wildcat
This recovery is for the HTC Nexus One
Features
* full ADB access in recovery mode
* Awesome Care-Bear version! (Blame packetlss for talking me into it ) *NEW in v1.6.0
* Busybox v1.15.3 *NEW in v1.6.0
* Kernel with ext3 + ext4 support *NEW in v1.6.0
* HW-Key navigation (Trackball + Volume-key) option
* Extended menu :
o Reboot system now :: reboot your phone
o USB-MS Toggle :: enable/disable USB mass storage (use when the phone is connected to your PC)
o Backup/Restore
+ Nand backup :: Make a Nand backup, the following partitions are NOT included :
# Recovery (to avoid restoring old version)
# Cache (no need to backup imo)
# Misc (no need to backup imo + restore issues on some phones)
# Splash1+2 (no need to backup imo + restore issues on some phones)
+ Nand + ext backup :: Make a Nand + ext backup *NEW in v1.6.0
+ Nand restore :: Restore a Nand backup
+ BART backup :: Make a BART backup (Nand + ext) *NEW in v1.6.0
+ BART restore :: Restore latest BART backup *NEW in v1.6.0
o Flash zip from sdcard :: Flash a zip update file from your sdcard
o Wipe
+ Wipe data/factory reset :: Wipe /data and /cache
+ Wipe Dalvik-cache :: Wipe Dalvik-cache both on /data and ext *NEW in v1.6.0
+ Wipe SD:ext partition : Wipe the ext partition on your sdcard *NEW in v1.6.0
+ Wipe battery stats : Wipe the battery stats in /data
+ Wipe rotate settings : Wipe the sensor settings in /data
o Partition sdcard
+ Partition SD :: Interactive SD partitioning
+ Repair SD:ext :: Repair the ext partition *NEW in v1.6.0
+ SD:ext2 to ext3 :: Convert ext2 to ext3 *NEW in v1.6.0
+ SD:ext3 to ext4 :: Convert ext3 to ext4 *NEW in v1.6.0
o Other
+ Fix apk uid mismatches :: Does extacly that
+ Move apps+dalv to SD :: Moves all apps and Dalvik-cache to sdcard (This will NOT enable apps2sd!) *NEW in v1.6.0
+ Move recovery.log to SD :: Moves the recovery log file to your sdcard. (Use when you want more detailed recovery log information)
o Power off :: Powers off your phone
* Scripts available via adb :
o Nandroid v2.2.1 : enter "nandroid-mobile.sh" to start.
o BART v1.0.1 (Backup and Restore Tool) : enter "utility" to start. *NEW in v1.6.0
o switchrom.sh V1.1 : enter "switchrom" or "u" to start. *NEW in v1.6.0
o sdparted v0.6 : enter "sdparted" to start.
Change-log:
v1.6.0
* Fixed mkyaffs2image-arm-uclibc which will hopefully fix the "losing root" issues after a nandroid restore (a big thanks to packetlss for the help on this one)
* Updated busybox to v1.5.3
* Recompiled kernel to fully support ext3 and ext4
* Added lots of ext-features + scripts to stop the a2sd nagging
* Created a carebear version after the idea of packetlss. Be aware that this version contains some "ultra-secret" features!
Chi tiết tại đây
Download
Cài đặt:
Chạy file install-recovery-RA-nexus-v1.6.0.bat
Features
* Extended menu :
o Backup/Restore
o Wipe
o Partition sdcard
o Other
Change-log:
v1.6.0
Chi tiết tại đây
Download
Cài đặt:
