Energy Patrol v 1.1
Ứng dụng theo dõi dung lượng pin của máy. Bạn sẽ cài đặt dung lượng pin bao nhiêu thì nó sẽ báo bằng cách tin hay beep.
Ứng dụng sẽ hoạt động theo profile mà bạn đang sử dụng.
Description list:
-- Program does vibrate or play ringtone according to battery level.
-- You can set minimum battery level to begin signaling.
-- Written in C + +, as a consequence consume few resources and does not require additional components.
-- Allows you to ask a kind of signal: vibrate and / or ringtone.
-- Sound volume and vibrate mode are taken from current profile. If your phone to silent night shifts or in quiet mode, then progress will not lodge signals, or will do so quietly.
-- Supported autoload
-- Interface in Russian and English. Contains the user manual in English and Russian
