong
Chưa hẳn?8-| Máy Mình nếu để thẻ SD trong máy thì không thể chuyển qua USB được (Đã thử vài chục lần với các loại dung lượng thẻ từ 128MB đến 2GB), nên khi Up Rom đều phải tháo thẻ nhớ ra? Cái này chắc do con CHIP trên từng máy???:-?:D
