XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 20764)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.20764 Build 20764.1.4.3 PV
=== Only for XDA ATOM / ATOM PURE ===
Lời cám ơn - Thanks:
Super Mod PhamQuang
Super Mod BatKid
Admin Kawaguchi
Adv. Mod Dvha79_ddt
Mod Lamson, TranMinhMan, Hoangdat_vista
Trial Mod PhamNhatThanh, khacduy1978, nhattoai
VIP Medkid, nhocbanme
herg62123, poorlyduck from xda-developers
Thông tin - ROM Information:
- CE OS 5.2.20764 Build 20764.1.4.3 PV
- Pagepool: 6M
- Rom date: December 5, 2008
- ROM Version: 20081205D6WWE
- Well supported A2DP (modules from my ROM 19212) now (Thanks to nikworld07 and
BatKid again)
- Transcriber included.
- Manilla 2D with
Blue Skin also included.
- Remove all help files.
- XIP & SYS from xbeta.cn (It said they're from original ROM of BlackStone but I'm not sure)
Hình minh hoạ - Illustrative Images:
Chức năng chính - Main functions:
- AudioManager v2.0 Build 1820.1321 (Elfin)
- JBlend Java v3.3.5 Build 20081015.1.1 (Jade)
- RSS Hub v2.1.1.1069.00 (Elfin)
- Outlook Enhancement (Elfin)
- Picture Enhancement (Elfin)
- Comm Manager v2.7.2.8
- ArcsoftMMS v5.0.31.63 (Elfin)
- Enlarge Start Menu (Moderate from Elfin)
- Enlarge TitleBar (Elfin)
- YouTube v1.5.1820.2325 (Elfin)
- Manila2D from Elfin (Moderate)
- HTC Sim Manager for Pocket PC v6.58
- .NET Compact Framework 3.5.7283.0
- Windows Media Player 10.3 Build 20764
- Office Mobile 6.1
- Office Note
- HTC Album (Moderate from Elfin)
- Google Maps (automatically run)
- Opera Browser (automatically run)
- SIPChange (automatically run)
- Advanced Configuration Tool v3.3 by Schap
- Pocket RAR v3.80 by Alexander Roshal
- ClearTemp v1.1 by Vicott Wong
- PIM Backup v2.8.0.0 by FdcSoft
- Pocket Screen v1.3 by JJM. Roseboom
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.2.0.0 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn - The link is available now
Link nằm trong file đính kèm ở cuối bài - Link put under attached file at the end of this post
UP ROM VỚI TÙY CHỌN "OS+ExtendedROM".
FLASH THE ROM WITH OPTION "
OS+ExtendedROM".
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Cuối tuần vui vẻ!
Have a good weekend!
Sonblack
nikworld07
man i told u to put modules from core 19212 and u did . thank you very much . lets see it works or not.
Atomo2
ROM có trong trước tối nay ko Bro? Cho xin nhìn cái giao diện chút xíu. Spam Bro đừng nổi wậu nghen.
nikworld07
when are u going to release it . i am going mad
please include thí module in all of your next roms mr . sonblack please ....
Sonblack
Don't worry, I know what I have to do :D I test finish time and post today from 9.00PM - 10.00PM (GMT +7, Vietnamese timezone). Please wait...
advshadab
Waiting déprately :D
ThanX SONBLACK.:D
Hey SONBLACK can't you insert the Network Setup from the link I provided???
Sonblack
Cái tên nói lên tất cả!
Có gì phải buồn hả.? Nếu muốn xóa bài của người khác thì ít ra phải cho biết lý do. Còn đã lên diễn đàn này rồi thì không phải ai cũng biết về pda,nếu bạn biết nhiều thì thì hổ trợ anh em còn không thì để người khác giúp. Không nhất thiết bạn nói này nói nọ hay xóa bài người khác rồi trả lời lại với câu THẾ THÔI!!! Còn về tuổi đời đây xin thưa là sonden còn nhỏ hơn thằng cháu tôi rất nhiều! Nếu muốn chứng minh thì đây dẩn đi xem luôn!
Theo cái nick này thì anh em nhà Atom nghĩ như thế nào? Đây là nick khác của tiensylao, tsl hay tsl007 đã bị BQT ban nick vì xúc phạm điều hành viên, chửi bới lăng mạ tôi qua PM khi tôi nhắc nhở về cách thức và lời lẽ khi post bài. Tuổi đời của con người này chỉ ngang bằng với cháu ruột tôi mà thôi.
Tôi lưu lại lời của nick này để lỡ ai đó trong BQT xóa thì anh em còn biết.
Tôi rất buồn vì điều này.
Còn đây là quy định của PDAVIET: http://www.pdaviet.net/showthread.php?t=15101
Sonblack
ThanX SONBLACK.:D
I check Network Wizard and it's data. I know that it support Indian Network Suppliers as follows:
1. AirTel
2. BPL
3. BSNL
4. Hutch
5. Idea
6. MTNL
7. MTNL (Prepaid)
8. Spice (Karnataka)
9. Spice (Punjab)
What's your supplier in India?
AnhPheCT
Theo mình BQT nên xem thông tin Đăng ký của "thangchosonden" và xóa nich lẫn thông tin đăng ký vĩnh viễn ko cho ĐK hoặc thảo luận trên diễn đàn PDAviet nữa!!! Làm người sai mà ko biết mình sai ở đâu thà đâm đầu vào xe cho xong!!! đã bị nhắc nhở còn quay lại thô tục người khác!Một con người vô học thức!! Nên thẳng tay!!! Mong BQT xem xét!!! Xóa vĩnh viễn Nick và thông tin thành viên " thangchosonden" này.
drRazi
so... when will you upload it mr ? ;;) thanks..
btw.. banda aceh (aceh, indonesia) could be included in weather?
So sorry when I edit your post because I answered already for another: 9.00PM - 10.00PM (GMT+7 - Bangkok, Hanoi, Jakarta) :D (Sonblack)
KiD2034
Anh Sơn cho em hỏi Core 19xxx và 20xxx thì em bik khác nhau là Touch và ActiveSync chạy nền.Vậy 207xx và 209xx thì có gỉ khác nhau kô vậy anh Sơn?
@drRazi : Mr Sơn will up ROM in 9PM to 10PM (GMT+7 - VietNam,Bangkok)
@ thangchosonden : người Việt Nam cái gì cũng bik chỉ có BIẾT ĐIỀU là KÔ bik mà thôi,người thiếu học thức văn hóa như bạn cũng bik xài PDA nữa àh ??? :O
Sonblack
Đã gom vào 1 nhóm 20xxx rồi mà còn tách ra hỏi :))
KiD2034
when will I get this new ROM mr sonblack :((
So sorry when I edit your post because I answered already for another: 9.00PM - 10.00PM (GMT+7 - Bangkok, Hanoi, Jakarta) (Sonblack)
Sonblack
cho em hỏi là rom mới này có ji` khác rom cũ ko anh? và chức năng thì có cái ji` hơn vậy anh?thanks
Trời ạ! Post bài có tiếng Việt mà bạn, hãy đọc và so sánh đi chứ. Rồi hình minh họa nữa kia mà :O
@All: Rom đã có sẵn để tải về - The rom is available for downloading.
AnhPheCT
Xin hỏi A2DP là gì? Có phải thế ko? Mình Search trên Googe giải thích thế này:
"Trước đây khi bạn sắm tai nghe Bluetooth, bạn chỉ có thể sử dụng được chức năng nghe và nhận cuộc gọi với chiếc ĐTDĐ của mình.
Khi công nghệ Bluetooth phát triển, nhu cầu nghe nhạc của người dùng tăng cao, chuẩn Bluetooth 2.0 kết hợp với tính năng A2DP được tích hợp đã giúp người sử dụng ĐTDĐ có thể nghe nhạc một cách rảnh tay và thoải mái hơn.
A2DP (Advanced Audio Distribution) là một trong những chế độ Bluetooth hỗ trợ ĐTDĐ khả năng phát ra âm thanh chuẩn stereo với chất lượng gần tương đương với tai nghe có dây thông thường. Về lý thuyết, công nghệ Bluetooth hỗ trợ truyền tải dữ liệu ở tốc độ tối đa là 1 Mbps và khoảng cách tốt nhất với bán kính dưới 10 mét.
Tuy nhiên, thực tế thì tốc độ truyền tải của Bluetooth chỉ đạt khoảng 700 Kbps và tùy hiệu năng của từng dòng ĐTDĐ có thể thấp hơn mức này. Chính vì vậy, chất lượng âm thanh khi nghe nhạc thông qua tai nghe Bluetooth thường không hay bằng tai nghe có dây khi kết nối hai thiết bị ở khoảng cách xa và có vật cản. Tuy vậy, ở khoảng cách gần và không bị cản trở, tai nghe Bluetooth A2DP vẫn đem lại chất lượng âm thanh tốt. "
