XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 20759)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.20759 Build 20759.1.4.2 PV
=== Only for XDA ATOM / ATOM PURE ===
Lời cám ơn - Thanks:
Super Mod PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Lamson, TranMinhMan, Hoangdat_vista
Trial Mod PhamNhatThanh, khacduy1978
VIP Medkid, nhocbanme, nhattoai
herg62123, poorlyduck from xda-developers
Thông tin - ROM Information:
- CE OS 5.2.20759 Build 20759.1.4.2 PV
- Pagepool: 6M
- Rom date: November 30, 2008
- ROM Version: 20081130D5WWE
- Transcriber included.
- Manilla 2D with Black Skin also included.
- Remove all help files.
- XIP & SYS from latest original rom of HTC QUARTZ
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- AudioManager v2.0 Build 1820.1321 (Elfin)
- JBlend Java v3.3.5 Build 20081015.1.1 (Jade)
- RSS Hub v2.1.1.1069.00 (Elfin)
- Outlook Enhancement (Elfin)
- Picture Enhancement (Elfin)
- Comm Manager v2.7.2.8
- ArcsoftMMS v5.0.31.63 (Elfin)
- Enlarge Start Menu (Mod from Elfin)
- Enlarge TitleBar (Elfin)
- YouTube v1.5.1820.2325 (Elfin)
- Manila2D v1.00.1819.2926
- HTC Sim Manager for Pocket PC v6.58
- .NET Compact Framework 3.5.7283.0
- Windows Media Player 10.3 Build 20759
- Office Mobile 6.1
- Office Note
- HTC Album (automatically run)
- Google Maps (automatically run)
- Opera Browser (automatically run)
- SIPChange (automatically run)
- Manilla 2D Custumizer v0.25.227 by Mpenguin14 (automatically run)
- W0lf's Translator v1.0
- Advanced Configuration Tool v3.3 by Schap
- Pocket RAR v3.80 by Alexander Roshal
- ClearTemp v1.1 by Vicott Wong
- PIM Backup v2.8.0.0 by FdcSoft
- Pocket Screen v1.3 by JJM. Roseboom
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.2.0.0 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn - The link is available now
Link nằm trong file đính kèm ở cuối bài - Link put under attached file at the end of this post
UP ROM VỚI TÙY CHỌN "OS+ExtendedROM".
FLASH THE ROM WITH OPTION "
OS+ExtendedROM".
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Cuối tuần vui vẻ!
Have a good weekend!
Sonblack
AnhPheCT
Bản Rom này của HTC QUARTZ (4G) Bác SonBlack build cho Atom (2G). sẽ có nhiều tính năng rất tuyệt!! Rom HTC QUARTZ cũng đã build lại cho rất nhiều dòng máy PPC Chạy rất tốt!!! Xin Cảm ơn!! và mong đợi rất nhiều!!
Sonblack
Về cơ bản, bản ROM này không có nhiều khác biệt so với bản ROM 19972 vừa rồi, chỉ có sự tinh chỉnh đôi chút để WMP có thể chơi nhạc khi Screen Off...
Khác biệt duy nhất là nâng tầm build mới mà thôi.
Basically, this ROM has a little different with ROM 19972, adjust registry for WMP can play when Screen is Off...
Only difference is new build and new utilities.
Thanks and enjoy it!
KiD2034
Bản Rom cũ hình như WMP kô có chức năng play khi open another program , nên khi chạy cái khác là nó pause.Mà giờ cũng kô sao rùi vì S2P nghe nhạc mình thấy tiện hơn WMP. Còn WMP để xem film :D đang xem Taxi 4 tải trên mạng về đuôi WMV coi đã lun.
Bản 20759 có thêm 2 cái mới là :
Cảm ơn anh Sơn rất nhiều.ROM của anh Sơn thì lúc nào em cũng enjoy it!
P/s : Xin mọi người đừng Spam để anh Sơn có thời gian up ROM nhé.
thienly12333
hình như chạy wmp bạn vào options chỉnh lại chỗ lib....(mình nhớ là vậy)là chạy ẩn được mà!!!!!!!!!!
Caohieu88
Chúc mừng anh Sơn và dân nghiền Atom với bản Rom xịn mới toanh!!!! Vui wa ^ ^ :D
KiD2034
Vào đó chỉ có mục : " Start Player on Library screen " thôi bạn ơi,chức năng này là khi bạn chạy WMP thì nó sẽ vào Library lun cho bạn chọn Music hay Video để play rùi mới ra màn hình chính của WMP.
mapbuidoi
Hic rất tiếc Atom nứt màn hình cảm ứng. Mà bác sơn nấu rom như ăn gỏi vậy. Bùn quá trời luôn
Sonblack
Link đã cập nhật, anh em vào down nhé!
Bản kế tiếp 20764.1.4.3 sẽ có vào cuối tuần hoặc sớm hơn.
KiD2034
Anh SƠn UP ROM rồi kìa pà kon , vào down về và nhớ Thanks Anh Sơn đóa nha . Em mạn phép bóc cái tem đầu tiên.
Bác son có ROM mới rồi hay quá
bác son ơi bản này có support super SIM không bác?
anh em down thôi, tối nay khỏi ngủ luôn
cảm ơn bác son rất nhiều
chúc bác luôn vui ! :D
Sonblack
Bản nào cũng chơi hết các SIM, có loại trừ thèng nào đâu, miễn là SIM của hệ GSM là ok.
tuananhg
bản Rom này sao dung lượng gần 77mb vậy anh Sơn,mấy bản rom trước chỉ khoảng 50mb thôi
Trời! bác SON có phải là người máy không vậy?:O
bác mới ra bản ROM hôm nay vậy mà tuần sau bác đã ra cái mới !
em phục bác sát đất lun =D>
không biết bản này thế nào nhỉ! bác son ơi bản trước (19972) em thấy Volume hơi nhỏ, nhỏ hơn bản 20758 nữa!
ah bác son ơi bản này còn O2 media plus không?
cảm ơn bác rất nhiều!
