WM 6.5 build 21501 Titanium
ndthanh208
Ai test bản này chưa ạh, cho ý kiến với ạh máy em die rùi không có test tiếc quá!:((
chudiep15687
Mình đã test thử rồi cũng tạm được, giao diện thì đẹp đấy' chay cũng nhanh nhung mình thấy no' hơi kho' sụ dụng,không hay bằng 6.1 :D , các cai' khac' thì vẫn thế không khac' j
duongcongtoan
Demorum trên nè các bác
tayhomieu
giao diện đẹp, nhưng link không down được nhờ bác up lên link khác dùm
chudiep15687
Ok i built this ROM because so many wanted it i have no intention of using 6.5 yet but i have tested and installed a few apps(Titanium Weather ,CeHome Edit ) just to make sure all was well (Not in ROM )this is a Clean build only added my own Comms Manager as it didn't have one but this is built from a untouched SYS and XIP and it's WWE
Thanks again to Doan Lamson for the SYS and XIP
My recomendations for this ROM here
http://forum.xda-developers.com/showthread.php?t=512121
Enjoy my Friends
Download Here: 110 downloads
http://www.adrive.com/public/6425312b2528a3f4ebed60ee39ed0b9e155d87d97498cdea82884496f3d86123.html
Fixes these cab fix the Ringtone and SMS and Mail Problems
chudiep15687
[New 17th May 2009] ROM WM6.1 21042
The Lite :
- CE OS 5.2.21041 (Build 21042.1.6.1)
- pagepool 8 МB
- Free ROM 55 MB, Free RAM 28 MB
- last HTC task manager
- CoolCamera
- HTC Calculator
- QuickMenu (big)
- WM5 NewMenu
- Black dialer
- newer icons in taskbar
- Black CommManager
- Tweaks for economic battery
- tweaks for sound
- No SelfRun Activesync
- Fix Activesync for Vista
- NetCF 3.5
- Office without Power Point
- new Connection Manager from 6.5
- new SimManager
- new STK_UIPPC
- fix (CheckRtc)
- start menu sound
- UC
- deleted unwanted things from OEM и SYS
- Many else
Recommend to make hardreset after flashing
Dowload Rom
meomun208
room này lỗi không new text mess được, dùng ngon lắm, bác nào biết cách sửa lỗi này cho anh em với..
duongcongtoan
Camera thì không bị lỗi gì, đã fix rồi:
http://forum.xda-developers.com/showthread.php?t=516859
Các bạn xem chi tiết ở đây, cả link download và bản fix
Riêng Wifi vẫn đang bị lỗi và không thể tắt sau khi bật được.
Tác giả khuyên nên dùng Wifi monster để thay cho Commanager:
Xem Wifi monster ở topic này: http://pdaviet.net/showpost.php?p=715951&postcount=609
Bản rom này hiện chưa có font tiếng việt, sau khi up rom này xong, download bộ PPCtahoma về cài vào.
Đây cũng có một bản rom xài rất tốt
http://forum.xda-developers.com/showpost.php?p=3459147&postcount=6
Vào Sound & Notifications không chỉnh được các chế độ rung và chuông cho cuộc gọi đến và tin nhắn mà cũng không thể nào thoát ra được nữa... Híc, quay về 6.1 đây...
