XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 20273)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.20273 Build 20273.1.3.3 PV
=== Only for XDA ATOM/XDA ATOM PURE ===
Lời cám ơn - Thanks:
Manager PhamQuang (Special thanks)
Admin Kawaguchi (Special thanks)
Mod Dvha79_ddt (Special thanks)
Mod Medkid
Mod Hoangdat_vista
Trial Mod Lamson
Trial Mod PhamNhatThanh
Trial Mod TranMinhMan
Trial Mod nhocbanme
Trial Mod khacduy1978
Thông tin - ROM Information:
- CE OS 5.2.20273 Build 20273.1.3.3 PV
- Pagepool: 6M
- ROM Version: 20080802C2WWE
- ROM Date: 08/02/2008
- Ported from HTC Diamond ROM (XIP & SYS 20273)
- High Speed ROM
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- .NET Compact Framework 2.0.7045.0
- Office Mobile 6.1
- Office Note
- ArcsoftMMS v5.0.31.11
- Windows Media Player 10.3 Build 20273
- Adobe Reader LE 2.5
- Adobe Flash Lite v2.1
- Advanced Configuration Tool v2.02.0.1.0 by Schap
- ClearTemp v1.0.2 by Vicott Wong
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.49
- Synchro Time v0.94 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080610.2.1
- EnlargeStartMenu v1.2.34070.1
- Total Commander CE v2.5 by Christian Ghisler
- SMS Display Mode by Sonblack (change message display on PPC)
- WKTask v1.1.7.3 (open/close applications fastly)
- PocketRAR v3.71 by Alexander Roshal
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- BatteryStatus Today Plugin v0.05.126 Build 0309 by Chi-Tai Dang
- PHM TrayLaunch
- Pocket Screen v1.3 by JJM. Roseboom
Hướng dẫn - Guides:
Tải file .exe về máy. Chạy nó. Giải nén vào thư mục C:\Windows\Temp. Chạy file Device Software Update Utility.exe từ thư mục này để up rom.
Download the .exe file to PC. Execute it. Uncompress to folder
C:\Windows\Temp. Run file Device Software Update Utility.exe from this folder for flashing rom.
Link bây giờ có sẵn.
The link is available now.
ATOM ROM 20273 - PDAVIET
PASSWORD for uncompress: SONBLACK
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Up cả EXtendedROM để có được giao diện màu đen của Wireless Manager.
Flashing with option "Update Item" is "OS+EXtendedROM" for having black skin of
Wireless Manager.
Chúc vui.
Enjoy it.
Sonblack
maitaison
ô là lá em bóc tem con này hehehehehe hôm nay là một ngày may măn
éc viết xong mới nhìn ra là chưa có link hic
thế có dau ko cơ chứ
phamcongli
Hix hix , ham hố cafe với đám bạn nên mất tem roài . Mà không bik bản này thế nào nhở . Đợi có link roài tẽt thử xem sao ....
VOKE
trời , canh me từ chiều giờ , mới đi uống về lại bị người ta bóc tem roài .. hic hic
Anh Sơn nên chỉnh hai cái button Soft reset lại nhé , cụ thể khi ấn vào thì nó hiện popup lên cảnh báo rồi ta chọn yes để SR ( như bản trước kia ) như thế sẽ hoàn hảo hơn khi mà hai button SR và PowerOff nằm cạnh nhau , nhiều lúc muốn Turn Off lại vô tình chạm phải button SR làm nó khởi động lại ko báo một câu !
Sonblack
Chỉnh rời nhau ra được chứ bạn, có sẵn PHM TrayLaunch để làm việc đó kia mà.
knmh2005
cảm ơn anh Son nhiều nha
Sao chưa có link down vậy Anh Sơn!
mykolor
Cho em hỏi ROM này anh mod từ dòng nào vậy anh Sơn, Diamond hả anh?
HTC Diamond!
maitaison
hehe mặc dù mình hok được down đầu tiên nhưng cũng lại là người bóc tem sp hehehehe sướng
takaru
Hôm qua bị ốm , chỉ kịp vào nhìn mấy cái ảnh mà a Sơn post lên thấy có iphone cho nên không thích lắm ( vì không thích iphone thôi ) . giờ quay lại đã thấy khác rồi . up up up nào . Cám ơn a Sơn .
SaipanX
ĐÊM NAY ĐANG BUỒN NGỒI LANG THANG TRÊN MẠNG,
vo pdaviet lại có rom mới nữa. Có việc để làm roài, hi vong ko mất điện ^^
Just do it!
Thanks anh Sơn
linh_ck01
Son daika làm em nhức nhối miết, cái ROM 2070 còn chưa có lỗi gì , nay đã có 20273 , hix, thanks daika nhìu nhìu ...
tiamo100187
THANK BÁC SƠN NHIỀU NHA
E CÓ Ý KIẾN THẾ NÀY,KO BIẾT BÁC CÓ Ý TƯỞNG LÀM BẢN ROM VỚI GIAO DIỆN WM7 KO NHỈ
takaru
Nếu giao diện WM7 giống như những gì mà báo chí đã đưa thì tôi thấy nó không thể đẹp bằng những bản rom mà a Sơn build .
Nhận xét về bản rom này thì tôi thấy đây lại là 1 bản rom hoàn hảo nữa của anh Sơn . Tôi không bao giờ lo lắng về tính ổn định mỗi khi up rom của anh Sơn .Tôi vẫn đang đợi 1 bản rom đột phá của anh Sơn .
