WM 6.1 Build 21054 TouchFlo 3D Look
What is your Favourite Colour Abstract Theme
  • Black
    Votes: 22 61.1%
  • Blue
    Votes: 7 19.4%
  • Red
    Votes: 3 8.3%
  • Yellow
    Votes: 0 0.0%
  • Green
    Votes: 4 11.1%
  • Total voters
    36
wapvirus
WM 6.1 Build 21054 TouchFlo 3D Look​
PDAVIET Special Edition​
Manila 2D v2.0.1917.1723
New Colour TaskBar
HTC Calculator 1.5
HTC Comm Manager v2.9.5.0 (Latest Version)
HTC CM Phone v1.2.0.0
HTC CM Pin v1.3.1.0
HTC CM BlueTooth v0.9.0.0
HTC Camera Album 2.5
PCMKeyboard 1.4 Vietnamese QWERTY
HTC Menu Enhancement v1.1.19163927.01
HTC Notification Enhancement v3.0.1917.1225
HTC Opal Phone Canvas 3.50 (Added new black carbon skin) Fixed 2G
HTC audio Manager v2.0.1819.2129
HTC Volume Control
Safe Inbox Extender
Solitaire Graphics updated
PHM Reg Edit 7.0 by Philippe Majerus
Fexploreext 2.05
PimBack-up 2.8.0.0 by FdcSoft
Synchro Time 0.95 by Dennis Grachov
Talking Sound Events
Netframework 3.5
Task Manager 3.1 by FdcSoft
Easy Contact
Tommy Text Message settings
FingerMsgbox v101
Oxidus Memory
WK Task
XDA Shutdown
I have spent a lot of time getting all the pieces of this ROM together i have re-skinned some
of the apps so it all comes together this version is about Finger Friendliness so that you
can use your stylus less and use your fingers more
Around 25mb with Manila Running
Free Storage 45mb + 10mb Extended ROM = 55mb
DownLoad Here
http://www.mediafire.com/download.php?mjmdi30hg2m
For additional Themes check Post #2
For Recomended Add-ons Post#3​
Big Thanks to Lamson
Big Thanks to WhiteAlien
Big Thanks to Mbravian
Please Note for Camera Usage​
In this ROM Version i have a new app called Camera Loader basically what this app does is control the camera drivers when the camera is not used the drivers are not loaded.
This saves over 4mb of RAM the only problem with this is that camera wont launch from Manila tab and when you close camera it must be by the green X from with in the camera and no other way ,For if you close using ok or taskmanager it also closes camera loader (then camera wont start again)
So please always shutdown camera by green X and you should have no problems​
Also if you have a taskmanger to close apps please make sure you add Camera Loader.exe to the don't close List​
wapvirus
Add-on and Fixes​
This post will contain any fixes or additional add-on cab files for the above ROM​
Advanced config 3.3
http://forum.xda-developers.com/showthread.php?t=418151
Manilla 2D Customizer v0.29.235 (be carefull with this as it not fully designed for this version of Manila)
http://forum.xda-developers.com/showthread.php?t=427392
For MMS Support use this version ArcsoftMMS.5.0.31.7
http://forum.xda-developers.com/atta...0&d=1249651559
Full Microsoft Office 2007 Install to SD card and is again only for the above ROM
http://www.mediafire.com/download.php?uxdomymrzzm
Here Are The Clock Options​
nguyenthuanbg_pv
Bản Rom có giao diện tuyệt quá. Chắc có lẽ phải sài cả mấy cái theme để thay đổi :p. Bản này mong rằng chạy không ì ạch và không bị lỗi hay treo máy khi khởi động.
Cảm ơn Wapvirus.
Nào thử thôi...
wapvirus
Cảm ơn Wapvirus.
Nào thử thôi...
Sorry i can't read your message. Can i please ask you to post in English then i can help and offer full support ;)
Kind Regards wapvirus
Lamson
Cảm ơn Wapvirus.
Nào thử thôi...
mean : The ROM interface is wonderful . Perhaps use all of thems to enjoy the thems. I hope this ROM smoothly running and no errors or stuck on the boot.
Thank Wapvirus.
Test it now…
nguyenthuanbg_pv
gộp bài
Đang thử bản Rom này. Giao diện rất đẹp, Today với GreenAbstract và M2Dv2 Both Clocks:
Nhưng không update thời tiết được (không biết có phải do GPRS :-?)
Và mấy cái Activesyn, TF cứ kích hoạt liên tục
Đã test thấy GPRS tốt, vậy lý do không update được thông tin thời tiết không phải do không kết nối được qua GPRS...
Thank Wapvirus.
nguyenthuanbg_pv
Đã update được thông tin về thời tiết qua Lịch Phù Đổng (cảm ơn Nguyễn Ngọc Cường) :)
Server đang ngon, hình up được rồi, show thêm vài cái hình nữa nào:
(Wapvirus: Thank for your new rom =D>)
@nguyenthuanbg_pv: Nhưng lỗi bạn kể trên khả năng là do bản Manila 2D 2.0 này chưa tương thích với Prophet, mình dùng Viva cũng có bản rom tích hợp M2D 2.0 này cũng hay có lỗi vặt như không xem được video và ảnh ở tab Pictures & Video nhưng update thời tiết vẫn okie...
wapvirus
Sorry my translator can't work for me on this mesage please try to pót english then i can help :-?
nguyenthuanbg_pv
Không phải do bản Rom, đã update thời tiết được rồi, chắc là tại mạng thôi. Nhưng mà cái TouchFlo thỉnh thoảng cứ chạy lại, không biết tại sao nữa :-?
Show thêm vài cái hình:
Thank W@pvirus, this Rom is very good, the weather apdated well via GPRS. But the TouchFlo is restartting sometimes.
The rom is running very stable, nice interface. While there are some errors in Manila but the ability of Manila 2.0 is not compatible with the Prophet...
wapvirus
Thank you nguyenthuanbg & dinhtuananh3010 for your feedback and i would also like to thank you for taking the time to reply in English =D>
This new version of manila needs some work to fix a few buttons ,in pictures and sound settings tab but i am working on what i can to make it work fully on our prophet ;
Regards w@p
