dduuoonngg88
x6 vừa ra fw mới chưa lâu lên ít bản cfw mình vừa tìm thấy cái này của vip bên diễn đàn ngoại
đây là cfw mình tìm thấy trên các diễn đàn nước ngoài
mình đã test thử thấy hay lên giới thiệu lên cho anh em nào có nhu cầu sài thử
MODS & HACKS:
\private\
101F4CD2 : Custom Menu. Organised folders into alphabetical order plus renamed and moved some apps. I have also included many apps in the xml configuration file which are not installed with the CFW. This way, when the apps are installed, they go where I want them to go and some are renamed. So, if you install an app and can't find it in the default folder, have a look in the other folders
100059C9 : Custom Folder Creation (scriptinit.txt)
100069CC : Bluetooth Name. Set to 'X6 Remix'
10282F06 : Disabled Widget security notifications
\private\10202be9\
101F87A3 : Voice Recorder. Increase quality and recording time
101F87EB : Messaging Settings. Added Conversation App to messaging menu and increased number of messages in sent items to 500
101F87EF : No request for SMS receipt. Enabled full character support
101F876F : Default theme (Nokia Now)
101F877C : Idle settings
101F978F : UPnP settings
101F8557 : Browser Cache to E Drive
101F8763 : Startup Configuration
101F8798 : Edited profile settings
101F8831 : Enabled call summary
101F8847 : Menu Mod. Unhid some items to move to Tools folder
101F9775 : RAM Cache to C Drive
101FFCD2 : Music Player Harvest Folders. Set to 'E:\Music'
10008D39 : Browser environment
10200C8C : Set light timeout to 30 seconds
10204DAB : File Transfers Folder. Set to 'E:\File Transfers'
10208A43 : Camera RAM Release
10282DF0 : Sensors Mod
10282F0F : Rotation Speed
102072C4 : FOTA settings
102072C6 : FOTA Disk Reserve set to 0
102828AC : Gallery Harvest Folders
102828B1 : Call Volume
102858F2 : Concerns apps
10207342 : Homescreen settings
10275102 : Panning, key-locks and tones settings
10281872 : Video Settings
10283344 : CPU Mod/UI Acceleration. Set fps to 30 and CPU to 75%
20021192 : Kinetic Scrolling Optimized
Improved caching
Java app permissions for installed apps set to 'Always allowed'
Removed default browser bookmark folders and their contents (Download Applications, Download Games, Download Themes etc and their contents)
Disabled Nokia SMS on first start
RomPatcher set to autostart
InstallServer patch
Changed Software Version details *#0000#
Fast & Stylish effects package (You will need to disable theme effects, then re-enable in order to view all of the effects)
APPS
8HS, LiveGadget-9HS & Symbian^3-9HS:
AutoInstaller v1.2.0
BatchUninstall v2.0
BT Switch v1.0
File Browser v4.5.2
KillMe v1.36
Nokia Music Player Update v15.02.1034
Pocket Sensor v1.0
ROM Patcher+ v2.3
Vivaz Conversation
Vodafone Apps Manager v1.7
Custom ROFS2:
Egg Timer v1.0
PhoneTorch v2.0
WinRAR v1.01
8HS, LiveGadget-9HS & Symbian^3-9HS AutoInstaller Apps (E:\ThinkChange\C):
Adobe Flash Lite v3.01.4
Custom ROFS2 AutoInstaller Apps (E:\ThinkChange\C):
Jbak TaskMan v1.37
Ovi Store v1.07.12
PhoNetInfo v2.9.0
Photo Browser v0.9.5
ScreenSnap v3.00
Speedy Go v1.05
Widgetizer v1.04
YouTube v1.00.2
THEMES
Nokia Now (Default)
Custom ROFS2:
Blue
Firebird
Firebird Dots
Nokia Now (Icons)
Nokia Theme White
HOMESCREENS
Standard HomeScreens for 8HS, LiveGadget-9HS & Symbian^3-9HS:
Vodafone (Default)
OraTsu (Tsunami with Nokia style icons)
OraTor (Tornado)
Basic
Contacts Bar
Full Page
Navigation Bar
Shortcuts Bar
LiveGadget-9HS:
Live Gadget
+ Standard HomeScreens
Symbian^3-9HS:
Symbian ^3 HS
CHANGELOG (02-12-10)
Added to 8HS, LiveGadget-9HS & Symbian^3-9HS ROFS3:
Nokia Music Player Update v15.02.1034. This enables the playback of lyrics in the Music Player. The mp3 files need to have the lyrics embedded in them. This can be done with a very handy program called MiniLyrics.
Removed from 8HS, LiveGadget-9HS & Symbian^3-9HS:
PocketLock v1.01. Great app but very buggy. Works ok for a little while then refuses to load. If you want to use this app, I recommend you install via Ovi Store as it may be more stable
Removed from LiveGadget-9HS:
ThumbWheel3 Gadget. Used to work but it's no longer loading properly for me. I will try to troubleshoot this for future releases as it's a great gadget screen.
Edited appshelldata.xml to correct some minor errors
Renamed Office folder to Organiser
Restored previous busy icon
CHANGELOG (01-12-10)
Pocket Lock v1.01
Added to AutoInstaller Folder in Custom ROFS2:
Jbak TaskMan v1.37
PhoNetInfo v2.9.0
Removed from Custom ROFS2:
PhoNetInfo v2.8.0
PhotoBrowser v0.9.4
PocketLock v1.01
Updated firmware version to v30.0.003
Added N8 Icons
Modified menu view and icon placement and positions
Changed theme effects package
link X6 Remix v30.0.003 CFW by dude2009 (8HS)
http://www.mediafire.com/?yh0b2ij91297k7l
X6 Remix v30.0.003 CFW bởi dude2009 (8HS): Đây là một bản 8HS không flash Điều này là lý tưởng cho những người không muốn gặp bất kỳ flash liên quan đến lỗi hoặc các vấn đề nảy sinh
link X6 Remix v30.0.003 CFW by dude2009 (Custom ROFS2)
http://www.mediafire.com/?6ghjyxba6f4n7y3
X6 Remix v30.0.003 CFW bởi dude2009 (Custom ROFS2): rofs2 này là tùy chọn để sử dụng nhưng bao gồm một số ứng dụng bổ sung các tập tin gadget.swf. đã bỏ các tập tin ngôn ngữ không phải tiếng Anh để tạo một số không gian
link X6 Remix v30.0.003 CFW by dude2009 (LiveGadget-9HS)
http://www.mediafire.com/?gazb3tkj0ojd05t
X6 Remix v30.0.003 CFW bởi dude2009 (LiveGadget-9HS): CFW này có 9 homescreens
link X6 Remix v30.0.003 CFW by dude2009 (Symbian^3-9HS)
http://www.mediafire.com/?7obehs7nfr73n64
X6 Remix v30.0.003 CFW bởi dude2009 (Symbian ^ 3-9HS): Đây CFW có 9 homescreens bao gồm một Symbian ^ 3 tiện ích flash phong cách. Như với các LiveGadget-9HS ở trên, bạn sẽ cần phải cài đặt Adobe Flash Lite v3.01.4 sau khi Flash
đây là bản cfw mới nhất của các cao thủ nước ngoài lên dùng rất ổn định
sau khi fash song lên khôi phục lại cài đặt bang *#7370# nha
MODS & HACKS:
\private\
\private\10202be9\
Improved caching
InstallServer patch
APPS
BatchUninstall v2.0
BT Switch v1.0
File Browser v4.5.2
KillMe v1.36
Pocket Sensor v1.0
ROM Patcher+ v2.3
Vivaz Conversation
Custom ROFS2:
Egg Timer v1.0
PhoneTorch v2.0
WinRAR v1.01
Jbak TaskMan v1.37
Ovi Store v1.07.12
PhoNetInfo v2.9.0
ScreenSnap v3.00
Speedy Go v1.05
Widgetizer v1.04
YouTube v1.00.2
THEMES
Nokia Now (Default)
Custom ROFS2:
Blue
Firebird
Firebird Dots
Nokia Now (Icons)
Nokia Theme White
HOMESCREENS
Vodafone (Default)
OraTor (Tornado)
Basic
Contacts Bar
Full Page
Navigation Bar
Shortcuts Bar
LiveGadget-9HS:
Live Gadget
Symbian^3-9HS:
Symbian ^3 HS
Pocket Lock v1.01
Jbak TaskMan v1.37
PhoNetInfo v2.9.0
PhoNetInfo v2.8.0
PhotoBrowser v0.9.4
PocketLock v1.01
Added N8 Icons
