TNT 19199 Series WM 6.1
hussein_erol
Official Edition:
- 1-Calculator
- Commanager 1.2.0.0 new
- ArcSoft_MMS_5_0_31_7 new
- Camera
- Modem Link (DUN)new build
- Streaming Media 2.1.1025.621(Fixed) new
- Some tweaks for battery drain and WiFi issues
- Office latest version with zip view and OneNote.
- SIM Manager 6.38 new
- PIM Backup 2.8 new
- Tsk Manager (with registry editor)
- SMS Backup new
- Windows Live Messenger 10.6.0034.800 new FIXED
- Net Compact Framework 3.5.7283.0 new
Professional Edition:
- camera app
- 1-calc.
- Modem Link (DUN) new build
- Network Wizard 1_0_29982_7 support many of networks (Auto run disabled, go to start/settings/connection to set you network settings)
- SmartKey 0.56 (the best settings)
- SoftKeyAppletEx (to change Home SoftKeys)
- WM5torage 1.78 Final new
- STK Service 4.69 new
- TimeZone Tab on the phone settings (just the tab w/o enabling which may show some issues with starup)
- All Help files as the official
- Internet Sharing
- Advanced Config Tool 2.0.2.0 new
- BT_FTP 1_2_30489_1 Removed
- BT_SAP 2_02_b0925_r3. Removed
- BtIO 0.6 (to listen sounds via the BT Headset)
- Dr.Yar 1.6 (to show the BT sender name and set the recieving folder).
- MJConfig
- Event Countdown 1.0 (timer)
- GroupSMS 1.2 new Removed
- GSFinder+ Removed
- black keyboard
- HTC Audio Manager 1.2.614.712
- Pocket RAR 3.7
- Pocket Screen Capture.
- Mobile Justice Removed
- Network Plugin 1_0_29714_1 Removed
- Notepad
- ClearTemp 0.9.6
- CloseApps
- Hibernate
- Peek Pocket 1.4 (WiFi networks manager)
- RealOne (rm ram ra player, files set to it) Removed
- RunEveryDay.
- SMS Backup 1.1
- SMSService
- Total Commander
- WinXplore 0.3.4.1
- HTC Voice Recorder 1.10.611.711 Removed
- TaskManager 2.7.0.1 (with reg app shortcut)
- BT_BPP_1_5_0_0
- Call2Contact_1.0
- SK tsync
- 6 smart Games Removed
- HTC_BT_Quicklink_0_4 Removed
- Hush SMS
- Alt Tab app.
- BtCrawler
- HTC Home 2_1_1005722_0 (many fixes compared with 1.5.xxx, first HTC Home 2.x for wizard "tnx hm4") new
Removed:
i removed some packages because SYS folder for WM6.1 is larger than before, so we have to minimize OEM size. BTW, all the removed files has been added to TNT Add On thread (2nd post)
TouchFLO Edition :
the same as professional edition with HTC Home and its settings on the Today/items tab, with the scrolling feature without the Cube (you can add it as an Add On) and also without VoIP (you can add it later, but make sure to download the new one for TNT.1933, it's compatible with TNT.1620) .
- Windows Live Messenger 10.6.34.800 Removed removed from TouchFLO (you can download it, please if you have this build, add it to TNT Add Ons thread PLEASE).
Official:
[HIDE]RapidShare[/HIDE]
Professional (my favorite) :
TouchFLO:
[HIDE]RapidShare
[/HIDE]
The New Add Ons :
- TNT_Flash_Player_3.0.cab
- TNT_VoIP_1933_for_Touch_Version.cab
- TNT_Cube_1933, 1620, and later.cab (for TouchFLO users)
Aivanhoknight
Chờ mấy tháng không thấy ra bản nào, bây giờ bác này ra 2 chú liền.
Vừa up bản 1620 hôm qua, hôm nay lại phải up bản mới rồi:((
DECAPITATED_8888
mình đã test bản Pro này gần 1 ngày có vài nhận xét :
- vẫn bị 1 lỗi như các bản TNT trước là Win Media cứ chạy 30s là nhảy bài :( ko rõ là có phải do đụng soft ko ?
- dùng rất trơn và mượt, pin bt, dùng chung với Radio 2.69 có vẻ ổn định nhất, theo mình thì đây là bản TNT ngon nhất trong nhóm Rom TNT
- đã remove 1 số soft ko cần thiết => giải phóng bộ nhớ đc tí chút :d
Aivanhoknight
Đây đúng là bản rom OK nhất trong dòng TNT từ trước tới giờ. Pin dùng bớt hao hơn Octaivoi 6.0
Mình dùng TNT chưa bao giờ bị nhảy bài sau 30s cả.
vuhaminh
em dùng bản TNT nào cũng bị nhảy bài sau khoảng 30s. bản TNT này co nhiều cái mới nhưng em thấy cái SMS kiểu conversation này không tiện lắm. Thực ra thì cũng có cái hay của nó nhưng:
- thiếu cái đếm ký tự
- không xóa được từng tin nhắn riêng
Em nghĩ nếu làm cái này theo kiểu option, có thể tùy chọn SMS theo kiểu cũ hoặc theo kiểu conversation.
thanks
minhmck
Bản ROM này dùng rất tốt, ít hao pin, chạy mượt... Tuy nhiên, thiết lập WOW HD Settings sử dụng không được, báo lỗi "There is no WOW HD driver loaded. The control panel will now exit". Không biết có bạn nào bị giống mình không?
bachikho
tui xài bản này thấy rất nhanh tuy nhiên hao pin hơn bản wm6 Speed Freak 2 nhiều (cùng với radio 2.40.11, up lên 2.71.11 còn hao hơn nữa)!
vuquang
e xin lỗi các Mod và mọi người trước kia e dùng minis nhưng giờ chuyển sang atom exec nhưng ko biết vào top nào để úp rom mong các mod và mọi người chỉ dẫn e xin cảm ơn. Hic! làm phiền mọi người giúp đỡ. E tìm rồi nhưng ko hiểu vào topnic nào thì đúng, úp nhầm thì toi. Thanks
bonmat8888
Vào đây bạn nì : http://www.pdaviet.net/forumdisplay.php?s=&daysprune=-1&f=95
Trước Tết bị mất O2 miniS. Bây giờ trong 4room có nhiều Rom mới để up mà đành ngồi nhìn. Tìm 1 con Cingular 8125 mà chẳng thấy ai bán cả. Chán wa'!
VUHEO
Mình mới cài thử bản ROM này, giao diện không có gì hay hơn mấy, đã qua được lỗi 20'sang bài của WM, không êm cho lắm vì đã phải reset 4 lấn trong vòng mới 2 giờ. đang kiếm lỗi từ đâu.
@bốn mắt : bạn ở đâu vậy, mình có con 8125 người bạn cầm từ Mỹ về chỉ có cái máy không thôi, máy mới, pin mới, nhưng máy nhìn tầy sướt vài chô hông đáng kể, thích thì mình gởi về cho
bonmat8888
Hay quá! tôi đang ở Nghệ An. Làm sao liên hệ với bạn vậy? giá bao nhiêu? có thể SMS cho tôi: 0903456781.
Cám ơn bạn!
VUHEO
Sau một ngày vọc bản TNT19199 này thì quyết định tháo bỏ và thay bản khác vì quá nhiều bug không đáng có cho một bản ROm ra sau. Nói một cách chính xác là nó dở hơn bản trước TNT1933. Đang phân vân không biết có nên chơi bản Octaivoi's v6.2 hay PDAViet 2.0.
@bonmat: tin buồn cho bạn, mình chỉ có thể đem máy tới Đà Nẵng mà thôi bạn à. Mình đang có 2 chú ở TpHCM đây nhưng Nghệ An thì mình thua.
DECAPITATED_8888
bug bạn thấy là như thế nào bạn nói rõ hơn xem ? mình lại thấy bản Rom này ngon hơn bản 1933 nhiều, còn bản 1933 có lẽ là dở nhất trong rom TNT
bonmat8888
Giá bao nhiêu vậy bạn? nếu được tôi nhờ người ở ĐN đến lấy và gửi ra cho tôi.
