Rygar
Vista Mobile
Bộ theme tuyệt vời dành cho PDA của bạn, hỗ trợ cả QVGA và VGA, tiện lợi cho những người thích dùng ngón tay hơn là dùng stylus =D>
Bonus thêm wallpaper cho S2U2 ^^
Hướng dẫn sử dụng:
Tải file mình up lên về, giải nén sẽ được 2 file nén khác, giải nén từng file và làm theo các bước sau:
1. Open the .zip file and extract the contents to a temporary folder on your PC.
* If you're an advanced/experienced user of WA/WAD, may want to take a look through the file structure before copying the files to your device, as you may already know where to put them.
2. Initiate an ActiveSync connection if you haven't done so already.
3. Using Windows Explorer, copy the folders from the _copy_to_device_MAIN_memory_(root) folder to the device's main memory.
* The files in \My Documents\My Pictures are the wallpapers that should be used. These may be kept anywhere on the device, but you'll need to tell Wisbar Desktop where their new home is, since the theme is preconfigured for this path.
* The files in \Program Files\Lakeridge\Wisbar Advance\Themes\Vista are the main Wisbar Advance (WA) theme resources that should be copied to wherever you keep your WA themes.
* The files in \Themes\Desktop are the Wisbar Advance Desktop (WAD) theme files which should be copied to where your WAD themes are kept. Note that if you do not have WAD installed, you do not need to copy this folder.
4. Open up WA and select the VistaMobile v1.0 theme that should now be in your list (try restarting WA if you have any issues).
5. Apply the theme, and change any other settings if needed.
6. WA should now be skinned, and next up is WAD. Simply click and hold on an open area on your WA Desktop and choose Theme Manager (note that "Author Mode" must be active).
7. Select either "vistaMobile_P_VGA" (portrait)or "vistaMobile_L_VGA" (landscape) depending on what your current screen orientation is.
8. Enjoy using Vista Mobile!
Extras Included:
* The following files are found within the _extras folder in the .zip
* Slide2Unlock v2.0 (S2U2) theme included (simply copy the files, overwriting the originals on your device)
* Random wallpapers sized to 640 x 480
* Blank large icon background for creating your own main icons
* Marshall WaitCursor Touch Skin (replaces the traditional 4-colour/slice WM wait cursor)
* Segoe UI fonts (Pocket Tweak or many other PPC programs will allow you to change the default system font to whatever you choose).
Bác nào có thể dịch ra tiếng Việt cách cài hoặc là chỉ cho mình cách cài cái theme này được ko. Cám ơn nhiều. Hix, hỗ trợ cả 2 mà sao thấy trong máy chỉ có VGA với cả cài xong rồi ra thì thấy cái thêm to đùng, kiểu như vượt quá khổ của máy nhiều lần, có bạn nào biết tại sao ko :-?
